On Nov 6, 2:47*pm, Peter wrote:
Alan Browne wrote My main frustration with the iPhone is also the very starved GPS interface. *I'd love to see more of what's going on with the receiver and sats status. *Moreso in the iPhone 4S (which I don't have) that also uses GLONASS. For airborne use I'd get a dedicated aviation receiver - though I can understand the seductive appeal of the iPad for such with its gorgeous larger screen. *Maybe the solution is in a non-Apple tablet? The Samsung Galaxy 10" tablet is the main competitor. Very similar to the Ipad, slightly less slick finger gesture implementation but actually fine for the job. Runs Android. And Oziexplorer exists for Android right now. I'll be ordering the etrex 30 soon. *It uses both GPS and GLONASS. *(Not an aviation receiver). As to your last statement, the iPhone GPS doesn't need to be that good. *It's assisted. *The correlators are driven "lazily" to save power. *My tests of its tracks against a WAAS GPS recorder show (in controlled, open sky areas with good ground truths) 2 - 5 m on the WAAS GPS receiver and 15 - 20 m on the iPhone 4. For VFRing around, the later is sufficient, actually - though not sure how much coverage you would get in some areas. 20m is fine for enroute IFR too. It's just that the GPS has problems keeping a fix once it has got one - something which is quite unusual in the GPS business. If you never read this: http://www.avweb.com/news/pelican/182076-1.html Then you really shouldn't mess with non certified GPS in IFR. If you've read, then you're en enlightened person... My usual ramble follows, the real point is made already... Big fan... John Deakin rules. Learned a ton of stuff you'll never dream of learning from instructors (mostly about aircraft piston engines). Also if you never tried an Anywhere Map device, you really should. Their stuff is sooo much cheaper and leaps and bounds better than Garmin (and traditional competition). They don't force you to buy a new system just to upgrade the software. I used their software 10+ years ago on an Compaq iPaq with an external USB GPS sensor, it worked perfectly. I flew a few "emergency simulation" approaches (with a safety pilot) using their solution instead of an ILS receiver, with better results than what you'll get from your typical run of the mill ILS receiver on old aircraft. Soo much easier to intercept the localizer with precision, and that was before WAAS (I was in Florida back then). For enroute and terminal the real issue is just keeping a lock on the signals, having an up to date database and navigation software that doesn't calculate things wrong. Even 100 meter error isn't an issue. RNP 0.3 is 550 meters, RNP 0.1 is 185 meters (currently RNP 0.3 is the tightest RNP standard used outside of approaches) ! You need to have a huge IONO storm with very few satellites without WAAS to be outside an RNP 0.1 track (vast majority of airliners today can't do better than RNP 0.3). Anyhow if you don't have a certified IFR receiver, radar control will assume your navigating that long direct leg via dead reckoning + VOR fixes, where errors of many nautical miles are the norm. Bottom line is we should be able to use a decent handheld SBAS enabled GPS for enroute and terminal operations. But the FAA certification police will never allow it, due to their usual paranoia. Perhaps a simplified certification procedure. One can wish. Just having your current wind compensated ground track at all times is a huge workload reducing advantage. That alone pays for having a VFR GPS onboard. Marcelo Pacheco |
macpacheco wrote:
Perhaps a simplified certification procedure. One can wish. Wish on. |
F/A-18 external stores load | [email protected] | Naval Aviation | 0 | December 13th 04 09:09 AM |
US external debt up to $6.494 tln | George R. Gonzalez | Military Aviation | 5 | January 8th 04 04:56 PM |
External GPS Antenna | Jim Weir | Owning | 0 | November 29th 03 04:12 AM |
External GPS Antenna | Jim Weir | Aviation Marketplace | 0 | November 29th 03 04:10 AM |
external oxygen port? | Kyler Laird | Owning | 9 | October 3rd 03 04:21 AM |
