I am in the process of writing up some regulations for aerotowing to
	standardize operations and ensure safe procedures for us here in Colombia. The civil aviation authorities don't know a thing about the intricacies of aerotowing so we are on our own with how we want to go about it. Hence the desire to implement something that resembles best bractices across the gliding world. I have been reviewing information/regulations from Germany, the US, the UK, Australia and New Zealand as well as manufacturer information and manuals. The result of this excercise so far has been that there are some considerable differences across countries even with such basic things as aerotow rope requirements. As far as a general guide is concerned I ran into the newly published book "Aerotowing Gliders" by John Marriot (http://www.amazon.com/ Aerotowing-Gliders-towing-gliders-emphasis/dp/1456775154/ref=sr_1_1? s=books&ie=UTF8&qid=1325720610&sr=1-1) which after a first quick read looks like a good basis for general operating procedures. As far as aerotow investigations and rope requirements are concerned I had, among other things, a good look at http://www.negevgliding.com/safety/airtow.pdf http://www.dg-flugzeugbau.de/Data/TN.../2004-54-e.pdf http://www.dg-flugzeugbau.de/sollbruchstelle-d.html (http:// translate.google.com/translate?sl=de&tl=en&u=://www.dg-flugzeugbau.de %2Fsollbruchstelle-d.html&act=url) http://www.dg-flugzeugbau.de/flugzeugschlepp-d.html (http:// translate.google.com/translate?sl=de&tl=en&u=http://www.dg- flugzeugbau.de/flugzeugschlepp-d.html&act=url) In addition and since I have years of past aerotow experience in the US I looked again at the regulations in the FARs: ------------------------ FAR 91.309 Minimum Strength = 80 percent of the glider maximum certificated operating weight Maximum Strength = twice the maximum certificated operating weight Note: Maximum certificated operating weight can be found in the glider POH and may be the Maximum certificated gross weight at takeoff. If the towrope has a breaking strength more than twice the maximum certificated operating weight of the glider being towed, a safety link has to be installed at the point of attachment of the glider and the tow plane with the following breaking strength requirements. Safety Link (Weak Link) Requirements Safety link (Weak Link) at the glider end: Minimum Strength = 80 percent of the glider maximum certificated operating weight Maximum Strength = twice the maximum certificated operating weight Safety link (Weak Link) at the tow plane end: Strength Requirements = Greater, but not more than 25% greater than that of the safety link on the glider end, and not more than twice the maximum certificated operating weight of the glider ------------------------ My conclusions that have come out of this so far a Aerotow, especially of single seater light wing loading gliders, should only be done with a nose hook (and not a CG hook) to avoid the danger of the rapid onset of kiting that will not break your standard glider weak link but stall the tow plane (see UK tests described in http://www.negevgliding.com/safety/airtow.pdf). Weak links at both ends of the rope to protect the glider but also the tow plane in case the rope gets caught e.g. in a tree or power line after glider release when close to the ground (I ran into several accident reports where this happened, especially after a tow emergency at low altitude). Interestingly enough the UK requires a weak link at the tow plane end to protect the tow plane with an additional glider end weak link being optional while the Germans only explicitely require a glider end weak link according to the glider manual. I have a personal distaste for the US arangement of using ropes as weak links since it is not easy to tell which rope has which diameter/ is made of which material to then indirectly deduct the rope weak link/ aerotow rope strength (if no weak links are used). In addition, rope wear can quickly become an issue limiting weak link/rope strength. Coming originally from a winching background for me there is nothing simpler than teaching and checking the weak link color required for a specific glider, no second guessing, no hidden rope wear reducing the weak link/rope strength. Now to the recommended weak link strengths: The US idea of having a slightly stronger weak link on the tow plane end seems to be a sensible idea to have the weak link fail first on the glider end to protect the glider from getting entangled with the rope which could happen if it breaks on the tow plane end. However, the specific US weak link strength requirements do not make much sense and e.g. in the case of the Diamond DA-40 contravene what the aircraft manual permits (http://www.diamond-air.at/fileadmin/...sales_support/ DA40-180/Airplane_Flight_Manual/Supplements/60101e-o1-r1.pdf): DA-40 Manual states: Weak link of max. 899 lbf (400 daN) on tow plane end required, on glider side optional according to glider manual, 750 kg/1653 lb max glider weight on tow, tow rope min breaking load 2248 lbf (1000 daN) If I use the requirements of FAR 91.309 to determine weak link strengths I could use between 80% and 200% of max gross weight of the glider for the glider end but it would be