ASK 21 spin testing
Old January 26th 11, 06:09 PM posted to rec.aviation.soaring
Pete Startup[_2_]
Default ASK 21 spin testing
Accession Number : ADA213513 - a spin test report carried out by the guys
at Edwards.
Can any of you guys Stateside point me in the direction of this report?
Says it's Approved for Public Release but I can't find a link that
works.
Cheers in advance.
Old January 27th 11, 12:12 AM posted to rec.aviation.soaring
Tim Taylor
at Edwards.
works.
Cheers in advance.
My search shows that there is no electronic version available at this
time. The NTIS (http://www.ntis.gov/search/index.aspx) has it at
$40.00 Microfiche and
$60.00-Print on Demand. Would likely cost a little extra for overseas
shipping.
Accession Number:
ADA213513
Full Text (pdf) Availability:
Handle / proxy Url: No Full Text PDF Available
Citation Status:
A - Active
Title:
Schleicher ASK - 21 Glider (TG-9) Stall and Spin.
Fields and Groups :
010100 - Aerodynamics
010306 - Training Aircraft
010308 - Gliders and Parachutes
Corporate Author:
AIR FORCE FLIGHT TEST CENTER EDWARDS AFB CA
Personal Author(s):
Janzen, Doyle B
Precourt, Charles J
Report Date:
Jul 1989
Media Count:
129 Pages(s)
Organization Type:
F - AIR FORCE
Report Number(s):
AFFTC-TR-89-27 (AFFTCTR8927)
Descriptive Note:
Final rept.,
Abstract:
This report documents the results of the Schleicher ASK- 21
Glider (TG-9) Stall and Spin Evaluation. Testing included evaluation
of the departure and spin susceptibility of the aircraft as a function
of weight and cg, definition of spin modes and modes characteristics
as well as the control effects on those modes. Stall and spin flight
tests of the ASK-21 were conducted between 27 April and 31 May 1989 at
the Air Force Flight Test Center (AFFTC), Edwards AFB, California.
Keywords: Flight testing; Gliders; Sailplanes; Stalls; Spin weight
ballast; Training aircraft. (SDW).
Distribution Limitation(s):
01 - APPROVED FOR PUBLIC RELEASE
Source Serial:
F
Source Code:
012100
Document Location:
1 - DTIC AND NTIS
Geopolitical Code:
0618
SBI Holding Symbol:
TRAL NWC ATLF TAV
Old January 27th 11, 12:16 AM posted to rec.aviation.soaring
T[_2_]
at Edwards.
works.
Cheers in advance.
I just sent a note off to some TPS Grads.. we'll see what they come up
with.
The report was most likely completed by the Test Pilot School.
T
Old January 30th 11, 08:41 PM posted to rec.aviation.soaring
Derek C
at Edwards.
works.
Cheers in advance.
I can give some practical advice after years of instructing in K21s.
They will spin only towards the bottom end of the front cockpit weight
range, or if tail ballast is fitted. Only stick hard back with full
rudder will promote a spin, and it recovers as soon as you move the
stick forward. With heavier front seat pilots, or no tail ballast, it
will only drop a wing and then go into a gentle spiral dive that can
be recovered by normal control inputs. Although I have not tried it
for airspace reasons, I understand that it will spin quite well above
10,000ft altitude.
Derek C
Old January 30th 11, 10:26 PM posted to rec.aviation.soaring
T[_2_]
at Edwards.
works.
Cheers in advance.
with.
T
I have a copy of the report and forwarded to the OP. Is there a
public place to post it?
I'll try to get it up on our clubs web page soon.
T
Old January 30th 11, 11:26 PM posted to rec.aviation.soaring
Andreas Maurer
Hi T,
I'd be very glad if you could forward this report to me, too.
Best wishes
Andreas
Old January 30th 11, 11:34 PM posted to rec.aviation.soaring
John Smith
A couple of years ago, I asked the Schleicher factory whether they had a
copy. They were happy to send me one for a few euros.
Old January 30th 11, 11:53 PM posted to rec.aviation.soaring
Andreas Maurer
On Mon, 31 Jan 2011 00:34:54 +0100, John Smith
Ah... I have to admit that I haven't even thought of asking them!
Since I'll be talking to Schleicher's Gregor Heller soon (in order to
renew the yearly permit to fly of the AS 22-2 - what a pain in the ***
if your glider doesn't have a type certificate in Germany!) I'll ask
him about the report - thx for the hint!
Regards
Andreas
Old January 31st 11, 01:32 AM posted to rec.aviation.soaring
vaughn[_3_]
"T" wrote in message
If nothing else, you can load it to a free archive site like
http://www.mediafire.com/ and then post a link to it.
Vaughn
Old February 1st 11, 12:16 AM posted to rec.aviation.soaring
T[_2_]
I have a copy of the report and forwarded to the OP. *Is there a
If nothing else, you can load it to a free archive site likehttp://www.mediafire.com/and then post a link to it.
Vaughn
http://www.mediafire.com/?2syzfyjbq0k7nah
USAF Test Pilot School ASK-21 Spin Test Report
It's Da' Spin,Boss! Da' Spin! [email protected] Home Built 8 November 19th 08 10:28 PM
Stall/ Spin testing the RV-12 cavelamb himself[_4_] Home Built 3 May 14th 08 07:01 PM
Testing the Testing of Mogas Jay Honeck Piloting 22 July 24th 06 09:38 PM
How Low to Spin?? Paul M. Cordell Soaring 180 September 14th 04 07:17 PM
Spin Toks Desalu Piloting 43 May 11th 04 01:04 PM
