On Nov 21, 5:49*am, lanebush wrote:
Scott, The 337 form can be sent in before the work begins. *This allows for approval/disapproval before a saw is taken to the airplane. *I imagine you will have to hire a DER (designated engineering representative) to do an engineering analysis to accompany the 337. *Harold Kasola is very easy to work with and has Kasola Engineering in Albany, GA. *A call to him would be worth the effort. *Having just certified a club glider in experimental (last week), I can tell you it took a few days and a trip to the FSDO. No inspector is going to sign a 337 before the work is done and DAR/ DER's aren't cheap. I paid $750.00 for an airworthiness-for-export and the guy wasn't here more than 30 minutes. JJ |
![]() And why exactly do you want to keep the std reg? Some insurance policies take a very dim view of EXPERIMENTAL aircraft. I recall one policy that would actually cover me if flying an aircraft with a STD airworthiness certificate, but not when flying an aircraft with an EXPERIMENTAL airworthiness certificate. This might be an issue for some. |
On Nov 22, 8:21*am, Guy Byars wrote:
And why exactly do you want to keep the std reg? Some insurance policies take a very dim view of EXPERIMENTAL aircraft. *I recall one policy that would actually cover me if flying an aircraft with a STD airworthiness certificate, but not when flying an aircraft with an EXPERIMENTAL airworthiness certificate. *This might be an issue for some. absolutely positively not the case for the SSA Group plan through Costello. Also if the group plan won't work for you the EAA has a fine group insurance plan as well. |
I'm pretty sure going to experimental would place various restrictions on the flying of the aircraft. Â*
I really like to fiddle my own panel/Oâ‚‚/cockpit as I see fit, without paying someone $100+ an hour to do it for me, usually not to my liking (no mechanic cares as much about my glider as I do ![]() being able to do other repair work on it myself, of course following the FAR guidelines on work/inspection/signoffs. There are no *practical restrictions on your flight regime in an EXP glider though. Besides not being able to use it commercially (renting it out, not an issue for your Cirrus ) and a little extra paperwork, the only limitation I can think of would be including the term 'experimental' in your identification stream when announcing yourself to ATC if you ever need to. I had an EXP glider I thought I wanted to be Std when I first got it. After looking at what the actual differences are (not the perceived ones...), I realized I don't want a Std reg glider for myself anyhow. Seeing you are up for making your own winglets, to me it's strange you would lean towards Std since it keeps your obviously skilled hands tied behind your back... -Paul |
On Nov 22, 8:07*am, Tony wrote:
On Nov 22, 8:21*am, Guy Byars wrote: And why exactly do you want to keep the std reg? Some insurance policies take a very dim view of EXPERIMENTAL aircraft. *I recall one policy that would actually cover me if flying an aircraft with a STD airworthiness certificate, but not when flying an aircraft with an EXPERIMENTAL airworthiness certificate. *This might be an issue for some. absolutely positively not the case for the SSA Group plan through Costello. *Also if the group plan won't work for you the EAA has a fine group insurance plan as well. The insurance issue for experimental relates to Life insurance not to the aircraft hull and liability insurance. Andy |
On Nov 22, 8:21*am, Guy Byars wrote: And why exactly do you want to keep the std reg? Some insurance policies take a very dim view of EXPERIMENTAL aircraft. *I recall one policy that would actually cover me if flying an aircraft with a STD airworthiness certificate, but not when flying an aircraft with an EXPERIMENTAL airworthiness certificate. *This might be an issue for some. absolutely positively not the case for the SSA Group plan through Costello. *Also if the group plan won't work for you the EAA has a fine group insurance plan as well. I think he was talking of life insurance underwriters. Some will not cover you, others want a rider if you fly personally, perhaps another if you fly experimental. Some are not so restrictive. NY Life was one several years ago. No idea of the current status. AOPA has programs for pilots. Frank Whiteley |
![]() "Frank Whiteley" wrote in message ... I think he was talking of life insurance underwriters. Some will not cover you, others want a rider if you fly personally, perhaps another if you fly experimental. Some are not so restrictive. NY Life was one several years ago. No idea of the current status. AOPA has programs for pilots. As do these folks: http://www.piclife.com/ Two years ago I priced several companies, including AOPA. PICLife (they are actually just an agency, like Costello) came in with the best price. Your results may vary. Life insurance is a significant investment, get multiple quotes! Vaughn |
On 11-22-2010 13:36, JJ Sinclair wrote:
On Nov 21, 5:49 am, wrote: Scott, The 337 form can be sent in before the work begins. This allows for approval/disapproval before a saw is taken to the airplane. I imagine you will have to hire a DER (designated engineering representative) to do an engineering analysis to accompany the 337. Harold Kasola is very easy to work with and has Kasola Engineering in Albany, GA. A call to him would be worth the effort. Having just certified a club glider in experimental (last week), I can tell you it took a few days and a trip to the FSDO. No inspector is going to sign a 337 before the work is done and DAR/ DER's aren't cheap. I paid $750.00 for an airworthiness-for-export and the guy wasn't here more than 30 minutes. JJ And I'm still having a hard time wrapping myself around the notion that the FAA would be happy to change an aircraft airworthiness certificate from standard to experimental for such a "small" change to the aircraft and then turn over maintenance to the owner and just have an A&P sign off a condition inspection yearly. Plus, I still think 337s are not used to place an aircraft into the experimental category. For example, a 337 (or STC) would be needed (I believe) to recover the wings on a Cessna 140 that was originally covered with Grade A cotton when built and certified and you recovered them with Stits. |
