bleeding Duo Discus brakes
Old January 24th 12, 11:55 PM posted to rec.aviation.soaring
Dan Marotta
Default problems with Cleveland brake calipers
Brake cylinder hone?
"Three Uniform" wrote in message
Changing topic to "problems with Cleveland Brake Calipers"
Thanks Craig for posting Bumpers's link again.
I called Joe at Sierra Specialty Automotive (brakecylinder.com)
He stated that his insurance company does not allow him anymore to
work on aviation parts.
(The part could of course be from a historic tractor)
But more importantly, he concluded that the composition of the
aviation alloys does not match with his process and procedures of
fitting sleeves.
He had to deal with a number of returns.
So, he is not providing this service anymore.
In talking to Joe, another point came up.
The Cleveland caliper has the O-ring on the piston.
The sealing is against the bore in the caliper.
Therefore the surface of the piston is not that relevant, but the
condition of the bore is very much so.
In his opinion, the bore should have a polished finish.
When I dis-assembled mine, it definitely did not have a polished
finish.
Apart from some corrosion, there seemed to be a fine, regular, ringed
structure in the surface of the bore.
Any ideas on this ?
3U
Old January 25th 12, 12:05 AM posted to rec.aviation.soaring
Craig[_2_]
fitting sleeves.
finish.
Any ideas on this ?
3U
I don't think I'd go there unless there is leakage from around the O-
ring. Too much potential for things to go backwards and not much
potential for improvement. The bore surface shouldn't influence how
firm the braking is.
I'd spend my time chasing out:
1. air in the system
2. soft or decayed brake hose
3. flex in the cable bowden leading to the master cylinder
Just my 2 cents,
Craig
Old February 15th 12, 07:47 PM posted to rec.aviation.soaring
Craig[_2_]
Default bleeding Duo Discus brakes
On Jan 24, 8:15*am, Craig wrote:
On Jan 23, 10:03*pm, Three Uniform wrote:
I have nearly the same problem on my V2C. 2 seasons ago I noticed
something dripping from the vent hole in the bottom of the fuselage.
Until then mybrakehad been rock hard. Inspection showed that yellow
brakefluid was leaking from the master cylinder and gum had formed
around the master. Fluid probably 14 years old. I could not find a
revision set and decided to buy a new Magura master (from the
motorcycle store, used on many BMWs). Instead of a 20mm master, I got
a 16mm master.
The 16mm master should only give a bit more travel. Re-installed and
had the same described spongyness. Took the Cleveland caliper apart
and observed significant corrosion on the caliper, less on the piston.
Sanded carefully a bit, installed new O-ring and re-mounted. Still the
spongyness, even after pumping a pint of new clean fluid both ways (up
and down).
Part of the problem is that the piston retracts a bit upon release of
thebrakehandle, instead of taking new fluid from the master
reservoir to fill the void.
I need to do more work before the season starts
Question to Bumper:
Can the brass liners and anodized piston be retrofitted ?
Where ?
3U
I saved this link last time Bumper recommended it.http://www.brakecylinder.com/index.htm
Good luck with the brakes. *You may want to look at replacing thebrakeline. *The one SH used was disintegrating & thebrakeworks much
better after replacing it with a stainless braided unit. *The Hot Rod
crowd has great sources.
http://www.jegs.com/i/JEGS-Performan...archCmd?storeI...
Cheers,
Craig
Just came across this tool for brakes on ebay.
http://www.ebay.com/itm/Pressure-Bra...item3f1396596b
No association with the seller at all.
Craig Funston
Old February 16th 12, 03:44 AM posted to rec.aviation.soaring
Karl Striedieck[_2_]
a 16mm master.
and observed significant corrosion on the caliper, less on the piston..
and down).
Question to Bumper:
Where ?
3U
http://www.jegs.com/i/JEGS-Performan...153/10002/-1?p.......
Cheers,
Craig
Just came across this tool for brakes on ebay.http://www.ebay.com/itm/Pressure-Bra...-Aviation-Car-...
Craig Funston
A method for bleeding the Duo wheel brake may be found on the Soaring
Cafe at http://soaringcafe.com/2012/01/duo-d...ke-adjustment/
brake bleeding Pintlar Home Built 15 April 7th 10 03:01 AM
bleeding brake help Pintlar Home Built 8 November 7th 09 12:41 PM
Engine bleeding [email protected] Piloting 4 December 9th 04 04:38 AM
Engine bleeding [email protected] Piloting 0 December 8th 04 09:22 AM
Bleeding brakes on Tripacer Corky Scott Piloting 2 July 30th 03 08:11 PM
