ASK-21 Weight and Balance
Old May 31st 11, 11:23 PM posted to rec.aviation.soaring
Carl Baxter
Default ASK-21 Weight and Balance
I'm trying to make sense of the weight and balance section in the
ASK-21 manual but having no success. They give an equation for r sub
R, which I assume is the empty CG, but it's not specifically called
out. The units don't balance; there is length on one side of the
equation and length squared on the other. There is an example given
for calculating "inflight CG" and the results seem to be out of
limits but they don't comment so I'm not sure I've got that right.
There is a Load Envelop with Empty Weight on the abscissa and r sub R
on the ordinate. Where does the in flight CG come in? Or is r sub R
also the inflight CG
At 360kg (the nominal empty weight of the aircraft) there is only 8 mm
of CG range within the envelop. Is it really that small? I
understand the Schweizer weight and balance calculations but the
English translation of the Schleicher manual has me puzzled.
Any help would be appreciated. Thanks.
Carl
Old June 1st 11, 12:07 AM posted to rec.aviation.soaring
On May 31, 6:23*pm, Carl Baxter
ASK-21 manual but having no success. *They give an equation for r sub
out. *The units don't balance; there is length on one side of the
equation and length squared on the other. *There is an example given
limits *but they don't comment so I'm not sure I've got that right.
on the ordinate. *Where does the in flight CG come in? Or is r sub R
of CG range within the envelop. *Is it really that small? *I
Any help would be appreciated. *Thanks.
Carl
r sub R is the calculated empty weight CG location relative to the
leading edge of the wing at the root.
It is also shown in the vertical axis of the diagram below.
The manual assumes most pilots will use the diagram, however the
information to calculate flight Cg is avaialable on the following
pages. Note that the only place(that I saw) where rear pilot moment
is shown is in the example calculation. Note that moment values of
pilot masses are negative.
Good luck
UH
Old June 1st 11, 11:10 AM posted to rec.aviation.soaring
Carl
Carl,
Are you simply trying to determine acceptable pilots weights for
flight, or ar you trying to actually understand the German "math".
The way the German two seaters do the weight and balance is kind of
simple for the user, if you don't need to understand how the got to
their conclusions.
What they do is specify a CG range for each possible empty weight.
There is a chart in the manual for this.
As long as your empty CG falls in the acceptable limits of this chart,
then the given pilots weights apply and will fall within limits.
Front pilot: 154 ~ 242
Front pilots less than 154 , use ballast weights as specified, and /
or seat ballast
Rear pilot 0 ~ 242Baggage within posted limit
You must respect gross weight limit
BTW Grob uses a similar un-undertandable W&B in their manual. They
also have an additional section in the manual for USA which tries to
explain the german part....but also not understandable.......
Cookie
Old June 2nd 11, 04:01 AM posted to rec.aviation.soaring
AT
Carl
Carl
The BGA web site has Data sheets for many gliders that are very helpful.
They can be found at
http://www.gliding.co.uk/bgainfo/tec...datasheets.htm
John
Old June 2nd 11, 02:57 PM posted to rec.aviation.soaring
Max Kirschner[_2_]
Carl
Carl
John
I have made up a spreadsheet to show where the C of G is for our K21,
especially useful when using spin wieghts.
The C of G range in mm is
Spinning
Forward limit 234
Forward of 315 Does not spin
320 to385 322 to 385 Incipient
aft 400 400 Sustained spins
Aft limit 469
Flying with the weights confirmed the manual, it was not possible to spin
with the C of G forward of 315 mm
It would incipient with the C of G between 322 and 385.
Being heavy I could not get the C of G aft of 400 to sustain a spin.
If you want a copy of the spread sheet drop me a mail
Regards
Max
PA-32 Weight and Balance John Doe Owning 14 May 23rd 06 01:03 AM
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 01:54 AM
Weight & Balance DVD jon Home Built 0 October 8th 05 05:39 PM
Weight and Balance JP Piloting 2 January 13th 04 10:54 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
