#21
On Dec 16, 11:30*am, Andy wrote:
On Dec 15, 11:58*pm, Tom Kelley wrote: Andy, *9B, you can't even get to 1178 lbs, as you, my friend, have an ASW 27 which has a max. weight of 1102 lbs.............. Check the wing on the ASH 31, its 128 sq. ft. and look at the ASH 26E, its 125 sq. ft. Look at their weights as they are motorgliders. Hey Tom, I was quoting your math for an ASG-29-18m rather than my -27B. If the intent of the rule is to allow for soft fields or short, high/hot runways it seems like ballasting to the heaviest motorglider TOW might not get used much if there are heavy motorgliders on the grid since it will put the non-motorgliders at pretty high wing loadings, which is not what you want for towing under those takeoff conditions. I guess it's a middle ground, but in some cases may not be much of one - at least where it comes to the non-motorgliders. 9B Two solutions leap to mind - add the ballast when airborne (that should be interesting!) or make motorgliders compete separately under thier own rules. I've never understood the mindset that permits motorgliders, with their inherent and unmeasurable advantage, to compete with unpowered sailplanes. Mike |
Just a question. From a totally outside perspective having only flown
in one Sports Class fun contest, why are we using ballast to create what amounts to a handicap? Wouldn't it be much simpler to just apply a handicap factor like we already do in Sports??? The partial ballast solution just seems to be a complex anser to a simple problem. Pete Just a simple Ka-6 driver |
![]() I've never understood the mindset that permits motorgliders, with their inherent and unmeasurable advantage, to compete with unpowered sailplanes. Mike Answer: Small numbers. Give me 65 gliders at every nationals, with more begging to get in, and we can split off a motorglider class. Give me 8 at opens, 10 at standard, and only mid-20s in 15-18, and we don't have enough gliders to split each class in two. At regionals: typical numbers are 7 in each class, and say 3 motorgliders in the contest. What do you do? We're already merging FAI classes to get reasonable numbers. When was the last time you saw an open class regional, or a regional with a full set of classes? We don't have the gliders to split each class in two. I wish it were otherwise for many reasons. John Cochrane |
#24
On Dec 14, 9:51*am, "John Godfrey (QT)"
wrote: http://www.ssa.org/files/member/2010...e%20Meeting%20... John Godfrey (QT) Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA |
#25
On Dec 16, 3:48*pm, Frank wrote:
On Dec 14, 9:51*am, "John Godfrey (QT)" wrote: http://www.ssa.org/files/member/2010...e%20Meeting%20... John Godfrey (QT) Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA If I recall correctly this is a recurring topic of where to set max distance points versus min speed points. It was polled again this year. You may remember a rule change a few years ago increased max distance points to 600 from 400 so that an outlanding was less likely to mean the end of your contest. The result was that speed points became compressed because finishers frequently post speeds that are less than 60% of the winners speed. The 2011 change allows competitors who fly long tasks but just miss getting home to score more points than competitors who fly the shortest possible task just to get home. It changes the long-held philosophy that every speed finisher should get more points than any landout. It will primarily apply in cases where there were exceptionally long landout flights along with significantly under time finishers. I think I got that right. 9B |
#26
![]() Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA Take a look at the poll, question 4, which tries to explain it all compactly. http://www.ssa.org/files/member/2010...%20Results.pdf Come back if that isn't clear John Cochrane |
#27
On Dec 16, 5:38*pm, John Cochrane
wrote: Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA Take a look at the poll, question 4, which tries to explain it all compactly. http://www.ssa.org/files/member/2010...inion%20Poll%2... Come back if that isn't clear John Cochrane There is a scenario I can't quite figure under the new rule. Say ALL the finishers are MT15 and very short distances but a bunch of pilots were able to rack up long distances but not get home. This can happen with big weather systems moving through. The choice you have is stay close to home so you can finish and risk a short flight or follow the good conditions on the chance that you'll be able to get back home later. I think under the new rules you might make the bet that none of the long flights finish, but if even one of them succeeds it radically changes the scoresheet because all the short finishers see their scores cut down dramatically as BESTDIST goes dramatically up. Also all the long non-finishers would see their scores go up if even one of them gets home. It also potentially gets tangled up in devaluation depending on the ratios. I guess versus the old system it gives you some additional incentive to be the hero and get around on a long flight even in dicey conditions. Any insights? 9B |
#28
On Dec 16, 8:19*pm, Andy wrote:
On Dec 16, 3:48*pm, Frank wrote: On Dec 14, 9:51*am, "John Godfrey (QT)" wrote: http://www.ssa.org/files/member/2010...e%20Meeting%20.... John Godfrey (QT) Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA If I recall correctly this is a recurring topic of where to set max distance points versus min speed points. *It was polled again this year. You may remember a rule change a few years ago increased max distance points to 600 from 400 so that an outlanding was less likely to mean the end of your contest. The result was that speed points became compressed because finishers frequently post speeds that are less than 60% of the winners speed. The 2011 change allows competitors who fly long tasks but just miss getting home to score more points than competitors who fly the shortest possible task just to get home. It changes the long-held philosophy that every speed finisher should get more points than any landout. It will primarily apply in cases where there were exceptionally long landout flights along with significantly under time finishers. I think I got that right. 9B Yes, that's what I understand too. However, I haven't heard any details about exactly how the scoring would be changed - i.e. how the current scoring formulas for MDP (Max Distance Points), MSP (Max Speed Points), "Points for Finishers" and "Points for Non-Finishers" would be modified. Stating the philosophy is one thing, but the devil is in the details (and the unintended consequences, whatever they turn out to be ;-). Just my luck that I'm giving a talk on the nuances of the U.S. contest scoring rules, and there is a potentially game-changer looming on the horizon ;-). TA TA |
