Butterfly external display questions
Old October 15th 12, 07:20 AM posted to rec.aviation.soaring
bumper[_4_]
Default Butterfly external display questions
On Sunday, October 14, 2012 11:54:47 AM UTC-7, Ramy wrote:
I believe the reason why the brick does not have an audio jack is that it only produces NMEA sentences which are processed by the display which produces the audio alerts.
Ramy
Understood.
But they "could" add the additional circuitry and audio jack to the brick, as they "could" have built in a bright alert LED on the portable (to make it more viable in tow planes etc, without having to wire it into the headset audio).
Neither change is likely as I doubt there's enough demand and they are working on other improvements. I also suggested to them that they provide a lower intensity back light on the portable for night flying (power plane). Lowest it goes now is 10%, which sounds just fine until you try flying with it at night! Lowest setting is still so bright it interfers with night vision.. If they don't fix that in a software revision I'll use some dark static cling plastic over the screen I guess.
bumper
Where are you Butterfly vario? [email protected] Soaring 17 May 25th 14 05:49 AM
Butterfly iGlide Reed von Gal Soaring 4 May 2nd 12 06:00 PM
New Butterfly Vario Paul Remde Soaring 238 February 20th 12 04:05 AM
This Just In- Butterfly [email protected] Soaring 6 February 17th 12 09:00 PM
Ipad compatible bluetooth GPS which has an external antennasocket and external pwr input? macpacheco Instrument Flight Rules 1 November 12th 11 03:32 PM
