In USA, if you are flying under Part 91 of the Federal Aviation Regulations
(FARs). Are you required to perform weight and balance checks before every flight? And if so, are you required to document it? Can the FAA show up on the ramp asking you to show the weight and balance calculation? |
Arne wrote: Are you required to perform weight and balance checks before every flight? No. If I'm flying alone in an aircraft that has a useful load of over 800 pounds, it would be pretty silly to calculate W&B. And if so, are you required to document it? Can the FAA show up on the ramp asking you to show the weight and balance calculation? No. Even when I do a W&B calculation, it's on my computer at home and I don't print them out. The FAA might ask you to perform one during a ramp check, but you know how to do that, right? George Patterson I prefer Heaven for climate but Hell for company. |
"George Patterson" wrote in message
... Are you required to perform weight and balance checks before every flight? No. If I'm flying alone in an aircraft that has a useful load of over 800 pounds, it would be pretty silly to calculate W&B. Sort of. The "weight" part is obviously satisfied, but the "balance" part is not. Of course, in most cases, a pilot will have done enough sample W&B calculations to know when they need to consider the "balance" part for solo or lightly loaded operations. This is probably true in your case as well. But that doesn't mean you didn't do the "balance" part...it just means you did it once (or a few times) and have applied the results to many subsequent flights. Even for the "weight" part, the few seconds it takes you to consider that you're alone and well under the useful load of the aircraft would certainly qualify as "perfoming a weight check". Just because you didn't write it down or do formal calculations, that doesn't mean you didn't verify that you were within the weight and balance envelope of the aircraft for that flight. IMHO, the correct answer is "yes, you are required to perform weight and balance checks before every flight". What those checks entail varies according to the flight and prior experience with the aircraft. But a pilot who can say, without making a (another) weight and balance calculation, whether the aircraft is within limits or not has made a de facto check of the weight and balance for that flight, whether or not they have made a formal calculation using the exact fuel, oocupant, and cargo load for that flight. (And conversely, a pilot who cannot make such a statement has not fulfilled the preflight duties required of that pilot). Bottom line: if you *know* that the aircraft is within the required limits, then you've made the preflight weight and balance checks. And you ARE required to *know* that the aircraft is within the required limits. Pete |
Peter Duniho wrote: Of course, in most cases, a pilot will have done enough sample W&B calculations to know when they need to consider the "balance" part for solo or lightly loaded operations. This is not necessary with a Maule. You can load anything in the front seats up to the point of MGW and stay within the envelope. This is also true of a Cessna 150. This is, in fact true of nearly every light aircraft. I suppose you could argue that "enough sample W&B calculations" is 1 in those cases, but I can't recall every doing any when I owned those planes. It was pretty obvious from the fact that the front seats are right under the center of lift. George Patterson I prefer Heaven for climate but Hell for company. |
... This is not necessary with a Maule. You can load anything in the front seats up to the point of MGW and stay within the envelope. This is also true of a Cessna 150. This is, in fact true of nearly every light aircraft. Your statement was about aircraft generally with a useful load over 800 pounds, not about your Maule specifically. Additionally, I *will* argue that the number of required previous calculations may only be one, but the calculation is required. Your statement that "this is, in fact true of nearly every light aircraft" is false, unless you'd care to qualify "nearly" as differently than I understand it (that is, only one or two aircraft would not be included). Certainly there are plenty of light aircraft out there for which balance in a lightly loaded airplane is still an issue. I'm sure I can find at least a dozen if I tried, and I know of at least three off the top of my head, which is a lot for someone like me who doesn't have anywhere close to an encyclopedic knowledge of airplanes. Pete |
In the Navion with the geared engine if I was flying solo I had to put fuel in the
baggage compartment tank to stay within W&B. Ron was ok by himself, I'm just too light : - ). We will see what the W&B looks like with the new engine. Margy George Patterson wrote: Peter Duniho wrote: Of course, in most cases, a pilot will have done enough sample W&B calculations to know when they need to consider the "balance" part for solo or lightly loaded operations. This is not necessary with a Maule. You can load anything in the front seats up to the point of MGW and stay within the envelope. This is also true of a Cessna 150. This is, in fact true of nearly every light aircraft. I suppose you could argue that "enough sample W&B calculations" is 1 in those cases, but I can't recall every doing any when I owned those planes. It was pretty obvious from the fact that the front seats are right under the center of lift. George Patterson I prefer Heaven for climate but Hell for company. |
("Margy Natalie" wrote)\
In the Navion with the geared engine if I was flying solo I had to put fuel in the baggage compartment tank to stay within W&B. Ron was ok by himself, I'm just too light : - ). We will see what the W&B looks like with the new engine. What's the update on your Navion? Montblack |
George Patterson wrote: The FAA might ask you to perform one during a ramp check, but you know how to do that, right? Really? I've never heard of this happening. Wouldn't they have to carry a scale around with them? I, for one, weigh all my gear at home (and perform the calculations at home). I carry the required W&B documentation on board the airplane, but not a list of all the weights of every item. The most I could give an inspector would be a figure for the weight (fuel full and empty) and the arm. John Galban=====N4BQ (PA28-180) |
Actually I have heard of this happening, where an FAA inspector saw 5
guys with parachute rigs get into a 182 in preparation for a Skydive. After the jump the inspector requested that the pilot show that he airplane was being flown within the W&B limits. The pilot happily complied and showed the inspector that the airplane was being flown within limits. End of Story. Brian |
"Brian" wrote in message ups.com... Actually I have heard of this happening, where an FAA inspector saw 5 guys with parachute rigs get into a 182 in preparation for a Skydive. After the jump the inspector requested that the pilot show that he airplane was being flown within the W&B limits. The pilot happily complied and showed the inspector that the airplane was being flown within limits. End of Story. Brian Not exactly reliable information. There are thousands of similar "I heard" stories in aviation. A surprisingly large number of them are not true. Do you have a reliable cite? |
| Thread Tools | |
| Display Modes | |
| Same BA 747 loses engine again, Violated U.S. regulations | Big John | Piloting | 3 | March 8th 05 11:38 PM |
| Ultra light Glider regulations | Denis G | Soaring | 5 | May 24th 04 07:19 PM |
| ANN: WingX Version 1.2 - Federal Aviation Regulations on your PDA! | Hilton Software LLC | Piloting | 7 | October 17th 03 05:51 PM |
| New UK Regulations | Soaring | 5 | October 2nd 03 01:13 AM | |
| FAR:Safety Pilot & High Performance/Complex? | John T | Piloting | 53 | August 18th 03 05:04 PM |
