Looking for advice on bleeding the brakes on my Duo with the tost 30-9
caliper. I replaced a shot bleeder valve with a new stahlbus valve, but after futzing with the system for over an hour, I can't get the brake to firm up to an acceptable level. I've tried using a suction device to pull fluid (Dot 4 in the Duo) down through the line. I've also gone with my normal old standby of pushing fluid up through the brake using a syringe. The Stahlbus valve is not working as advertised or rather the brake isn't. The brake doesn't seem to be creating enough pressure to overcome the spring tension on the check valve. The best I've been able to get to so far is a fairly spongy grip on the rotor. Enough that turning by hand isn't possible, but it doesn't feel like it would slow you down much when you needed it. Basically it just doesn't feel like the master cylinder is drawing fluid in or maybe there is a hidden air bubble. Any thoughts from the internet hive on the quirks of this beast? It's certainly been a much greater hassle than I expected. I'm guessing at this point that either there is a trick that I don't know about or something is malfunctioning. Thanks, Morgan |
Not on the Duo specifically, but some thoughts none-the-less.
Best to use a pressure pot (can be a good quality pump oil can, but better is a small pump-up garden sprayer modified for the job, as this allows some serious through-put to overcome and move out bubbles in high spots). Cycle the brake lever a few times while pumping the fluid up. Note that some installations don't have the brake line going into the caliper at the top, thus there can be a stubborn bubble in the caliper itself. In this case, remove caliper and but a clamp on piston to keep it from coming out. Then bleed with brake line at top. To get more through put, you will need remove all brake fluid from the reservoir with a syringe. Better is to intall a fitting in the existing cap vent hole so you can install a temporary tube to take off the excess brake fluid. Depending on existing cap vent hole, you may be able to use a large hypodermic needle for this (McMaster-Car sells them 1/8" OD) or you can drill hole bigger and install a nipple to accept the vent tube. Pump brake fluid up until no more bubbles exit vent tube - - which can be placed in a container so bubbles are clearly visible. Interesting that the Duo uses automotive Dot fluid?? I know the Stemme does also. Schleicher uses the more common (at least in the USA for small GA) Mil Spec 5606 fluid (the good ole red stuff). You cannot mix or substitute the two as 5606 calls for Buna-N seals and O-rings, while Dot fluid takes EPDM rubber seals. Tost buys some US Cleavland brake parts, such as the 30- series caliper, and replaces the Buna-N O-rings with EPDM. The Cleveland calipers, and their early non-anodized pistons, tend to corrode due to moisture as the Dot fluids are hygroscopic. Later pistons, after the mid-90's or so, are anodized, but the caliper bore is still prone to corrode when Dot fluids are used, and this leads to leaks and poor braking. So be sure to check caliper bore condition if using Dot fluids. The long term fix is to sleave the bores with brass liners and anodize the pistons if they're the early ones. bumper MKIV & QV Minden |
On Jan 11, 12:54*am, bumper wrote:
Not on the Duo specifically, but some thoughts none-the-less. Best to use a pressure pot (can be a good quality pump oil can, but better is a small pump-up garden sprayer modified for the job, as this allows some serious through-put to overcome and move out bubbles in high spots). Cycle the brake lever a few times while pumping the fluid up. Note that some installations don't have the brake line going into the caliper at the top, thus there can be a stubborn bubble in the caliper itself. In this case, remove caliper and but a clamp on piston to keep it from coming out. Then bleed with brake line at top. To get more through put, you will need remove all brake fluid from the reservoir with a syringe. Better is to intall a fitting in the existing cap vent hole so you can install a temporary tube to take off the excess brake fluid. Depending on existing cap vent hole, you may be able to use a large hypodermic needle for this (McMaster-Car sells them 1/8" OD) or you can drill hole bigger and install a nipple to accept the vent tube. Pump brake fluid up until no more bubbles exit vent tube - - which can be placed in a container so bubbles are clearly visible. Interesting that the Duo uses automotive Dot fluid?? I know the Stemme does also. Schleicher uses the more common (at least in the USA for small GA) Mil Spec 5606 fluid (the good ole