limited to just below the strength of the tow plane end weak link. So if the DA-40 manual limits me to 899 lbf (400 daN) on the tow plane end my glider weak link has to be less than that, best case 898 lbf (399 daN). The best I can do now for max gross weight is a minimum of 80% of the glider's max gross weight for the glider end weak link which would get me at the most 1122.5 lbs/509 kg for the glider. In short the FARs would not allow me to tow any modern 2 seater with a DA-40 even though the DA-40 manual explicitely allows for up to 1653 lb/750 kg gliders. Now considering the UK tests mentioned earlier it seems to me like a really bad idea to use a tow rope with no weak links approaching twice the max gross weight as allowed by the FARs. Research done in Germany suggests (see above links to documents on the DG website) that weak links of no more than 661 lbf/300 daN are necessary on the glider end even though most glider handbooks specify the same weak link strength for aerotow as for winch launching (which involves much higher forces). So the quick summary of my take so far on all this with regards to aerotow ropes is: - Minimum aerotow rope breaking load of 2248 lbf (1000 daN) - General purpose length of aerotow rope for standard daily ops of 50m/ 165 feet - Use of 2 weak links, one on the glider end, one on the tow plane end - Weak links with the Tost reserve setup, 899 lbf (400 daN) on the tow plane end, 661 lbf/300 daN on the glider end Looking forward to comments, suggestions, experiences etc. Thanks in advance, Markus Graeber Aeroclub de Colombia Gliding Colombia/Vuelo a Vela Colombia  |
On 1/4/2012 6:11 PM, Markus Graeber wrote:
	I am in the process of writing up some regulations for aerotowing to standardize operations and ensure safe procedures for us here in Colombia. The civil aviation authorities don't know a thing about the intricacies of aerotowing so we are on our own with how we want to go about it. Hence the desire to implement something that resembles best bractices across the gliding world. I have been reviewing information/regulations from Germany, the US, the UK, Australia and New Zealand as well as manufacturer information and manuals. Snip of excellent research summary... So the quick summary of my take so far on all this with regards to aerotow ropes is: - Minimum aerotow rope breaking load of 2248 lbf (1000 daN) - General purpose length of aerotow rope for standard daily ops of 50m/ 165 feet - Use of 2 weak links, one on the glider end, one on the tow plane end - Weak links with the Tost reserve setup, 899 lbf (400 daN) on the tow plane end, 661 lbf/300 daN on the glider end Looking forward to comments, suggestions, experiences etc. Thanks in advance, Markus Graeber Aeroclub de Colombia Gliding Colombia/Vuelo a Vela Colombia Hello Markus, Seems like a great "good news/bad news" situation you're faced with...the good news of having a blank sheet of paper & the bad news being (non-bureaucratic) you have to do all the filling in of it. I hope the Powers That Be eventually see fit to buy into your conclusions/suggestions... Off-the-cuff thoughts follow... - "Real" (as in metallic, testable, precision-made) weak links at both ends seem to me to be eminently sensible & much preferred over "knots in rope" sort of weak links. While only Tost (so far as I'm aware) makes these, anyone with access to spec-ed metal, standard machine tools, and a pull tester could easily "roll their own." Hence, spec-ing such doesn't necessarily build "whiney" up-front costs. IM(U.S.-based)O, the U.S. FAA approach of specifying *only* breaking strengths probably has worked as well as it has mainly because historically the U.S. has been primarily an aero-tow operation. Kinda-sorta related, personally I wouldn't winch launch without a "metal-spec" weak link at the glider end. - I think you're right to "ignore DA-40-like" plane-specific special cases in any spec-ing you do. Let plane manufacturers rule out/self-limit any newer models they roll out. It probably won't be in our lifetimes non-manufacturer-spec-ed acceptable towplanes (e.g. Pawnees and Super Cubs in the U.S.) vanish. Don't self-create problems for your country/self. - Avoid the "over specification" swamp. For example, don't specify max/min rope length or strength. (Well, OK, maybe some motherhood words about an aerotow rope having to be stronger than either weak link, just to satisfy the lawyer crowd.) On the winch side, if some bubba wants to build a monster winch using chain as the cable, a glider-end weak link should adequately protect the glider and its educated, qualified and current pilot (and passenger, if any), which I would suggest is the proper/sufficient goal. Let education and "the market" address all the other glider-launching, safety-related issues. You should get some interesting feedback! Regards, Bob W.  |
A careful reading of the US FAR's shows 91.309 is not the only