On Nov 22, 3:16*pm, Scott wrote:
On 11-22-2010 13:36, JJ Sinclair wrote: On Nov 21, 5:49 am, *wrote: Scott, The 337 form can be sent in before the work begins. *This allows for approval/disapproval before a saw is taken to the airplane. *I imagine you will have to hire a DER (designated engineering representative) to do an engineering analysis to accompany the 337. *Harold Kasola is very easy to work with and has Kasola Engineering in Albany, GA. *A call to him would be worth the effort. *Having just certified a club glider in experimental (last week), I can tell you it took a few days and a trip to the FSDO. No inspector is going to sign a 337 before the work is done and DAR/ DER's aren't cheap. I paid $750.00 for an airworthiness-for-export and the guy wasn't here more than 30 minutes. JJ And I'm still having a hard time wrapping myself around the notion that the FAA would be happy to change an aircraft airworthiness certificate from standard to experimental for such a "small" change to the aircraft and then turn over maintenance to the owner and just have an A&P sign off a condition inspection yearly. *Plus, I still think 337s are not used to place an aircraft into the experimental category. *For example, a 337 (or STC) would be needed (I believe) to recover the wings on a Cessna 140 that was originally covered with Grade A cotton when built and certified and you recovered them with Stits.- Hide quoted text - - Show quoted text - Scott, In order to modify a ship in standard category you need a 337 and your inspector will need an approved method usually an STC. There is no approved method for adding winglets to your Cirrus and an DAR or EAD or FAA engineering will still need approved data. The other way to add winglets to your Cirrus is to go down to your FSDO and tell them you would like to add winglets, but the factory doesn't provide this option. Request they change your registration to experimental. Once your in experimental category, the winglets may be added with a log book entry from an A&P. I recommend you have the work done at a certified repair shop because improperly installed winglets can change the flight characteristics and lead to big trouble................I remember a guy that added his own home brew winglets and the ship was the better part of uncontrollable! The only way he was able to maintain control was to keep the speed above 80. He was forced to land doing 80 also. Hope this helps, JJ |
On 11-23-2010 15:10, JJ Sinclair wrote:
On Nov 22, 3:16 pm, wrote: On 11-22-2010 13:36, JJ Sinclair wrote: On Nov 21, 5:49 am, wrote: Scott, The 337 form can be sent in before the work begins. This allows for approval/disapproval before a saw is taken to the airplane. I imagine you will have to hire a DER (designated engineering representative) to do an engineering analysis to accompany the 337. Harold Kasola is very easy to work with and has Kasola Engineering in Albany, GA. A call to him would be worth the effort. Having just certified a club glider in experimental (last week), I can tell you it took a few days and a trip to the FSDO. No inspector is going to sign a 337 before the work is done and DAR/ DER's aren't cheap. I paid $750.00 for an airworthiness-for-export and the guy wasn't here more than 30 minutes. JJ And I'm still having a hard time wrapping myself around the notion that the FAA would be happy to change an aircraft airworthiness certificate from standard to experimental for such a "small" change to the aircraft and then turn over maintenance to the owner and just have an A&P sign off a condition inspection yearly. Plus, I still think 337s are not used to place an aircraft into the experimental category. For example, a 337 (or STC) would be needed (I believe) to recover the wings on a Cessna 140 that was originally covered with Grade A cotton when built and certified and you recovered them with Stits.- Hide quoted text - - Show quoted text - Scott, In order to modify a ship in standard category you need a 337 and your inspector will need an approved method usually an STC. There is no approved method for adding winglets to your Cirrus and an DAR or EAD or FAA engineering will still need approved data. The other way to add winglets to your Cirrus is to go down to your FSDO and tell them you would like to add winglets, but the factory doesn't provide this option. Request they change your registration to experimental. Once your in experimental category, the winglets may be added with a log book entry from an A&P. I recommend you have the work done at a certified repair shop because improperly installed winglets can change the flight characteristics and lead to big trouble................I remember a guy that added his own home brew winglets and the ship was the better part of uncontrollable! The only way he was able to maintain control was to keep the speed above 80. He was forced to land doing 80 also. Hope this helps, JJ OK...I am not the original poster...at present I do not own a sailplane...just a powered expermental airplane. I didn't realize it was apparently fairly easy (???) to ask the FAA to change from a standard to experimental airworthiness certificate. Maybe I will see if I can get our Cessna 140 into the experimental class so I can do more owner maint/mods ![]() |
FAA Revoking Standard Airworthiness Certificate DG-505 | NG | Soaring | 32 | February 16th 17 02:23 PM |
Airworthiness Certificate Replacement? | [email protected] | Soaring | 6 | June 26th 08 07:11 PM |
USA Glider Experimental Airworthiness Certificate | charlie foxtrot | Soaring | 4 | April 15th 06 05:04 AM |
Exhibition/Racing Airworthiness Certificate Question | bsquared | Soaring | 5 | June 22nd 04 06:24 PM |
Airworthiness Directives for Jantar Standard 3 | Miguel Lavalle | Soaring | 5 | January 24th 04 10:55 AM |
