Revisiting the Cambridge Model 20 OLC failures...
Old August 29th 11, 05:02 PM posted to rec.aviation.soaring
Westbender
Default Revisiting the Cambridge Model 20 OLC failures...
Has anyone figured out a way to submit valid igc files from these
devices? For the last few seasons, everything was working fine. This
year, about 3 out of every 4 OLC postings produce an invalid status.
The OLC folks have been nice enough to fix the log file status, but
they cannot continue to do this. What's the secret? We've tried See
You as well as the DOS command line utilities. Same results no matter
which method we use.
Old August 29th 11, 05:13 PM posted to rec.aviation.soaring
Darryl Ramm
What exact error do you get? is it only OLC complaining or does VALI-CAM
fail as well?
Have you run VALI-CAM on every file before submission?
Darryl
Old August 29th 11, 05:47 PM posted to rec.aviation.soaring
Ian Reekie
After each flight I perform the download from the Cambridge to an Ipaq
using Connectme from Naviter. When I get home I sync the IGC file created
by Connectme to the PC and do a direct file claim to the OLC site.
It has worked every time this year, I get a green V (validated OK).
The IGC file created by Connectme has the binary .CAI file contents
appended at the end. This allows OLC validation.
I believe you cannot submit flights to the OLC directly from SeeYou
anymore.
Old August 29th 11, 06:11 PM posted to rec.aviation.soaring
Westbender
The problem is that we get the red "V" on the OLC site after
submitting. All the output from vali-cam shows everything to be
correct. All validation passes....except for the OLC.
I corresponded with the folks at the OLC and they recommend I use the
command line utilities (vali-cam, cai2igc, etc.). However that method
does not work 100% of the time either. They claim it's an issue with
the legacy cambridge loggers and they recommended yesterday that we
should upgrade our logger.
I personally have a 302, which works flawlessly. A fellow club member
has the model 20 that we can't seem to get valid OLC submittals out
of. I've been doing the conversions and submittals for him. The
interesting thing is for the last 4 seasons or so, the files were
accepted by the OLC 100% of the time. This problem just started this
year.
Old August 30th 11, 12:03 AM posted to rec.aviation.soaring
Westbender
Ok, I could use a little schooling on these converted cai files.
Here's the message from Juergen @ OLC regarding the problems with the
files. He sent this about 3 or 4 files ago.
"The signature in the .igc file was missing. The validation procedure
only can validate the binary .cai file. Therefore the .igc file for
the OLC consists of three parts: The plain igc records, the signature
and the embedded .cai file. The server splits this combined file and
checks the .cai file and the signature. Without that signature the
file is invalid. I extracted the .cai file from the .igc file,
converted it again with my own procedure (you can find it attached)
and replaced the file in the flight claim with this new one."
Vali-cam shows the cai file to be fine, so I'm assuming that's not the
problem. When I look at the igc file, I can see two "G" records. Are
these the "signature" records that Juergen is referring to? What other
kind of signature file is there besides what's in the original cai
file?
Old August 30th 11, 12:11 AM posted to rec.aviation.soaring
Westbender
Update...
After looking at the different files from different conversion
methods, the See You converted files are in fact missing the "G"
records. However, the DOS cmd line utilities are creating "G" records,
but the files are still invalid when submitting to the OLC. Once in a
while one will work, so this is an intermittent problem, but most of
the time we get a failure.
I have sent another email to the OLC help group with more details to
see if they can tell me precisely what is wrong with the latest files
that do have the "G" records.
Old August 29th 11, 05:56 PM posted to rec.aviation.soaring
Paul Remde
Hi,
How exactly are you using SeeYou? You should be able to open the .cai file
(not the .igc file) in SeeYou and then save it as a .igc file.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Westbender" wrote in message
Old August 30th 11, 04:41 AM posted to rec.aviation.soaring
Dan Marotta
I, too, have been having problems submitting my files recorded by a Model 20
GPS. In the past, Juergen has fixed them for me, too.
I have found through experimentation that, if I validate and submit the same
file THREE TIMES, it will fail validation on the server twice and will be
accepted the third time. Of course, I have to delete the first two
submissions after they fail and before resubmitting. I have no explanation
but it seems to work for me.
I have to ask: Why do I need to upgrade my hardware? What was done to the
server software which makes my logger no longer create valid files? This
would never be acceptable in a business setting...
"Paul Remde" wrote in message
Hi,
file (not the .igc file) in SeeYou and then save it as a .igc file.
Best Regards,
Paul Remde
Old August 30th 11, 01:32 PM posted to rec.aviation.soaring
Westbender
Latest reply from Hannes @ OLC:
"the file attached to Your mail is valid. The g-record may consist of
1 or more lines starting with a G. I really donīt understand, why the
file sometimes is found invalid and without any change it sometimes is
found valid. A mysterium of Cambridge files.
Our program is working with following steps:
1. It finds a cambridge file derived from a Cambridge 10/20/25 logger
(this file must contain also the cai file (added by means of Carl
Ekdahls program c2i4o11.exe or manually with cai2igc.exe
2. It excerpts the cai file and
3. It compares the cai file and the igc file
4. If both files are found congruent, the file will be marked as igc
valid
5. If it finds any differences it will be marked as invalid
So the first condition is, that the CAI File itself is valid, which is
checked by vali-cam.exe
The second condition is, that the CAI file is converted into a normal
IGC file with conv-cam.exe
The third condition is, that the CAI file is added to the normal IGC
file with cai2igc.exe
So far clear?
Now the program of Carl Ekdahl c2i4o11.exe still produces an igc file
which has a wrong file name, because it sets a B (for 2011) in the
beginning of the file name, instead of a 1 (for 2011). So if You use
the Ekdahl program, please change the file name from e.g. b8scxxxx.igc
to 18scxxxx.igc and this file should be igc valid for olc,"
Old August 31st 11, 03:41 AM posted to rec.aviation.soaring
Roy Clark
valid
So far clear?
-----Forwarded Message-----
Sent: Jun 1, 2011 10:09 PM
To: Roy Clark
Subject: OLC flight claim - Status Report
Hello Roy,
the old cai2igc4olc.exe does not work anymore since beginning 2010,
please use the attached cai4olc.vbe vor conversion of cai files into
valid igc files, I set Your flights to green manually,
regards
Hannes
Cambridge GPS NAV Model 20 with S NAV Leigh Soaring 0 March 21st 08 07:58 PM
Cambridge GPS-Nav Model 20 Fred[_4_] Soaring 16 March 2nd 08 10:11 PM
Cambridge Model 20 to OLC Bubba Soaring 6 June 22nd 06 08:45 PM
Cambridge Model 20 to OLC Bubba Soaring 0 June 12th 06 02:30 PM
Buy -- Model 20 Cambridge GPS John Murphy Soaring 0 March 24th 05 02:32 AM
Copyright Đ2004-2025 AviationBanter.
