Hi all,
I'm currently doing a project on gliders designed within the last ten years and one of the crucial aspects is knowing the mean camber profile for various lift coefficient calculations. I was wondering whether a) Any modern gliders are using NACA type airfoils? b) Whether anyone knows what the parabolic equation of the ASG-29 profile? Any other suggestions would be greatly appreciated! Thanks |
On Tue, 8 Feb 2011 09:44:45 +0000, JJ21
wrote: a) Any modern gliders are using NACA type airfoils? Nope... I'd estimate since at least 50 years... b) Whether anyone knows what the parabolic equation of the ASG-29 profile? If you men the parabolic equation that defines the camber and thickness distribution of NACA airfoil: Laminar airfoils that are used on gliders don't use parabolic equations - their shape is defined by calculating the shape based upon pressure distribution. Regards Andreas |
On Feb 8, 1:44*am, JJ21 wrote:
Hi all, I'm currently doing a project on gliders designed within the last ten years and one of the crucial aspects is knowing the mean camber profile for various lift coefficient calculations. I was wondering whether a) Any modern gliders are using NACA type airfoils? b) Whether anyone knows what the parabolic equation of the ASG-29 profile? Any other suggestions would be greatly appreciated! Thanks -- JJ21 http://www.sailplanedirectory.com lists the airfoil used for SOME gliders. Some of those airfoil sections can be found he http://www.ae.illinois.edu/m-selig/a..._database.html |
By "parabolic equation", perhaps the OP means the polar calculation
points? Parabolic is synonymous with quadratic, which is what we use to approximate our polars for the computers. |
On Feb 8, 4:44*am, JJ21 wrote:
Hi all, I'm currently doing a project on gliders designed within the last ten years and one of the crucial aspects is knowing the mean camber profile for various lift coefficient calculations. I was wondering whether a) Any modern gliders are using NACA type airfoils? b) Whether anyone knows what the parabolic equation of the ASG-29 profile? Any other suggestions would be greatly appreciated! Thanks -- JJ21 Airfoil is DU89-134/14. Coordinates are not available to my knowledge. I'd like to be proven wrong on that. UH |
Quote:
I can't really think of any other way of calculating the lift coefficient of an airfoil theoretically. |
coefficient of an airfoil theoretically. A lot of good people have found more straightforward ways to compute the lift coefficient, which is in fact very easy to calculate. The maximum lift coefficient, the drag coefficient, the pitching moment coefficient are the hard ones. Perhaps you could consult a standard textbook on glider aerodynamics, e.g. Prof. Fred Thomas "Handbook of Sailplane Design". |
At 00:28 10 February 2011, Francisco De Almeida wrote:
I can't really think of any other way of calculating the lift coefficient of an airfoil theoretically. A lot of good people have found more straightforward ways to compute the lift coefficient, which is in fact very easy to calculate. The maximum lift coefficient, the drag coefficient, the pitching moment coefficient are the hard ones. Perhaps you could consult a standard textbook on glider aerodynamics, e.g. Prof. Fred Thomas "Handbook of Sailplane Design". If you have the aerofoil profile, then Xfoil (freeware from a very respected aerodynamicist) will give you a reasonable 1st guess at all of these for 2D flow. XFLR5 extends Xfoil to 3D wings (originally intended for RC gliders, but should probably* be OK for full-scale sailplanes). Using Fourier coefficients to calculate 2D (or 3D wing) characteristics, is a real throw-back to the 50's - useful in a textbook derivation to give an analytical solution, but no-one does it any more. Doug *usual caveats apply - these are not guaranteed to give the right answer, so use with caution! |
| Best Looking Sailplane | glider[_2_] | Soaring | 52 | November 23rd 09 05:29 PM |
| Could this be used in a sailplane? | Spam | Soaring | 6 | July 5th 09 09:16 PM |
| Another Sailplane | Ben Jeffrey | Aviation Photos | 2 | June 24th 08 09:11 PM |
| Digital airspace data question -- any FAA data gurus out there? | Tuno | Piloting | 2 | December 27th 07 06:06 PM |
| Flight Data recorders on a 757 - What data? | Al Dykes | General Aviation | 0 | January 1st 07 06:09 PM |
