Sailplane data
Old February 8th 11, 04:03 PM posted to rec.aviation.soaring
jsbrake[_2_]
Default Sailplane data
By "parabolic equation", perhaps the OP means the polar calculation
points? Parabolic is synonymous with quadratic, which is what we use
to approximate our polars for the computers.
Old February 9th 11, 07:34 PM
JJ21 JJ21 is offline
Junior Member
First recorded activity by AviationBanter: Feb 2011
Pretty much looking for a quadratic which can be used to calculate the lift coefficient theoretically using Fourier coefficients.
I can't really think of any other way of calculating the lift coefficient of an airfoil theoretically.
Old February 10th 11, 12:28 AM posted to rec.aviation.soaring
Francisco De Almeida[_2_]
A lot of good people have found more straightforward ways to compute the
lift coefficient, which is in fact very easy to calculate. The maximum
lift coefficient, the drag coefficient, the pitching moment coefficient
are the hard ones.
Perhaps you could consult a standard textbook on glider aerodynamics, e.g.
Prof. Fred Thomas "Handbook of Sailplane Design".
Old February 10th 11, 10:47 AM posted to rec.aviation.soaring
Doug Greenwell
are the hard ones.
e.g.
If you have the aerofoil profile, then Xfoil (freeware from a very
respected aerodynamicist) will give you a reasonable 1st guess at all of
these for 2D flow. XFLR5 extends Xfoil to 3D wings (originally intended
for RC gliders, but should probably* be OK for full-scale sailplanes).
Using Fourier coefficients to calculate 2D (or 3D wing) characteristics,
is a real throw-back to the 50's - useful in a textbook derivation to
give an analytical solution, but no-one does it any more.
Doug
*usual caveats apply - these are not guaranteed to give the right answer,
so use with caution!
Best Looking Sailplane glider[_2_] Soaring 52 November 23rd 09 04:29 PM
Could this be used in a sailplane? Spam Soaring 6 July 5th 09 08:16 PM
Another Sailplane Ben Jeffrey Aviation Photos 2 June 24th 08 08:11 PM
Digital airspace data question -- any FAA data gurus out there? Tuno Piloting 2 December 27th 07 05:06 PM
Flight Data recorders on a 757 - What data? Al Dykes General Aviation 0 January 1st 07 05:09 PM
