We will soon be flying our DG1000S. Since many pilots will be flying we will need to have a standardized process for determining the correct tail ballast or front ballast. Does anyone have a work sheet for the DG1000 W&B?
Thanks Phil |
Phil there are a couple suggestions I could make. I don't have a worksheet for a 1000, but it is relatively simple to make one.
Option A if you have a computer at your club that everyone can access, get SeeG from Matt Heron over at http://www.glideplan.com/. It's pretty slick and easy to use and doesn't require much work to set it up. Option B: The old tried and true spreadsheet. If you use a Google Doc spreadsheet, you can open it up on the web to anyone for editing. Option C: Tweak the form and javascript off of our W&B for a 2-33. A bit more technical skill required to alter this, but if you have a hosting location it will give you a shared access point for a quick weight and balance calc. http://www.soaravenal.com/WnB1.htm Option D: Paper calcs. Last I heard, paper and pencil still worked for figuring out CG although I think the last time I did that was on my check ride. Lot's of options once you have the moments to work from. Morgan On Thursday, May 24, 2012 11:39:31 AM UTC-7, wrote: We will soon be flying our DG1000S. Since many pilots will be flying we will need to have a standardized process for determining the correct tail ballast or front ballast. Does anyone have a work sheet for the DG1000 W&B? Thanks Phil |
ASK-21 Weight and Balance | Carl Baxter | Soaring | 4 | June 2nd 11 02:57 PM |
PA-32 Weight and Balance | John Doe | Owning | 14 | May 23rd 06 01:03 AM |
L23 weight and balance | Tony Verhulst | Soaring | 5 | December 31st 05 01:54 AM |
Weight & Balance DVD | jon | Home Built | 0 | October 8th 05 05:39 PM |
Weight and balance.. | Bart | Rotorcraft | 9 | August 19th 03 02:57 AM |
