Rudder Cable Systems Used in Modern Sailplanes
Old May 11th 12, 01:54 AM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default Rudder Cable Systems Used in Modern Sailplanes
There seems to be a fair amount of confusion about the springs used in almost all modern sailplane rudder cables. The springs are there to keep the pedals upright (pulling forward) and to facilitate rudder pedal adjustment through the use of an 'S' tube. Each rudder cable enters the top rear of its 'S' tube and exitsthe lower forward portion of the 'S' tube, then extends on forward another foot or so and is bolted to the square tube that both pedals slide on when adjusting the pedals forward and aft. One can simulate a broken cable by simply grasping one rudder pedal and pulling it aft about 6 inches. The spring on that side will expand and the rudder cable will go slack. The spring on the other side will slam the rudder hard over..........I just did this on my ship. The same is true for Schleicher, Schempp-Hirth, DG, LS and most all sailplanes!
Some things to check on annual inspection:
1. Nylon inner sleeve in place on both 'S' tubes and extending about an inch out both ends of the 'S'tube.(the nylon sleeve keeps the cable from rubbing metel to metal during normal rudder operation and during pedal adjustment.
Old May 11th 12, 02:30 AM posted to rec.aviation.soaring
Ramy
On Thursday, May 10, 2012 5:54:15 PM UTC-7, JJ Sinclair wrote:
There seems to be a fair amount of confusion about the springs used in almost all modern sailplane rudder cables. The springs are there to keep the pedals upright (pulling forward) and to facilitate rudder pedal adjustment through the use of an 'S' tube. Each rudder cable enters the top rear of its 'S' tube and exitsthe lower forward portion of the 'S' tube, then extends on forward another foot or so and is bolted to the square tube that both pedals slide on when adjusting the pedals forward and aft. One can simulate a broken cable by simply grasping one rudder pedal and pulling it aft about 6 inches. The spring on that side will expand and the rudder cable will go slack. The spring on the other side will slam the rudder hard over...........I just did this on my ship. The same is true for Schleicher, Schempp-Hirth, DG, LS and most all sailplanes!
2. Springs in place and pulling equal (I measured 9# spring tension on my Genesis)
3. Adjust the rudder pedals full forward and inspect the cable at the top rear 'S' tube. (this is the most likely place to find cable wear)
4. Adjust the rudder pedals full aft and inspect for cable wear at the point where it exits the lower forward 'S' tube.
5. Inspect the weld that attaches the rudder pedal to the rotating tube at the bottom. In an accident, the pilot may have ended up standing on both rudder pedals as the ship came to an abrupt stop. I have found cracked welds due to this and several AD's have been issued on this problem.
6.Inspect the Nicopress sleeve and inner protective eye (thimble) and the bolt that attaches the cable to the rudder assembly. It must have lock-nut or castlenated nut & carter pin.
7. Inspect as much of the cable runs as you can see and don't forget to check the other end where the cable attaches to the rudder, sleeve/bolt nut or pin.
8. Check rudder stops. They may be at the rudder or on the pedals, but must stop full rudder movement before rudder strikes fin or pedals hit fuselage sides.
Most manufactures recommend not using lube on the rudder cables because it attracts dirt and can lead to unnecessary cable wear, but do lube the rudder pedals and rudder hinges. One more little tid-bit, you can adjust the angle at which the rudder pedals sit by simply making the rudder cables longer..........OK, JJ just how the hell do I do that? By inserting two 1" steel carobeaners in the cable run at the forward attach point. This will make both rudder pedals rotate forward about 30 degrees. Some pilots object to the straight up angle of the pedals in ships like the Duo-Discus. Make sure you still have full rudder movement before rudder pedals hit fuselage side..
Cheers,
JJ A&P for 40 years + owner/operator of glider repair station.
Thanks JJ!
Can rust be also an issue ? After all we can't inspect most of the rudder cable.
Ramy
Old May 11th 12, 03:38 AM posted to rec.aviation.soaring
aerodyne
Most manufactures recommend not using lube on the rudder cables because it attracts dirt and can lead to unnecessary cable wear, but do lube the rudder pedals and rudder hinges. One more little tid-bit, you can adjust the angle at which the rudder pedals sit by simply making the rudder cables longer..........OK, JJ just how the hell do I do that? By inserting two 1" steel carobeaners in the cable run at the forward attach point. This will make both rudder pedals rotate forward about 30 degrees. Some pilots object to the straight up *angle of the pedals in ships like the Duo-Discus. Make sure you still have full rudder movement before rudder pedals hit fuselage side.
Cheers,
Thanks JJ!
Ramy- Hide quoted text -
- Show quoted text -
Great post - not all have S tubes, the cirrus mechanisim uses pulleys
on a sliding rack, as does the 1-34 and perhaps others. Aircraft
cables have a parrafin based lube during mfg, and should not be
cleaned with solvents or relubricated. Rust can occur in severe
situations, but wire breakage/wear in the bends is more commom.
AC43-13 give good examples of wear, damage, repair and acceptable
limits.
I think not only is the "carobeaner" a great idea, but would make a
good name for a health food...
aerodine
Old May 11th 12, 09:42 AM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Cheers,
Thanks JJ!
Ramy
Most aircraft cables are galvanized and should resist rust OK. I have never seen rust that became an issue. A 1/8" cable is rated at more than 1000 pounds, so a little rust is OK, but worn or broken strands are not.
JJ
Old May 12th 12, 12:13 AM posted to rec.aviation.soaring
zulu
Cheers,
Thanks JJ!
Ramy
JJ- Hide quoted text -
When checking the rudder cables for broken strands it is best to use a
soft tissue which will readily snag on the broken strand. Of course
you can use your fingers if you like and if you have any broken
strands they can be easliy seen by the bloody drippings on the cable.
Old May 12th 12, 12:23 AM posted to rec.aviation.soaring
bradley
Cheers,
Thanks JJ!
Ramy
JJ
Have you ever heard of a rudder cable failure? Thanks
Old May 12th 12, 12:37 AM posted to rec.aviation.soaring
Ramy
Cheers,
Thanks JJ!
Ramy
JJ
There are multiple accounts of rudder cable failure discussed in another thread that starts with "Crunch Alert"...
Old May 15th 12, 08:35 AM posted to rec.aviation.soaring
Ramy
Cheers,
Thanks JJ!
Ramy
Checked the rudder cables on my 27 - looking good. But as JJ described, loosening the tension on one side causes a hard over to the other side!
I would like to hear how glider manufactures defends this design! I wonder how many were killed by this design, giving many unexplained spins into the ground from higher altitude. A glider may still be landable without rudder control, but not with a full rudder. Couldn't they come up with a design with a more graceful mode of failure??
Ramy
Old May 15th 12, 02:33 PM posted to rec.aviation.soaring
What would be the consequence of removing the springs from the rudder pedals?
Old May 15th 12, 02:41 PM posted to rec.aviation.soaring
Dan[_6_]
I used to fly competition aerobatics in a Pitts S-1S I built. I
became worried about rudder return springs in that airplane for the
same reasons. Eventually I removed the springs and I actually liked
the feel of the rudder much better.
Dan
ASW 20
WO
Russian defense minister Sergei Ivanov confirms the sale of modern TOR-M1 anti-aircraft missile systems to Iran AirRaid Naval Aviation 1 January 16th 07 05:06 PM
Rudder cable slots Ernest Christley Home Built 5 July 1st 06 04:29 AM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
rudder cable question Bob Loer Home Built 7 November 26th 03 08:34 AM
Rudder cable - was The Little Wheel in Back BD5ER Home Built 9 September 11th 03 04:14 PM