	applicable rule addressing aero tow weak links. 91.9 require all aircraft to be operated in accordance with their Approved Flight Manuals (POH) - if one was published as part of the airworthiness documentation. JAR-22 gliders and most other modern glider have such AFM's which specify an aero tow weak link. Seen in this light, 91.309 is a historical accident which has become a "catch all" for gliders without an AFM specified weak link, (eg, Schweizers). Taken together, 91.309 and 91.9 mean that the AFM specified weak link it to be used at the glider end and a weak link at the tow plane end must be stronger than the glider end link but not more than 25% stronger. FAA FSDO inspectors I've discussed this with agree with this interpretation. AFAIK, no one in the US is actually operating in accordance with the above rules since they think it would be a hassle to be switching weak links for every glider. Fortunately, Tost makes hardware which makes it somewhat easier. It wouldn't surprise me to see an NPRM clarifying the above. Bill D On Jan 4, 6:11*pm, Markus Graeber wrote: I am in the process of writing up some regulations for aerotowing to standardize operations and ensure safe procedures for us here in Colombia. The civil aviation authorities don't know a thing about the intricacies of aerotowing so we are on our own with how we want to go about it. Hence the desire to implement something that resembles best bractices across the gliding world. I have been reviewing information/regulations from Germany, the US, the UK, Australia and New Zealand as well as manufacturer information and manuals. The result of this excercise so far has been that there are some considerable differences across countries even with such basic things as aerotow rope requirements. As far as a general guide is concerned I ran into the newly published book "Aerotowing Gliders" by John Marriot (http://www.amazon.com/ Aerotowing-Gliders-towing-gliders-emphasis/dp/1456775154/ref=sr_1_1? s=books&ie=UTF8&qid=1325720610&sr=1-1) which after a first quick read looks like a good basis for general operating procedures. As far as aerotow investigations and rope requirements are concerned I had, among other things, a good look at http://www.negevgliding.com/safety/a...d.html(http:// translate.google.com/translate?sl=de&tl=en&u=://www.dg-flugzeugbau.de %2Fsollbruchstelle-d.html&act=url)http://www.dg-flugzeugbau.de/flugzeu...d.html(http:// translate.google.com/translate?sl=de&tl=en&u=http://www.dg- flugzeugbau.de/flugzeugschlepp-d.html&act=url) In addition and since I have years of past aerotow experience in the US I looked again at the regulations in the FARs: ------------------------ FAR 91.309 * * Minimum Strength = 80 percent of the glider maximum certificated operating weight * * Maximum Strength = twice the maximum certificated operating weight Note: Maximum certificated operating weight can be found in the glider POH and may be the Maximum certificated gross weight at takeoff. If the towrope has a breaking strength more than twice the maximum certificated operating weight of the glider being towed, a safety link has to be installed at the point of attachment of the glider and the tow plane with the following breaking strength requirements. Safety Link (Weak Link) Requirements Safety link (Weak Link) at the glider end: * * Minimum Strength = 80 percent of the glider maximum certificated operating weight * * Maximum Strength = twice the maximum certificated operating weight Safety link (Weak Link) at the tow plane end: * * Strength Requirements = Greater, but not more than 25% greater than that of the safety link on the glider end, and not more than twice the maximum certificated operating weight of the glider ------------------------ My conclusions that have come out of this so far a Aerotow, especially of single seater light wing loading gliders, should only be done with a nose hook (and not a CG hook) to avoid the danger of the rapid onset of kiting that will not break your standard glider weak link but stall the tow plane (see UK tests described inhttp://www.negevgliding.com/safety/airtow.pdf). Weak links at both ends of the rope to protect the glider but also the tow plane in case the rope gets caught e.g. in a tree or power line after glider release when close to the ground (I ran into several accident reports where this happened, especially after a tow emergency at low altitude). Interestingly enough the UK requires a weak link at the tow plane end to protect the tow plane with an additional glider end weak link being optional while the Germans only explicitely require a glider end weak link according to the glider manual. I have a personal distaste for the US arangement of using ropes as weak links since it is not easy to tell which rope has which diameter/ is made of which material to then indirectly deduct the rope weak link/ aerotow rope strength (if no weak links are used). In addition, rope wear can quickly become an issue limiting weak link/rope strength. Coming originally from a winching background for me there is nothing simpler than teaching and checking the weak link color required for a specific glider, no second guessing, no hidden rope wear reducing the weak link/rope strength. Now to the recommended weak link strengths: The US idea of having a slightly stronger weak link on the tow plane end seems to be a sensible idea to have the weak link fail first on the glider end to protect the glider from getting entangled with the rope which could happen if it breaks on the tow plane end. However, the specific US