red stuff). You cannot mix or substitute the two as 5606 calls for Buna-N seals and O-rings, while Dot fluid takes EPDM rubber seals. Tost buys some US Cleavland brake parts, such as the 30- series caliper, and replaces the Buna-N O-rings with EPDM. The Cleveland calipers, and their early non-anodized pistons, tend to corrode due to moisture as the Dot fluids are hygroscopic. Later pistons, after the mid-90's or so, are anodized, but the caliper bore is still prone to corrode when Dot fluids are used, and this leads to leaks and poor braking. So be sure to check caliper bore condition if using Dot fluids. The long term fix is to sleave the bores with brass liners and anodize the pistons if they're the early ones. bumper MKIV & QV Minden After replacing the seals on my Discus 2 hydraulic brake, the only way we could bleed the system was to pump upwards from the bottom to remove some stubborn air bubbles. It was a pig to do and took a long time to get it properly working. I have no idea why your syringe would not work, but all of Bumper's suggestions sound good. Mike |
Bumper and Mike thanks for the suggestions. Adding the automatic vent
to the top of the cap sounds like a good move. I have pumped the reservoir full from the bottom and wasn't seeing bubbles, but maybe there is a big one hiding and being able to push more volume sounds like a reasonable start. I have a big syringe from the pet store that probably holds 3x the capacity of the system, but the reservoir at the top becomes the limiting factor. The garden sprayer is another great tip. The caliper is mounted near vertical. I may pull it just to orient it better and eliminate that variable. Thanks again for the suggestions. Morgan |
Good luck . . .
And if it is Dot fluid, be really careful about clean up, given some time this stuff is as good a paint remover as anything else. Once upon a long time ago, I thought I was being fastidious cleaning up and used compressed air to blow out one of the tubes I'd used for bleeding. The little bits of brake fluid spray settled unnoticed on my car hood and fender some 25 feet away. Next morning that car had a serious case of the measels. bumper |
IIRC, note not all Duos have the same setup as SH have
tried to improve it a few times now... On Wednesday, January 11, 2012 11:10:10 AM UTC-5, Morgan wrote: The caliper is mounted near vertical. I may pull it just to orient it better and eliminate that variable. Right, its still got a cavity trapping air in the mounted position. Be careful with the adjustments. Things I have seen, which you REALLY want to avoid: (1) adjustment so that vent in top of master is blocked; this is supposed to be a normally open system. (2) adjustment so that the spoiler travel is restricted; check that the spoilers can come full out (cases some complaints about Duo spoilers !) Hoe that helps, Best Regards, Dave "YO electric" |
On Jan 11, 9:40*am, Dave Nadler wrote:
IIRC, note not all Duos have the same setup as SH have tried to improve it a few times now... On Wednesday, January 11, 2012 11:10:10 AM UTC-5, Morgan wrote: The caliper is mounted near vertical. I may pull it just to orient it better and eliminate that variable. Right, its still got a cavity trapping air in the mounted position. Be careful with the adjustments. Things I have seen, which you REALLY want to avoid: (1) adjustment so that vent in top of master is blocked; this is supposed to be a normally open system. (2) adjustment so that the spoiler travel is restricted; check that the spoilers can come full out (cases some complaints about Duo spoilers !) Hoe that helps, Best Regards, Dave "YO electric" I have a Nimbus which I assume isn't too different regarding the brakes. I rebuilt the entire brake system last winter and found that using the oversize veterinary syringe and pushing fluid from the bottom works well as long as the caliper is off the gear and oriented so that the brake line port points straight up. Schemp does use DOT fluid. I didn't find any severe pitting of the caliper or pistons, but it's worth looking out for. Best regards, Craig |
I'll pull the caliper before my next bleed attempt. I also picked up
a pump bottle and some hardware to potentially make this easier to do solo. My issue is probably made worse by the angle of the glider in the driveway which causes it to sit very high in the cradle making the angle to the caliper even farther off 90. I suspected that might be contributing to the issue, and the comments would confirm that it probably isn't helping. I appreciate all of the feedback and support. Morgan |
On Jan 11, 12:30*am, Morgan wrote:
Looking for advice on bleeding the brakes on my Duo with the tost 30-9 caliper. *I replaced a shot bleeder valve with a new stahlbus valve, but after futzing with the system for over an hour, I can't get the brake to firm up to an acceptable level. I've tried using a suction device to pull fluid (Dot 4 in the Duo) down through the line. *I've also gone with my normal old standby of pushing fluid up through the brake using a syringe. *The Stahlbus valve is not working as advertised or rather the brake isn't. *The brake doesn't seem to be creating enough pressure to overcome the spring tension on the check valve. The best I've been able to get to so far is a fairly spongy grip on the rotor. Enough that turning by hand isn't possible, but it doesn't feel like it would slow you down much when you needed it. Basically it just doesn't feel like the master cylinder is drawing fluid in or maybe there is a hidden air bubble. Any thoughts from the internet hive on the quirks of this beast? It's certainly been a much greater hassle than I expected. *I'm guessing at this point that either there is a trick that I don't know about or something is malfunctioning. Thanks, Morgan Hi All, I have owned a lot of SH gliders and have had success doing the following - unbolt the brake cylinder and raise it up so there is no "loop" in the brake line - so the path from the brake calipers to the brake cylinder goes only uphill - first try to actuate the brake cylinder lever - sometimes this will "burp" the air bubble up into the brake cylinder - otherwise fill fluid from the bottom nipple until the air bubble goes into the brake cylinder reservoir - most times the air bubble will burp into the reservoir and no filling is necessary - good luck, Ralph Woodward |
This pretty much nails what ended up working for me. I ended up
removing the whole system from the ship and flushing it forwards and backwards to make sure there wasn't any old fluid or particles in the system. Popped the piston out and inspected it and the cylinder wall for corrosion and pitting. Overall things looked pretty good, but it got a good cleaning while I was in there. Funny, you'll jump through all sorts of hoops and delays to avoid doing it the "hard way" and in the end that was the least traumatic and fastest way to get it to work. It took me way longer than it should have, but the upside is that I know my braking system inside an out now and it is time for new pads as well. Thanks for the tips. Morgan On Jan 16, 9:23*am, rhwoody wrote: On Jan 11, 12:30*am, Morgan wrote: Looking for advice on bleeding the brakes on my Duo with the tost 30-9 caliper. *I replaced a shot bleeder valve with a new stahlbus valve, but after futzing with the system for over an hour, I can't get the brake to firm up to an acceptable level. I've tried using a suction device to pull fluid (Dot 4 in the Duo) down through the line. *I've also gone with my normal old standby of pushing fluid up through the brake using a syringe. *The Stahlbus valve is not working as advertised or rather the brake isn't. *The brake doesn't seem to be creating enough pressure to overcome the spring tension on the check valve. The best I've been able to get to so far is a fairly spongy grip on the rotor. Enough that turning by hand isn't possible, but it doesn't feel like it would slow you down much when you needed it. Basically it just doesn't feel like the master cylinder is drawing fluid in or maybe there is a hidden air bubble. Any thoughts from the internet hive on the quirks of this beast? It's certainly been a much greater hassle than I expected. *I'm guessing at this point that either there is a trick that I don't know about or something is malfunctioning. Thanks, Morgan Hi All, *I have owned a lot of SH gliders and have had success doing the following - unbolt the brake cylinder and raise it up so there is no "loop" in the brake line - so the path from the brake calipers to the brake cylinder goes only uphill - first try to actuate the brake cylinder lever - sometimes this will "burp" the air bubble up into the brake cylinder - otherwise fill fluid from the bottom nipple until the air bubble goes into the brake cylinder reservoir - *most times the air bubble will burp into the reservoir and no filling is necessary - good luck, Ralph Woodward |
brake bleeding | Pintlar | Home Built | 15 | April 7th 10 03:01 AM |
bleeding brake help | Pintlar | Home Built | 8 | November 7th 09 12:41 PM |
Engine bleeding | [email protected] | Piloting | 4 | December 9th 04 04:38 AM |
Engine bleeding | [email protected] | Piloting | 0 | December 8th 04 09:22 AM |
Bleeding brakes on Tripacer | Corky Scott | Piloting | 2 | July 30th 03 08:11 PM |
