The file mentioned in my prior post is: cai4olc.zip and came be
downloaded via a link on the Geelong Gliding Club website http://www.gliding-in-melbourne.org thanks to Jeff Farrow. |
It appears that our only option is to keep resubmitting the same file
until it validates successfully. If that truly does work, then it's obvious that the problem is in the OLC validator software. Once I have a track record of proof, I'll contact the OLC folks again and try to get them to look into it. Although at this point, they don't seem to have any enthusiasm at all for dealing with this problem. We'll see how it goes. |
On Aug 31, 10:03*am, Westbender wrote:
It appears that our only option is to keep resubmitting the same file until it validates successfully. If that truly does work, then it's obvious that the problem is in the OLC validator software. Once I have a track record of proof, I'll contact the OLC folks again and try to get them to look into it. Although at this point, they don't seem to have any enthusiasm at all for dealing with this problem. We'll see how it goes. This is a crazy problem. This is a moving target. How can a bad file be fixed with a program? How can a good file be bad and then fixed with a program? If I convert the cai file to igc with the old dos program it gets scored and put in order in light print with a red v. It all pays the same - ($0). I for one have spent my last evening trying to get rid of the dreaded red v. Bill Snead |
Last two flight logs validated fine without issue. Not sure if
something changed with the OLC flight log validator. Hopefully it's fixed. |
Same here, though I've only had one. It validated on the first try (after
running the batch file). "Westbender" wrote in message ... Last two flight logs validated fine without issue. Not sure if something changed with the OLC flight log validator. Hopefully it's fixed. |
On Sep 12, 10:53*am, "Dan Marotta" wrote:
Same here, though I've only had one. *It validated on the first try (after running the batch file). "Westbender" wrote in message ... Last two flight logs validated fine without issue. Not sure if something changed with the OLC flight log validator. Hopefully it's fixed. Three in a row! It's looking more and more like the problem was fixed. Yay! |
On Sep 15, 11:23*pm, Westbender wrote:
On Sep 12, 10:53*am, "Dan Marotta" wrote: Same here, though I've only had one. *It validated on the first try (after running the batch file). "Westbender" wrote in message .... Last two flight logs validated fine without issue. Not sure if something changed with the OLC flight log validator. Hopefully it's fixed. Three in a row! It's looking more and more like the problem was fixed. Yay! Hmmm.... I see there's a couple of recent failures by other pilots submitting logs from legacy Cambridge recorders. Looks like the problem is not solved. |
I submitted a log from a Model 20 yesterday and it went through perfectly
first time. Previously, I've had to submit the same log three times for it to be accepted. "Westbender" wrote in message ... On Sep 15, 11:23 pm, Westbender wrote: On Sep 12, 10:53 am, "Dan Marotta" wrote: Same here, though I've only had one. It validated on the first try (after running the batch file). "Westbender" wrote in message ... Last two flight logs validated fine without issue. Not sure if something changed with the OLC flight log validator. Hopefully it's fixed. Three in a row! It's looking more and more like the problem was fixed. Yay! Hmmm.... I see there's a couple of recent failures by other pilots submitting logs from legacy Cambridge recorders. Looks like the problem is not solved. |
Cambridge GPS NAV Model 20 with S NAV | Leigh | Soaring | 0 | March 21st 08 07:58 PM |
Cambridge GPS-Nav Model 20 | Fred[_4_] | Soaring | 16 | March 2nd 08 10:11 PM |
Cambridge Model 20 to OLC | Bubba | Soaring | 6 | June 22nd 06 08:45 PM |
Cambridge Model 20 to OLC | Bubba | Soaring | 0 | June 12th 06 02:30 PM |
Buy -- Model 20 Cambridge GPS | John Murphy | Soaring | 0 | March 24th 05 02:32 AM |