weak link strength requirements do not make much sense and e.g. in the case of the Diamond DA-40 contravene what the aircraft manual permits (http://www.diamond-air.at/fileadmin/...sales_support/ DA40-180/Airplane_Flight_Manual/Supplements/60101e-o1-r1.pdf): DA-40 Manual states: Weak link of max. 899 lbf (400 daN) on tow plane end required, on glider side optional according to glider manual, 750 kg/1653 lb max glider weight on tow, tow rope min breaking load 2248 lbf (1000 daN) If I use the requirements of FAR 91.309 to determine weak link strengths I could use between 80% and 200% of max gross weight of the glider for the glider end but it would be limited to just below the strength of the tow plane end weak link. So if the DA-40 manual limits me to 899 lbf (400 daN) on the tow plane end my glider weak link has to be less than that, best case 898 lbf (399 daN). The best I can do now for max gross weight is a minimum of 80% of the glider's max gross weight for the glider end weak link which would get me at the most 1122.5 lbs/509 kg for the glider. In short the FARs would not allow me to tow any modern 2 seater with a DA-40 even though the DA-40 manual explicitely allows for up to 1653 lb/750 kg gliders. Now considering the UK tests mentioned earlier it seems to me like a really bad idea to use a tow rope with no weak links approaching twice the max gross weight as allowed by the FARs. Research done in Germany suggests (see above links to documents on the DG website) that weak links of no more than 661 lbf/300 daN are necessary on the glider end even though most glider handbooks specify the same weak link strength for aerotow as for winch launching (which involves much higher forces). So the quick summary of my take so far on all this with regards to aerotow ropes is: - Minimum aerotow rope breaking load of 2248 lbf (1000 daN) - General purpose length of aerotow rope for standard daily ops of 50m/ 165 feet - Use of 2 weak links, one on the glider end, one on the tow plane end - Weak links with the Tost reserve setup, 899 lbf (400 daN) on the tow plane end, 661 lbf/300 daN on the glider end Looking forward to comments, suggestions, experiences etc. Thanks in advance, Markus Graeber Aeroclub de Colombia Gliding Colombia/Vuelo a Vela Colombia  |
Hi Markus
	https://www.gliding.co.uk/bgainfo/cl.../documents/aer otownotes.pdf for the British Gliding Association handbook. I am sure that the BGA would be more than happy to help you develop your own national equivalent. Best wishes John Roche-Kelly Norfolk Gliding Club  |
On Jan 4, 7:11*pm, Markus Graeber  wrote:
	I am in the process of writing up some regulations for aerotowing to standardize operations and ensure safe procedures for us here in Colombia. The civil aviation authorities don't know a thing about the intricacies of aerotowing so we are on our own with how we want to go about it. Hence the desire to implement something that resembles best bractices across the gliding world. I have been reviewing information/regulations from Germany, the US, the UK, Australia and New Zealand as well as manufacturer information and manuals. The result of this excercise so far has been that there are some considerable differences across countries even with such basic things as aerotow rope requirements. As far as a general guide is concerned I ran into the newly published book "Aerotowing Gliders" by John Marriot (http://www.amazon.com/ Aerotowing-Gliders-towing-gliders-emphasis/dp/1456775154/ref=sr_1_1? s=books&ie=UTF8&qid=1325720610&sr=1-1) which after a first quick read looks like a good basis for general operating procedures. As far as aerotow investigations and rope requirements are concerned I had, among other things, a good look at http://www.negevgliding.com/safety/a...d.html(http:// translate.google.com/translate?sl=de&tl=en&u=://www.dg-flugzeugbau.de %2Fsollbruchstelle-d.html&act=url)http://www.dg-flugzeugbau.de/flugzeu...d.html(http:// translate.google.com/translate?sl=de&tl=en&u=http://www.dg- flugzeugbau.de/flugzeugschlepp-d.html&act=url) In addition and since I have years of past aerotow experience in the US I looked again at the regulations in the FARs: ------------------------ FAR 91.309 * * Minimum Strength = 80 percent of the glider maximum certificated operating weight * * Maximum Strength = twice the maximum certificated operating weight Note: Maximum certificated operating weight can be found in the glider POH and may be the Maximum certificated gross weight at takeoff. If the towrope has a breaking strength more than twice the maximum certificated operating weight of the glider being towed, a safety link has to be installed at the point of attachment of the glider and the tow plane with the following breaking strength requirements. Safety Link (Weak Link) Requirements Safety link (Weak Link) at the glider end: * * Minimum Strength = 80 percent of the glider maximum certificated operating weight * * Maximum Strength = twice the maximum certificated operating weight Safety link (Weak Link) at the tow plane end: * * Strength Requirements = Greater, but not more than 25% greater than that of the safety link on the glider end, and not more than twice the maximum certificated operating weight of the glider ------------------------ My conclusions that have come out of this so far a Aerotow, especially of single seater light wing loading gliders, should only be done with a nose hook (and not a CG hook) to avoid the danger of the rapid onset of kiting that will not break your standard glider weak link but stall the tow plane (see UK tests described inhttp://www.negevgliding.com/safety/airtow.pdf). Weak links at both ends of the rope to protect the glider but also the tow plane in case the rope gets caught e.g. in a tree or power line after glider release when close to the ground (I ran into several accident reports where this happened, especially after a tow emergency at low altitude). Interestingly enough the UK requires a weak link at the tow plane end to protect the tow plane with an additional glider end weak link being optional while the Germans only explicitely require a glider end weak link according to the glider manual. I have a personal distaste for the US arangement of using ropes as weak links since it is not easy to tell which rope has which diameter/ is made of which material to then indirectly deduct the rope weak link/ aerotow rope strength (if no weak links are used). In addition, rope wear can quickly become an issue limiting weak link/rope strength. Coming originally from a winching background for me there is nothing simpler than teaching and checking the weak link color required for a specific glider, no second guessing, no hidden rope wear reducing the weak link/rope strength. Now to the recommended weak link strengths: The US idea of having a slightly stronger weak link on the tow plane end seems to be a sensible idea to have the weak link fail first on the glider end to protect the glider from getting entangled with the rope which could happen if it breaks on the tow plane end. However, the specific US weak link strength requirements do not make much sense and e.g. in the case of the Diamond DA-40 contravene what the aircraft manual permits (http://www.diamond-air.at/fileadmin/...sales_support/ DA40-180/Airplane_Flight_Manual/Supplements/60101e-o1-r1.pdf): DA-40 Manual states: Weak link of max. 899 lbf (400 daN) on tow plane end required, on glider side optional according to glider manual, 750 kg/1653 lb max glider weight on tow, tow rope min breaking load 2248 lbf (1000 daN) If I use the requirements of FAR 91.309 to determine weak link strengths I could use between 80% and 200% of max gross weight of the glider for the glider end but it would be limited to just below the strength of the tow plane end weak link. So if the DA-40 manual limits me to 899 lbf (400 daN) on the tow plane end my glider weak link has to be less than that, best case 898 lbf (399 daN). The best I can do now for max gross weight is a minimum of 80% of the glider's max gross weight for the glider end weak link which would get me at the most 1122.5 lbs/509 kg for the glider. In short the FARs would not allow me to tow any modern 2 seater with a DA-40 even though the DA-40 manual explicitely allows for up to 1653 lb/750 kg gliders. Now considering the UK tests mentioned earlier it seems to me like a really bad idea to use a tow rope with no weak links approaching twice the max gross weight as allowed by the FARs. Research done in Germany suggests (see above links to documents on the DG website) that weak links of no more than 661 lbf/300 daN are necessary on the glider end even though most glider handbooks specify the same weak link strength for aerotow as for winch launching (which involves much higher forces). So the quick summary of my take so far on all this with regards to aerotow ropes is: - Minimum aerotow rope breaking load of 2248 lbf (1000 daN) - General purpose length of aerotow rope for standard daily ops of 50m/ 165 feet - Use of 2 weak links, one on the glider end, one on the tow plane end - Weak links with the Tost reserve setup, 899 lbf (400 daN) on the tow plane end, 661 lbf/300 daN on the glider end Looking forward to comments, suggestions, experiences etc. Thanks in advance, Markus Graeber Aeroclub de Colombia Gliding Colombia/Vuelo a Vela Colombia In addition to the technical advice given by others, let me offer tactical advice. Keep the regulation as simple as possible. Develop a separate set of "best practices" which are good advice but not codified into legally binding regulation. The US 80% - 200% has been in the regulations since time immemorial -- at least the 1940s. Regulations don't adapt to advances in technology and technique. The 80Z%-200% contravenes what's written in many operating handbooks for example. Nosehooks are another example. OK, write a best practices that it's better to airtow with nosehooks. But don't put that in regulations! Many of us have been airtowing with belly hooks for a long time, and it's simply not legal to retrofit others with nosehooks. (If the manufacturer doesn't have an approved kit, and you have a fully legal repair station, etc.) You can end up unintentionally grounding half your fleet. John Cochrane  |
Thanks all, especially the BGA Aerotowing Guidance Notes linked to by
