#21
@Andy: I saw a large difference before and after connecting the SN10,
that's good enough for me. One of the things I checked after connecting the SN10 was the data stream using SYM's terminal feature. Observed all the normal NMEA sentences plus the SN10's $PILC sentences. Andres will have to answer to whether/how the Oudie's GPS is optimized for aviation, it's immaterial at this point. |
On Apr 3, 9:52*pm, "Paul Remde" wrote:
Hi Bill, Be sure your SN10 has the latest software. *Also, in SeeYou Mobile, go to the Hardware screen and select SN10 as the hardware type. Best Regards, Paul Remde Cumulus Soaring, Inc. "William Elliott" wrote in message ... On Apr 2, 11:51 am, "Paul Remde" wrote: Hi Dan, The advantage to connecting the Oudie to the SN10 is that the SN10 (assuming it has somewhat current software) can send vario and wind data to the Oudie. The Oudie's "Thermal Assistant" really only works well with real-time vario data. And since the SN10 has airspeed sensors and GPS data, it can calculate accurate wind speed and direction when cruising - not just when circling as the Oudie can do with GPS data alone. Being able to calculate the wind while cruising is very important when ridge or wave flying. If you also connect the Oudie to the VL, then you can have the Oudie send official task declarations to the VL and you can download secure flight logs from the VL. Best Regards, Paul Remde Cumulus Soaring, Inc. "Dan" wrote in message ... On Apr 1, 11:31 am, "Paul Remde" wrote: Hi Ted, The Oudie's power/data cable is supplied with an RJ45 to DB-9m adapter which can be configured for connection to our standard Goddard SN10/PDA wiring harnesses. I would setup the adapter exactly the same as if it was being connected to a Cambridge 302 or Goddard PS-5a power converter. You can see the connections for that hehttp://www.cumulus-soaring.com/seeyo...udie-Cable-Kit I sell standard wiring harnesses for the SN10 for several GPS types - with PDA connections.http://www.cumulus-soaring.com/goddard.htm If you want to modify your existing wiring harness, you'll need the SN10 manual - which is available hehttp://www.ilec-gmbh.com/manuals.htm Best Regards, Paul Remde Cumulus Soaring, Inc. "Tuno" wrote in message .... Later today or tomorrow I'm going to be searching the 'Net for a how- to on this, but until then if anyone has a link to help with, I'll check here first. Advance thanks ted/2N7O- Hide quoted text - - Show quoted text - what are the advantages to conneting an SN-10b to an Oudie? I have both but kept my Volkslogger connected to the SN-10b and run the Oudie by itself, just replaced the iPAQ. It was very easy to pick up the power for the Oudie from the VL power source. Can't wait to use the Oudie in my glider, it works great in my powerplane. Dan WO I have not had good luck getting the SN-10 data working in the Oudie. I get the GPS data from the SN-10 just fine. *Has anyone else had success getting the wind and vario data working properly in the Oudie with SYM? WE I do have the latest software and I have selected SN-10 as the hardware type. When I do this, the flight statistics page showing the last four climbs is never correct. It doesn't matter how I have this hardware setting. When I switch back to receiving a direct feed from the Colibri (or the Flarm I was using last summer), the flight statistics page is better but still not correct. I am not convinced that the SN-10 and SYM are sending/receiving what they expect. Have spoken to both Nadler and Andrej about this but neither seem to understand there is a problem. The reason I am asking RAS folks is to find out if I am the only one having a problem or if other are too. WE |
Bill: I'll check this on my combination next time I fly.
On your SYM, when you use the terminal feature while connected to the SN10, do you see $PILC sentences? Definitely check for that first. tuN7o |
At 19:30 04 April 2011, Brad wrote:
On Apr 4, 10:37=A0am, Andy wrote: On Apr 4, 10:21=A0am, Tuno wrote: Good question wrt the GPS quality. How is a receiver optimized for aviation? But I do think the air data makes a huge difference in wind and glide calculations. Without it, SYM and the SN10 provided varying answers on the steering to target; with the airdata, they always matched. I'd be convinced if you disabled the SN10 GPS feed and saw the same results. Or are you saying the SN-10 is feeding only airdata to the Oudie and not GPS position data. PNA GPS receivers are typically optimized for car navigation. =A0One result is that they like to say they are going straight even if the host vehicle is turning. =A0Ok it's not the GPS receiver itself but the associated data processing and in some devices, such as the HP310, no one has yet found a way to hack it so it works properly. Andy Andy, I've been told, and I hope it's correct, that sending a GPS signal to the 310 will give better results. I will be using a Powerflarm to send the 310 data and by-pass the internal GPS. It is a simple setting in the LK8000 software for a com port and baud rate setting. Brad There is quite a lot about the iPAQ 31* series problem on the LK8000 forum. The internal gps is almost useless for gliding. I use a Holux bt gps with mine as Device A, and if it ever loses that, it never has, it will default to Device B, the internal. Been trying for some time to connect the SN10B to the iPAQ 314, as soon as one problem is solved, another raises it's head, but I think I know what to do now thanks to Dave N and Paul R. Dave |
| Thread Tools | |
| Display Modes | |
| Oudie Pilot Reports? | AY | Soaring | 6 | December 13th 10 12:51 AM |
| Oudie - ConnectMe question | kinsell@pobox.com | Soaring | 9 | August 9th 10 05:18 PM |
| Oudie with a LX 5000 | Randy[_2_] | Soaring | 2 | May 24th 10 11:48 AM |
| New Oudie Photos | Paul Remde | Soaring | 3 | April 30th 10 05:17 PM |
