WGC2012 Uvalde Scoring
Old August 15th 12, 05:41 AM posted to rec.aviation.soaring
Darryl Ramm
Default WGC2012 Uvalde Scoring
On Tuesday, August 14, 2012 9:18:13 PM UTC-7, Darryl Ramm wrote:
On Tuesday, August 14, 2012 8:23:39 PM UTC-7, Tony wrote:
On Tuesday, August 14, 2012 10:20:02 PM UTC-5, Jp Stewart wrote:
I am lost, if something happened at 15:24:06 with RB I am missing what it was. No airspace there to bust, just MOAs.
Darryl
I thought that too except I found this interesting about open class day 8 task: "About the open class task:
After 180 km. the pilots enter the cylinder of Toledo. The CENTER of this cylinder is a forbidden airspace are. Pilots were warned to keep an eye on that.The next leg is 79 km. and then back over 112 km.
370 km. [min.299km. max 447 km] and time 2.30"
JP
It was actually Laredo, and 18 meter had a similar task last week where the circle was really a donut, except that Laredo is on the Mexican border so the donut is really about a half donut.
This is all clear as mud.
It was Laredo what? He did not get close to the LOREDO CLASS D. You mean the CRYSTAL MOA centered on Laredo?
What exact time (nearest second) CDST did the violation occur and in what exact named airspace volume (proper FAA name please)? The score sheet says 15:24:06 (presumably CDST). But nothing is occurring exactly at that time. Around 15:19:46 CDST the glider climbs into the LAUGHLIN 2 MOA briefly (base of which is 7,001' MSL, but is just an MOA and therefore not an airspace violation per-se). Around 15:25:34 the glider passes from under LAUGHLIN 2 MOA to under LAUGLIN 3 MOA, around 16:00:12 the glider climbs though 6,000' into LAUGLIN 3 MOA. These are all just MOAs was there a NOTAM/TFR out modifying these or was additional contest airspace restrictions that are not in the airspace files or not FAA NOTAMed? it would really help to make that info available publicly.
See it would just be easir to give a nice precise explanatory answer instead of playing guessing games. Even better if the scorer (yes I know he's damn busy) had made clear what the penalty was and when it actually occurred..
Darryl
OK with my airspace set to the correct M-F ones, not the weekend one, doh. I now see that around 15:24:02 CDST the glider clips the corner of the WGC-MOA-2 airspace claiming to be prohibited in the M-F airspace file. I'm not sure if that actually maps to a prohibited/NOTAMed FAA airspace or more I suspect is a prohibition the CD called.
Thanks
Darryl
Old August 15th 12, 05:52 AM posted to rec.aviation.soaring
David Leonard
Darryl
Its not an FAA airspace violation. Its WGC contest specific. One of the
really active MOAs is prohibited to contest gliders on week days during
the contest. We stay out of their low altitude MOAs and they stay above
us in their other MOAs. An agreement worked out before the contest to
minimize chances of disaster.
ZL
Old August 15th 12, 12:46 PM posted to rec.aviation.soaring
Muttley
If this has been an Airspace infringement the description in the scoring of
"Hazardous Maneuvre" is rather unfair on the pilot and misleading the public
at large.
Old August 15th 12, 01:03 PM posted to rec.aviation.soaring
Ron Gleason
at large.
The wording used is developed and approved by contest management, as scorers we just follow the guide lines.
Ron
Old August 15th 12, 01:47 PM posted to rec.aviation.soaring
Muttley
at large.
Ron
Hi Ron
You are absolutely correct. Annex A Par. 8.7 List of Approved Penalties states under
Dangerous or hazardous flying
(entering forbidden airspace vertically or horizontally)
first Offence outlanded at point of airspace entry.
However I just personally feel that " Airspace violation " may have been a
more appropriate description of the penalty rather than the implied Hazardous
Maneuvre.
Bruno
Old August 15th 12, 02:56 PM posted to rec.aviation.soaring
Ron Gleason
at large.
Ron
Hi Ron
Maneuvre.
Bruno
Agree with you Bruno but I am just an Indian.
WGC2012 Uvalde Launch/Landing and US Team audio feed Tony[_5_] Soaring 12 August 17th 12 04:34 PM
OLC Scoring [email protected] Soaring 2 June 13th 06 03:01 AM
OLC scoring - USA Ian Cant Soaring 18 November 29th 05 07:43 PM
OLC scoring - USA Ian Cant Soaring 0 November 28th 05 03:09 AM
TAT scoring question Mark Zivley Soaring 34 September 6th 04 04:55 AM