	John is very good stuff (by the same author as the mentioned book), I hadn't seen those yet even though we use quite a few BGA publications as a reference here. Just to clarify the situation, I am not going to write any legally binding regulations for the civil aviation authorities here (Aerocivil). The idea is a common sense set of rules for the federation level and a very specific set of rules for the club's operation based on the equipment and operating environment we have. Since we control these rules ourselves (much like the BGA does in the UK as well as the AU GFA and NZ GN as largely selfgoverning gliding organisations) it will be easy for us to change them quickly if needed. In addition, gliders here in Colombia are in practical terms treated like experimentals in the US so we can pretty much do as we please as long as we can reasonably assure it's safe to fly. If for example I want to install a nose hook I don't have to worry about STCs from the FAA/EASA, if I can dig up install instructions based on solid engineering I can just go ahead and install it. One example is the 2 LAK 12s we have in the club. They are known for lacking a bit of rudder so the owners got together and developed a slight extension to improve rudder effectiveness. Both LAKs also came without CG hooks so in order to get them ready for our winch launch operation I just organized the factory drawings for the CG hook install with the necessary specifications for the belly reinforcement. The actual install with the factory information is not that big of a deal if you have a good A&P around that has experience with fibreglass, no artificial legal barriers to worry about. Here, like all over the world, but sadly sometime more so, people have a habit of just improvising and out of convenience ingnore what should be common sense. Hence the need to be very specific, at least at the club level, based on a general set of reference rules. In addition, the club has a professional pilot school that is now starting to implement glider training into the general power pilot curriculum so we have to make every effort to develop a sound set of rules we can point to that can safe our ass and the school's certification when that accident that shouldn't happen eventually does. Hence my desire to make the best out of the situation and, free from any governmental tight jacket, develop a set of rules based on best practices and the latest research/developments. So for starters I would for example have no problem mandating that the school needs to replace the Schweizer aerotow hook on our PA-18 with a Tost for use for aerotow training while resticting the use of the Schweizer hook on our private C-180 to glider pilots with a certain aerotow experience level until it is replaced by a Tost. Taking into account the UK tests and fatal accidents that have happened due to the inability to trigger the release of a Schweizer hook under high loads I find it a bit mind boggling that these hooks are still legal in many countries and not being phased out on a mandatory basis. All the club's gliders have dedicated aerotow hooks so the only thing that needs to be done for now is mandating their use for aerotow to limit the risk of kiting. If someone eventually brings in a glider with a CG hook only (e.g. an ASW 20) we could then deal with it on a case by case basis on the federation or club level. As far as the aerotow ropes are concerned I am considering requiring a minimum rope strength (e.g. 1000 daN) and and weak links on both ends that comply with the max limits in the respective airplane's manual, I don't really see any valid excuse for not making that relatively small investment into proper safety equipment. On top of that would then be the recommendation to use a 400 or 500 daN weak link on the tow plane side not exceeding any limits imposed by the manufacturer while recommending 300 daN for most gliders or 400 daN for Open Class gliders with a take off weight of more than 600 kg (having in mind recent research and DG's weak link recommendation of half the glider's take-off weight). Keep it coming, Markus Graeber  |
On Jan 5, 10:58*am, Markus Graeber  wrote:
	Thanks all, especially the BGA Aerotowing Guidance Notes linked to by John is very good stuff (by the same author as the mentioned book), I hadn't seen those yet even though we use quite a few BGA publications as a reference here. Just to clarify the situation, I am not going to write any legally binding regulations for the civil aviation authorities here (Aerocivil). The idea is a common sense set of rules for the federation level and a very specific set of rules for the club's operation based on the equipment and operating environment we have. Since we control these rules ourselves (much like the BGA does in the UK as well as the AU GFA and NZ GN as largely selfgoverning gliding organisations) it will be easy for us to change them quickly if needed. In addition, gliders here in Colombia are in practical terms treated like experimentals in the US so we can pretty much do as we please as long as we can reasonably assure it's safe to fly. If for example I want to install a nose hook I don't have to worry about STCs from the FAA/EASA, if I can dig up install instructions based on solid engineering I can just go ahead and install it. One example is the 2 LAK 12s we have in the club. They are known for lacking a