USA 2010 Competition Rules Committee Minutes Posted
Old December 14th 10, 02:51 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
Default USA 2010 Competition Rules Committee Minutes Posted
http://www.ssa.org/files/member/2010...%20Minutes.pdf
John Godfrey (QT)
Old December 14th 10, 03:46 PM posted to rec.aviation.soaring
Andy[_1_]
On Dec 14, 7:51*am, "John Godfrey (QT)"
http://www.ssa.org/files/member/2010...e%20Meeting%20...
John Godfrey (QT)
Can someone please explain the intent of this:
"Rule change to add provision for restricted water to allow ballasting
of all gliders up to the
weight of the heaviest unballasted glider, in addition to current
provision that allows no ballast.
For a no-ballast day, the rule is unchanged.
“No water contest rules” will not be changed – tail water is the only
ballast allowed."
Under what circumstances, contest type, class etc, is ballasting to
the weight of the heaviest unballasted glider to be allowed?
Why does the new rule apply to weight rather than wing loading?
thanks
Andy
Old December 14th 10, 04:03 PM posted to rec.aviation.soaring
John Cochrane[_2_]
ballast allowed."
thanks
Andy
This addresses a situation such as Cesar Creek, where full ballast
could not be used because of a soft field. However, some pilots had a
lot of iron (motors) in the back, giving them a perceived wingloading
advantage. So now, everyone can ballast to the same weight as the
motorgliders. If it's safe to tow the motorgliders, it's safe to tow
everyone at their weight. Newcastle or Parowan might want to do the
same thing.
Why weight rather than wingloading? Simplicity. Imagine the chaos if
we have to find the highest wingloading mortorglider, then everyone
else has to figure out how much ballast puts them at the same
wingloading, then the scales guy has to verify they did the
computation right. Weight is much easier, and we felt the difference
in wing area of modern gliders is small enough that the resultant
advantage to smaller wing area gliders is not worth worrying about.
(And 3/5 of the rules committee flies Schleicher gliders... No, just
kidding)
The conventional no-ballast rules are still an option. For example, if
no water is available, or if there is no time to give everyone a fair
chance to water, weigh, and grid, then the CD can call conventional no-
ballast rules.
Fairness is also a consideration. If it's a clearly marginal 1 knot
day and there are other reasons for wanting to limit water (Mifflin, a
pain to get the fire trucks out) that argues for no-ballast rules. If
it's booming but takeoff or runway considerations are limiting water,
that argues for the water-to-same-gross rules.
Bottom line, now CDs have two options for limiting water: 1) They can
say "everyone can water up to XXX gross weight only" and 2)
conventional no-water rules. Which to use depends on the circumstance,
safety, fairness, etc. etc.
I can see we're in for some interesting pilot meetings....
John Cochrane
Old December 14th 10, 04:26 PM posted to rec.aviation.soaring
Mike the Strike
On Dec 14, 9:03*am, John Cochrane
ballast allowed."
thanks
Andy
same thing.
kidding)
ballast rules.
John Cochrane
So the committee feels that motorgliders have no advantage over
conventional sailplanes when they have the same wing loading?
Would you line a ten-minute argument or the whole half-hour?
Old December 14th 10, 04:37 PM posted to rec.aviation.soaring
John Cochrane[_2_]
Calm down now, that's not what we said. All we did is address a
wingloading advantage on no-ballast days. This is only about how to
apply no ballast rules. It's not a deep statement on the whole vexing
motorglider question.
John Cochrane
Old December 14th 10, 04:44 PM posted to rec.aviation.soaring
Andy[_1_]
ballast allowed."
thanks
Andy
same thing.
kidding)
ballast rules.
John Cochrane- Hide quoted text -
- Show quoted text -
Thanks for the quick reply John. The "ballast to the same weight"
concept seems to be unfair to Std class gliders flying FAI class rules
with a combined Std and 15M contest. While most modern Std gliders
may have similar wing area, and most modern 15m gliders may have
similar wing areas, there is a very distinct difference between Std
and 15M wing areas.
Would it not be reasonable to have every pilot declare their
unballasted wing loading at contest entry. Each pilot could then
calculate, before the contest started, what ballast was required to
reach the loading of the highest wing loading entrant. It would only
take me a minute or two to fire up the laptop and open the W/B
spreadsheet to get that data.
If that's too complicated then, in the case of a combined Std and 15M
class, the Standard should be assigned a max takeoff weight that is
adjusted by the ratio of typical Std and typical 15m wing areas.
ASW-28 wing area 10.5, ASG-29-15 9.2 (area in square metres) so
adjustment factor 1.14?
Andy
Old December 15th 10, 12:41 AM posted to rec.aviation.soaring
Kevin Christner
ballast allowed."
thanks
Andy
same thing.
kidding)
ballast rules.
Thanks for the quick reply John. *The "ballast to the same weight"
with a combined Std and 15M contest. *While most modern Std gliders
and 15M wing areas.
unballasted wing loading at contest entry. *Each pilot could then
reach the loading of the highest wing loading entrant. *It would only
class, *the Standard should be assigned a max takeoff weight that is
adjusted by the ratio of *typical Std and typical 15m wing areas.
ASW-28 wing area 10.5, ASG-29-15 *9.2 (area in square metres) so
Andy
Conversely if you are flying a 15m ship in an 18m contest you could be
at an advantage. Should the 15m ships have an adjustment factor as
well?
2C
Old December 15th 10, 03:03 AM posted to rec.aviation.soaring
ballast allowed."
thanks
Andy
same thing.
kidding)
ballast rules.
and 15M wing areas.
Andy
at an advantage. *Should the 15m ships have an adjustment factor as
well?
2C- Hide quoted text -
Or go to to the contemplated combined handicap class and don't worry
about it.
UH
Old December 15th 10, 08:22 PM posted to rec.aviation.soaring
Andy[_10_]
ballast allowed."
thanks
Andy
same thing.
kidding)
ballast rules.
and 15M wing areas.
Andy
How about allowing more ballast for older generation glass ships up
until their handicap under Sports Class rules is equalized? This would
turn handicapping on it's head - use ballast to equalize performance
rather than adjusting scores after the fact. Of course that would make
for one heavy Libelle.
I'm kidding.
This does show the challenge the RC faces in responding to the calls
for simple rules versus the calls for fairness. No water contests do
confer some advantage on heavy motorgliders with heavy pilots. The RC
proposal seems like a decent attempt at closing most of that gap. I'm
not sure that equalizing wing loading is an improvement since gliders
all have inherently different wing loading ranges by design. Plus
older gliders with really large wing areas could get pretty heavy -
which might undermine the original intent behind restricting takeoff
weight at certain airfields.
9B
Old December 15th 10, 09:46 PM posted to rec.aviation.soaring
Andy[_10_]
I thought the "start anywhere" rule was going to revert back to the
original version by eliminating the "front half" of the cylinder
provision that was added for 2010. What happened?
Also, under advanced handicap class rules that allow water will the
handicaps vary with the ballasted weight or just use the unballasted
weights for setting handicaps?
9B
Proposed US Competition Rules Changes for 2010 [email protected] Soaring 1 December 17th 09 05:20 PM
SSA Competition Rules Meeting Minutes [email protected] Soaring 3 December 4th 09 08:04 PM
US Competition Rules Poll and Committee Election [email protected] Soaring 6 October 13th 09 01:37 PM
SSA Competition Rules Committee Nominations and Poll [email protected] Soaring 0 June 3rd 09 02:16 PM
2005 SSA Rules Committee Meeting Minutes Posted Ken Kochanski (KK) Soaring 1 December 20th 05 05:38 PM
