Using the newer esa probe, model DN/3-fach/UN, with the two "prongs".
Does the orientation matter, and if so, which way is correct? Horizontal or up/down? Thanks. also, comedic replies not needed. J4 |
On Jun 4, 7:15*pm, "John Bojack" wrote:
Using the newer esa probe, model DN/3-fach/UN, with the two "prongs". Does the orientation matter, and if so, which way is correct? * Horizontal or up/down? Thanks. also, comedic replies not needed. J4 Since the marketing hype for this type of probe is about insensitivity to angle of attack changes I would presume you are supposed to use them vertically so AoA changes on both TE prongs balances each others. Presumably the reason for not putting the TE prong horizontal (includign on a single prong conventional TE probe) is sensitivity to slip/skid angle. That and it would look dawky. I suspect more likely this is an example of a solution looking for a problem. Try taping over one of the TE ports at a time and let us all know if it was worth spending the extra money on. Darryl |
Received this reply:
Hello John, the correct way is horizontal. you can also positon up and down but it is not the best way! have a good time and always strong thermals! mit freundlichen Grüßen kind regards Erwin Salzinger esa-systems Wilmeresch58 D-48565 Steinfurt Tel.:+49(0)2551 996659 Fax: +49(0)2551 996664 mobil: 01749998326 www.esa-systems.com |
The idea is to make it insensitive to "uncoordinated" flight. I've never flown that probe myself, but I've heard good critics from other pilots. |
Most interesting! What about the model with the single prong? (Model
MNI/UN?) |
CAP Orientation Pilot? | Robert M. Gary | Piloting | 7 | August 3rd 05 02:22 AM |
WTB: Sage Model B Netto Total Energy Box | November Bravo | Soaring | 0 | March 15th 05 03:10 PM |
Pilot's Political Orientation | Chicken Bone | Instrument Flight Rules | 317 | June 21st 04 06:10 PM |
Pilot's Political Orientation | Chicken Bone | Owning | 314 | June 21st 04 06:10 PM |
varios not using a total energy probe | Robert | Soaring | 20 | April 25th 04 11:24 PM |