bit of rudder so the owners got together and developed a slight extension to improve rudder effectiveness. Both LAKs also came without CG hooks so in order to get them ready for our winch launch operation I just organized the factory drawings for the CG hook install with the necessary specifications for the belly reinforcement. The actual install with the factory information is not that big of a deal if you have a good A&P around that has experience with fibreglass, no artificial legal barriers to worry about. Here, like all over the world, but sadly sometime more so, people have a habit of just improvising and out of convenience ingnore what should be common sense. Hence the need to be very specific, at least at the club level, based on a general set of reference rules. In addition, the club has a professional pilot school that is now starting to implement glider training into the general power pilot curriculum so we have to make every effort to develop a sound set of rules we can point to that can safe our ass and the school's certification when that accident that shouldn't happen eventually does. Hence my desire to make the best out of the situation and, free from any governmental tight jacket, develop a set of rules based on best practices and the latest research/developments. So for starters I would for example have no problem mandating that the school needs to replace the Schweizer aerotow hook on our PA-18 with a Tost for use for aerotow training while resticting the use of the Schweizer hook on our private C-180 to glider pilots with a certain aerotow experience level until it is replaced by a Tost. Taking into account the UK tests and fatal accidents that have happened due to the inability to trigger the release of a Schweizer hook under high loads I find it a bit mind boggling that these hooks are still legal in many countries and not being phased out on a mandatory basis. All the club's gliders have dedicated aerotow hooks so the only thing that needs to be done for now is mandating their use for aerotow to limit the risk of kiting. If someone eventually brings in a glider with a CG hook only (e.g. an ASW 20) we could then deal with it on a case by case basis on the federation or club level. As far as the aerotow ropes are concerned I am considering requiring a minimum rope strength (e.g. 1000 daN) and and weak links on both ends that comply with the max limits in the respective airplane's manual, I don't really see any valid excuse for not making that relatively small investment into proper safety equipment. On top of that would then be the recommendation to use a 400 or 500 daN weak link on the tow plane side not exceeding any limits imposed by the manufacturer while recommending 300 daN for most gliders or 400 daN for Open Class gliders with a take off weight of more than 600 kg (having in mind recent research and DG's weak link recommendation of half the glider's take-off weight). Keep it coming, Markus Graeber Markus, About the Schweizer tow hooks on towplanes: While the Tost is without a doubt a better solution, and safer, we have been using the Schweizer in the US for a long time with few problems. Unless you fly a fleet of early trainers, the pitch up problem is probably more theoretical than real (for that matter, it would still be a problem with the Tost at low altitude, since you still have to release and recover!). That being said, one relatively simple fix is to invert the Schweizer release on the towplane, so the arm releases from the bottom (like on the glider). That way, upwards tension on the towrope caused by kiting is taken by the fixed arm and pivot, avoiding the problem of the towrope tension jamming the release arm. There is a 337 for this mod on Pawnees - Turf Soaring in Arizona developed it and they could help if interested. Regardless of the type of tow hook, a good briefing for both the tow pilot and glider pilot on the causes and consequences of this type of upset is essential! Cheers, Kirk  |
On Jan 5, 11:45*am, "kirk.stant"  wrote:
	On Jan 5, 10:58*am, Markus Graeber wrote: Thanks all, especially the BGA Aerotowing Guidance Notes linked to by John is very good stuff (by the same author as the mentioned book), I hadn't seen those yet even though we use quite a few BGA publications as a reference here. Just to clarify the situation, I am not going to write any legally binding regulations for the civil aviation authorities here (Aerocivil). The idea is a common sense set of rules for the federation level and a very specific set of rules for the club's operation based on the equipment and operating environment we have. Since we control these rules ourselves (much like the BGA does in the UK as well as the AU GFA and NZ GN as largely selfgoverning gliding organisations) it will be easy for us to change them quickly if needed. In addition, gliders here in Colombia are in practical terms treated like experimentals in the US so we can pretty much do as we please as long as we can reasonably assure it's safe to fly. If for example I want to install a nose hook I don't have to worry about STCs from the FAA/EASA, if I can dig up install instructions based on solid engineering I can just go ahead and install it. One example is the 2 LAK 