Engine bleeding
Old December 8th 04, 09:21 AM
Default Engine bleeding
What's engine bleeding? I've heard the term a few times before, but
know not what it means, or indeed what its use is.
If I'd to hazard a guess, it must have something to do with wilfully
letting off something - air or fuel, perhaps...
Ramapriya
Old December 8th 04, 05:08 PM
Peter Duniho
"Bob Moore" wrote in message
. 122...
In Jet engines, it is Bleed Air. The compressor section of
the engine produces excess air that can be used for cabin
pressurization or starting other engines.
Same thing for turbocharged piston engines...bleed air from the turbocharger
compressor may be used for cabin pressurization.
Old December 8th 04, 06:27 PM
Brilliant. Now I know where I heard it last. The A320 cap'n who I was
with the other day on the chartered trip was giving me a commentary as
he did the started up the engines. After he revved the first one up, I
remember him saying he'll use the bleed air to start up the other one,
or something to that effect. Don't know why I didn't pursue with him to
know more at the time, but what you mention fits the piece, Bob. Thanks
It was during that cockpit flight that first noticed that both engines
don't get revved up at the same time. In fact, throughout the flight, I
noticed that the fuel consumption figures were slightly unequal because
of one engine's earlier startup. Equally intriguing was the continual
engine performance readout on those digital screens. One more thing I
hadn't known earlier was that pilots actually calculate the extent of
throttle required for takeoff, based on the aircraft loading; I'd
somehow presumed it was always full throttle. On that flight, the cap'n
took off at 90% or so, because there were only 12 souls and almost no
luggage on board
Ramapriya
Old December 9th 04, 04:38 AM
Don Hammer
Normally you use APU bleed to start the engines. If the APU is dead,
you can still dispatch by using a ground air cart to start one engine
then cross bleed to start the other(s). Bleed air from the engines is
used to pressurize the cabin.
luggage on board
It really has very little to do with load by itself, but runway
available and conditions such as runway altitude, temperature, etc.
Most jet aircraft either use one of two power settings, max or reduced
engine pressure ratio (EPR). Reduced on most aircraft is 10% lower EPR
than max. Some large engines use the N1 (fan speed) for power
indication, so I would imagine they set a reduced N1. The reduced
power setting is used to save wear and tear on the engines, if there
is enough available runway for the conditions. Most takeoffs are at a
reduced power even with a full load. One operator's certificate I am
aware of require them to log at least one full power takeoff per month
to ensure the engines can make full power when required.
Most modern aircraft are capable of calculating the required takeoff
distance based on the sensed weight, temperature, etc. and will adjust
the autothrottles to obtain max or reduced EPR or N1 as selected by
the crew.
Each engine is an individual and will be slightly different from any
other in fuel flow, temperature, or rpm at any particular power
setting. Most common is to match N1 to reduce the out-of-sync noise
in the cabin. Everything else will be a slight mismatch.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Engine bleeding [email protected] Piloting 0 December 8th 04 09:19 AM
ROP masking of engine problems Roger Long Piloting 1 September 25th 04 07:13 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