#29
On Dec 14, 11:03*am, John Cochrane
wrote: Can someone please explain the intent of this: "Rule change to add provision for restricted water to allow ballasting of all gliders up to the weight of the heaviest unballasted glider, in addition to current provision that allows no ballast. For a no-ballast day, the rule is unchanged. “No water contest rules” will not be changed – tail water is the only ballast allowed." Under what circumstances, contest type, class etc, is ballasting to the weight of the heaviest unballasted glider to be allowed? Why does the new rule apply to weight rather than wing loading? thanks Andy This addresses a situation such as Cesar Creek, where full ballast could not be used because of a soft field. However, some pilots had a lot of iron (motors) in the back, giving them a perceived wingloading advantage. So now, everyone can ballast to the same weight as the motorgliders. If it's safe to tow the motorgliders, it's safe to tow everyone at their weight. Newcastle or Parowan might want to do the same thing. Why weight rather than wingloading? Simplicity. Imagine the chaos if we have to find the highest wingloading mortorglider, then everyone else has to figure out how much ballast puts them at the same wingloading, then the scales guy has to verify they did the computation right. Weight is much easier, and we felt the difference in wing area of modern gliders is small enough that the resultant advantage to smaller wing area gliders is not worth worrying about. (And 3/5 of the rules committee flies Schleicher gliders... No, just kidding) The conventional no-ballast rules are still an option. For example, if no water is available, or if there is no time to give everyone a fair chance to water, weigh, and grid, then the CD can call conventional no- ballast rules. Fairness is also a consideration. If it's a clearly marginal 1 knot day and there are other reasons for wanting to limit water (Mifflin, a pain to get the fire trucks out) that argues for no-ballast rules. If it's booming but takeoff or runway considerations are limiting water, that argues for the water-to-same-gross rules. Bottom line, now CDs have two options for limiting water: 1) They can say "everyone can water up to XXX gross weight only" and 2) conventional no-water rules. Which to use depends on the circumstance, safety, fairness, etc. etc. I can see we're in for some interesting pilot meetings.... John Cochrane No water rule is US new wheel invention. If the airport is not safe(soft field ect.) , we should not fly or wait. If there is no water in the field we can bring our own water (Mifflin) If somebody didn't put his glider in the morning together and fill it with water(it was raining) , it is his problem. If was raining after morning briefing we should have no tape day. Same if somebody forgot to charge his battery. Can we make no battery day ?Maybe was no power at the airport last night.Some time ago I did check ride in Estrela and I got really ****ed (they had no airbrake rules),Can I use slip, NO was the respond.Took me 3 trays to stop+/- 50ft from my waiting son. Or maybe some of us are too old for all this hassle ? OK, we have a team ![]() rules. Water rule is aimed against Diana 2 and future Duckhawk fliers. Who is afraid ? Ryszard Before last Grand Prix in Chile there was protest against Diana 2 fliers having bigger wing loading.Both Diana fliers had to reduce water ballast, but it did not help. |
#30
On Dec 16, 6:39*pm, Frank wrote:
On Dec 16, 8:19*pm, Andy wrote: On Dec 16, 3:48*pm, Frank wrote: On Dec 14, 9:51*am, "John Godfrey (QT)" wrote: http://www.ssa.org/files/member/2010...e%20Meeting%20... John Godfrey (QT) Anyone care to provide a good explanation of the new 'long landout vs early finisher' scoring rule? TA If I recall correctly this is a recurring topic of where to set max distance points versus min speed points. *It was polled again this year. You may remember a rule change a few years ago increased max distance points to 600 from 400 so that an outlanding was less likely to mean the end of your contest. The result was that speed points became compressed because finishers frequently post speeds that are less than 60% of the winners speed. The 2011 change allows competitors who fly long tasks but just miss getting home to score more points than competitors who fly the shortest possible task just to get home. It changes the long-held philosophy that every speed finisher should get more points than any landout. It will primarily apply in cases where there were exceptionally long landout flights along with significantly under time finishers. I think I got that right. 9B Yes, that's what I understand too. *However, I haven't heard any details about exactly how the scoring would be changed - i.e. how the current scoring formulas for MDP (Max Distance Points), MSP (Max Speed Points), "Points for Finishers" and "Points for Non-Finishers" would be modified. *Stating the philosophy is one thing, but the devil is in the details (and the unintended consequences, whatever they turn out to be ;-). Just my luck that I'm giving a talk on the nuances of the U.S. contest scoring rules, and there is a potentially game-changer looming on the horizon ;-). TA TA The specific formula change is described in the pilot poll. 9B |
Proposed US Competition Rules Changes for 2010 | [email protected] | Soaring | 1 | December 17th 09 05:20 PM |
SSA Competition Rules Meeting Minutes | [email protected] | Soaring | 3 | December 4th 09 08:04 PM |
US Competition Rules Poll and Committee Election | [email protected] | Soaring | 6 | October 13th 09 01:37 PM |
SSA Competition Rules Committee Nominations and Poll | [email protected] | Soaring | 0 | June 3rd 09 02:16 PM |
2005 SSA Rules Committee Meeting Minutes Posted | Ken Kochanski (KK) | Soaring | 1 | December 20th 05 05:38 PM |