12s we have in the club. They are known for lacking a bit of rudder so the owners got together and developed a slight extension to improve rudder effectiveness. Both LAKs also came without CG hooks so in order to get them ready for our winch launch operation I just organized the factory drawings for the CG hook install with the necessary specifications for the belly reinforcement. The actual install with the factory information is not that big of a deal if you have a good A&P around that has experience with fibreglass, no artificial legal barriers to worry about. Here, like all over the world, but sadly sometime more so, people have a habit of just improvising and out of convenience ingnore what should be common sense. Hence the need to be very specific, at least at the club level, based on a general set of reference rules. In addition, the club has a professional pilot school that is now starting to implement glider training into the general power pilot curriculum so we have to make every effort to develop a sound set of rules we can point to that can safe our ass and the school's certification when that accident that shouldn't happen eventually does. Hence my desire to make the best out of the situation and, free from any governmental tight jacket, develop a set of rules based on best practices and the latest research/developments. So for starters I would for example have no problem mandating that the school needs to replace the Schweizer aerotow hook on our PA-18 with a Tost for use for aerotow training while resticting the use of the Schweizer hook on our private C-180 to glider pilots with a certain aerotow experience level until it is replaced by a Tost. Taking into account the UK tests and fatal accidents that have happened due to the inability to trigger the release of a Schweizer hook under high loads I find it a bit mind boggling that these hooks are still legal in many countries and not being phased out on a mandatory basis. All the club's gliders have dedicated aerotow hooks so the only thing that needs to be done for now is mandating their use for aerotow to limit the risk of kiting. If someone eventually brings in a glider with a CG hook only (e.g. an ASW 20) we could then deal with it on a case by case basis on the federation or club level. As far as the aerotow ropes are concerned I am considering requiring a minimum rope strength (e.g. 1000 daN) and and weak links on both ends that comply with the max limits in the respective airplane's manual, I don't really see any valid excuse for not making that relatively small investment into proper safety equipment. On top of that would then be the recommendation to use a 400 or 500 daN weak link on the tow plane side not exceeding any limits imposed by the manufacturer while recommending 300 daN for most gliders or 400 daN for Open Class gliders with a take off weight of more than 600 kg (having in mind recent research and DG's weak link recommendation of half the glider's take-off weight). Keep it coming, Markus Graeber Markus, About the Schweizer tow hooks on towplanes: *While the Tost is without a doubt a better solution, and safer, we have been using the Schweizer in the US for a long time with few problems. *Unless you fly a fleet of early trainers, the pitch up problem is probably more theoretical than real (for that matter, it would still be a problem with the Tost at low altitude, since you still have to release and recover!). *That being said, one relatively simple fix is to invert the Schweizer release on the towplane, so the arm releases from the bottom (like on the glider). *That way, upwards tension on the towrope caused by kiting is taken by the fixed arm and pivot, avoiding the problem of the towrope tension jamming the release arm. *There is a 337 for this mod on Pawnees - Turf Soaring in Arizona developed it and they could help if interested. Regardless of the type of tow hook, a good briefing for both the tow pilot and glider pilot on the causes and consequences of this type of upset is essential! Cheers, Kirk You might also want to revisit the pros and cons of high versus low tow. Low tow seems likely to be safer for the tow pilot as kiting upsets are less likely. Mike  |
Thanks Kirk, good point, I had heard about inverting the Schweizer tow
	hook many years ago while still flying in ABQ but somehow forgot about it. We have to worry within the club about a PA-18 and a C-180, will check with the shop what it would take to invert them and if/what the legal ramifications in Colombia would be. Markus  |
Low tow very tricky in a glider with only a CoG hook.
	John You might also want to revisit the pros and cons of high versus low tow. Low tow seems likely to be safer for the tow pilot as kiting upsets are less likely. Mike  |
| FAA regulations - W&B | Arne | Piloting | 13 | March 15th 05 02:50 AM |
| Jim Weir - aviation headset specifications | Rick Pellicciotti | Home Built | 2 | October 4th 04 08:34 PM |
| Aerotow rope drogue chute? | John Galloway | Soaring | 18 | December 11th 03 06:37 AM |
| Connecting Rod Specifications | Cambridge_Flyer | Home Built | 4 | November 18th 03 12:54 PM |
| Huntair Pathfinder 2 specifications | Nigel Hodgson | General Aviation | 1 | October 16th 03 05:32 AM |
