WGC2012 Uvalde Scoring
Old August 14th 12, 02:01 PM posted to rec.aviation.soaring
Muttley
Default WGC2012 Uvalde Scoring
I am just wondering what the closer details of the following are
in the Scoring 18m Class Day 8
RB is scored at 35.9km due to Hazardous Maneuvre. Must have been
serious??
Old August 14th 12, 03:05 PM posted to rec.aviation.soaring
Ron Gleason
serious??
I encourage you to down load the flight log and perform the analysis.
Ron Gleason
Old August 14th 12, 03:29 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
serious??
Ron Gleason
I see a 500' zoomie.
Old August 14th 12, 09:26 PM posted to rec.aviation.soaring
soartech[_2_]
Evan says:
What is a "zoomie" and what's so bad about it?
Old August 14th 12, 09:51 PM posted to rec.aviation.soaring
BobD
On Tuesday, August 14, 2012 3:26:02 PM UTC-5, soartech wrote:
Evan says:
I'm assuming he finished 500' below the finish cylinder edge and zoomed up to kill speed and gain altitude for getting to the pattern. In previous tasks they've declared a 15k cylinder with a 3,000ft minimum altitude base. They do this because weather had forecasted a gust front from approaching T-storms to the north of Uvalde. They want to give the pilot the option to get a valid finish then break off a glide to the airport should the gusts get strong. The breakoff would then be a decision to landout or go to another air strip. Hitting the 15k cylinder and keeping yourself at 3,000agl+ is tricky as most have never done final glides to a target like that. The "zoomie" is dangerous at any finish cylinder because you're zooming up at what might be the majority of gliders finishing above the floor limit. Hence the penalty points.
Old August 14th 12, 09:57 PM posted to rec.aviation.soaring
Tony[_5_]
On Tuesday, August 14, 2012 3:51:22 PM UTC-5, BobD wrote:
On Tuesday, August 14, 2012 3:26:02 PM UTC-5, soartech wrote: Evan says: I see a 500' zoomie. What is a "zoomie" and what's so bad about it? I'm assuming he finished 500' below the finish cylinder edge and zoomed up to kill speed and gain altitude for getting to the pattern. In previous tasks they've declared a 15k cylinder with a 3,000ft minimum altitude base. They do this because weather had forecasted a gust front from approaching T-storms to the north of Uvalde. They want to give the pilot the option to get a valid finish then break off a glide to the airport should the gusts get strong. The breakoff would then be a decision to landout or go to another air strip. Hitting the 15k cylinder and keeping yourself at 3,000agl+ is tricky as most have never done final glides to a target like that.. The "zoomie" is dangerous at any finish cylinder because you're zooming up at what might be the majority of gliders finishing above the floor limit. Hence the penalty points.
the dangerous action was at 15:24, about 14 minutes after he started.
Old August 14th 12, 02:45 PM posted to rec.aviation.soaring
RN
Would appreciate a tip on where you are finding the results.
The "Official" site is showing "Warning: Number of competition pilots
launched is zero "
Thanks
Old August 14th 12, 05:39 PM posted to rec.aviation.soaring
Luke Szczepaniak
launched is zero "
Thanks
The scores are posted on Naviter's Soaring Spot web page
http://soaringspot.com/wgc20112/results/
Cheers,
Luke Szczepaniak
WGC2012 Uvalde Launch/Landing and US Team audio feed Tony[_5_] Soaring 12 August 17th 12 04:34 PM
OLC Scoring [email protected] Soaring 2 June 13th 06 03:01 AM
OLC scoring - USA Ian Cant Soaring 18 November 29th 05 07:43 PM
OLC scoring - USA Ian Cant Soaring 0 November 28th 05 03:09 AM
TAT scoring question Mark Zivley Soaring 34 September 6th 04 04:55 AM
