Electronic total energy vario
Old July 19th 11, 12:01 AM posted to rec.aviation.soaring
kd6veb
Default Electronic total energy vario
Hi Gang
The electronic TE vario should be possible to implement with modern
electronics today. I have googled this item but have not been able to
find one. Maybe it doesn't exist for whatever reasons. It would sure
simplify some of the complex TE probe systems that stick out of the
empennages of many gliders. Any ideas or thoughts?
Dave
Old July 19th 11, 12:30 AM posted to rec.aviation.soaring
guy
There are many choices for electronic TE varios. Most are just about
any of the common flight computer vario systems. I fly with a
Cambridge 302 that is configured for electronic compensation. I have
only my mechanical vario on the TE probe. That way I have two
independent systems. The Cambridge 302 with electronic compensation
works very well for me.
Guy "DDS"
Old July 19th 11, 12:44 AM posted to rec.aviation.soaring
66
On Jul 18, 6:01*pm, kd6veb wrote:
Hi Gang
*The electronic TE vario should be possible to implement with modern
Dave
Try the Cambridge 302, Westerboer VW911, LX4000, to name a few.
Electronic TE has been around for a long time.
Kirk
66
Old July 19th 11, 12:48 AM posted to rec.aviation.soaring
Tony V
On 7/18/2011 7:01 PM, kd6veb wrote:
Hi Gang
Dave
The Cambridge 302 (and I'm sure many others) will do that. see the
manual http://www.cambridge-aero.com/manuals/302_v2.pdf , section 2.2.4.
Tony
Old July 19th 11, 01:31 AM posted to rec.aviation.soaring
Mike[_37_]
On Jul 18, 5:01*pm, kd6veb wrote:
Hi Gang
Dave
Hi Dave,
The Westerboer 1020 is the latest full featured electronic total
energy vario from Westerboer- Great vario.
Mike
Old July 19th 11, 01:35 AM posted to rec.aviation.soaring
Bill D
Hi Gang
Dave
I don't think Dave is asking about the 302 since it uses a TE probe.
What I think he's asking about is doing the TE calculation in real-
time in silicon using just the airspeed and altitude data from pitot
and static ports. AFAIK, no variometer has ever taken this approach.
I've wondered about this too since it would do away with almost all
the special variometer plumbing as well as the probe. It would also
eliminate a lot of pneumatic artifacts.
Bill Daniels
Old July 19th 11, 01:51 AM posted to rec.aviation.soaring
Westbender
Hi Gang
Dave
and static ports. *AFAIK, no variometer has ever taken this approach.
the special variometer plumbing as well as the probe. *It would also
Bill Daniels
The 302 does not require a TE probe. You can connect the static port
to both the static and TE connections on the 302 and use pure
electronic TE compensation. The 302 was designed to do this very thing
as specified in the documentation.
Old July 19th 11, 03:59 AM posted to rec.aviation.soaring
Hagbard Celine
It can be done and it can work quite well. My glider has no TE probe
and is equipped with an old Peschges VP4E NAV vario which is set up
for electronic compensation. In order for electronic TE to work
properly though the pitot and static systems installation must have
little to no inherent error. Not all glider designs meet this
criteria. If you go back and look at the Johnson flight tests in
Soaring magazine you'll find that quite a few gliders have large
errors in the static system which can put the airspeed indication
several knots out (dig up the article on the Standard Cirrus for a
good example of this).
Old July 19th 11, 04:34 AM posted to rec.aviation.soaring
Bill D
If the position error is known, why can't the vario computer use a
"lookup table' to produce calibrated airspeed?
Old July 19th 11, 04:48 AM posted to rec.aviation.soaring
mike
Bill,
On the current Westerboer, tweaks can be simply done (manually), to
get the correct total energy. Probably on others also. The 1020 works/
worked well in both a RS-15 and Mini Nimbus- both with questionable
static locations.
Mike
Way to go Joe! (energy advances) Duane Ritter Piloting 0 March 26th 11 09:41 PM
Diafragm type total energy compensator JC Soaring 3 March 1st 11 12:51 AM
Total energy probe orientation? John Bojack[_2_] Soaring 4 June 5th 09 02:33 PM
WTB: Sage Model B Netto Total Energy Box November Bravo Soaring 0 March 15th 05 03:10 PM
varios not using a total energy probe Robert Soaring 20 April 25th 04 11:24 PM
