How do I legallly install winglets on a standard airworthiness certificate?
Old November 23rd 10, 06:32 PM posted to rec.aviation.soaring
kirk.stant
Default How do I legallly install winglets on a standard airworthiness certificate?
OK...I am not the original poster...at present I do not own a
sailplane...just a powered expermental airplane. *I didn't realize it
was apparently fairly easy (???) to ask the FAA to change from a
standard to experimental airworthiness certificate. *Maybe I will see if
I can get our Cessna 140 into the experimental class so I can do more owner maint/mods
Scott, you are apparently confusing Experimental Homebuilt (where the
original builder can maintain "his" plane) with Experimental Racing
and Exhibition, which is the catagory many gliders are registered in.
No way you can change your 140 to Ex-homebuilt, but you could probably
change it to EX-Racing and Exhibition.
I'll leave it to smarter people than I to explain the difference.
Kirk
66
Old November 24th 10, 09:20 PM posted to rec.aviation.soaring
Johan Nykvist
At 16:39 20 November 2010, Scott Alexander wrote:
A friend in my club built a pair of winglets for his Standard Cirrus.
His glider is expirmental, mine is not. The total cost for him was
just a hundred dollars for supplies, and some free guidance from a
local IA/AP. The finished product looks fantastic! The mold came
from an American Spirit, which I believe is a copy of the Ventus. And
the result is that his handling has improved quite a bit. He did do
some adjustments on the toe-out angle to fine tune it which
supposively helped.
I would like to do the same thing with mine using the exact same
molds. My Cirrus is a standard airworthiness certificate. If I were
to do the factory winglet or the Maughmer winglet, the cost is between
3,000-5,000 when it's all said and done. So that being said, this
option, looks very appealing.
Has anyone in this group dealt with the same sort of deal? I would be
willing to change my standard airworthiness certificate over to an
expiremental if that is the best solution. Any guidance is much
appreciated.
Thanks,
Scott
PS Happy Thanksgiving.
If it was me, Id go with the factory, or atlest the STC. Remember,
the value of the glider will probably rise as much as invested.
Maby im wrong, but maby the valu will be lower than now when
in experimental alternative. How would u think if you was a
intrested buyer of that glider?
Im sure youre friends winglets improved handeling. But Im also
sure factory or Maughmer performes even better!! Its just much
more engineering and testing behind it!!
It might be cheaper in the end, when you want to sell for upgrading to a
Discus2!! =)
Just a thouhgt.
Old November 24th 10, 09:43 PM posted to rec.aviation.soaring
Darryl Ramm
His glider is expirmental, mine is not. *The total cost for him was
local IA/AP. *The finished product looks fantastic! *The mold came
from an American Spirit, which I believe is a copy of the Ventus. *And
the result is that his handling has improved quite a bit. *He did do
supposively helped.
molds. *My Cirrus is a standard airworthiness certificate. *If I were
3,000-5,000 when it's all said and done. *So that being said, this
Has anyone in this group dealt with the same sort of deal? *I would be
expiremental if that is the best solution. *Any guidance is much
appreciated.
Thanks,
Scott
If it was me, Id go with the factory, or atlest the STC. *Remember,
in experimental alternative. *How would u think if you was a
sure factory or Maughmer performes even better!! *Its just much
more engineering and testing behind it!! *
Discus2!! =)
Just a thouhgt.
There are no STCs. So the aftermarket winglets on certified gliders
must be being done via a 337.
Darryl
FAA Revoking Standard Airworthiness Certificate DG-505 NG Soaring 32 February 16th 17 02:23 PM
Airworthiness Certificate Replacement? [email protected] Soaring 6 June 26th 08 07:11 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 05:04 AM
Exhibition/Racing Airworthiness Certificate Question bsquared Soaring 5 June 22nd 04 06:24 PM
Airworthiness Directives for Jantar Standard 3 Miguel Lavalle Soaring 5 January 24th 04 10:55 AM
