#21
How do you plan to take the wind out of the equation?
I have performed succesful tests with wind and thermals (in Condor though, not real life) where by alternating the direction you fly in and then averaging, you get pretty okay results. The only huge flaw I can think of in this setup is the assumption that the wind field is the same for the entire altitude-range. Roel |
Yes, I realized after I wrote the post that calculating LD can't be done without speed, distance and altitude lost. You can figure out feet per minute sink, but then there is the airmass wild card.
The original test with the Cirrus was flown in a straight line at the following IAS. 70, 60, 50, 40. Then I turned the opposite direction and flew the same speed sets. Might be better to fly one speed, do an immediate 180 and fly the same speed. Probably for longer that the 45 seconds per speed that I used. Also realize that TAS has to be computed, ASI calibrated, winds and airmass.. ... Aaron |
I think it was George Moffatt who suggested that a glider designer who claimed a 45:1 L/D should be towed to one mile altitude and released....45 miles OFFSHORE!
#24
That's a good one. They would probably make it to shore, fly to California City, then north to Minden and land back in California city all before sunset.
Standard Cirrus | Walt Connelly | Soaring | 23 | March 20th 11 03:14 AM |
Standard Cirrus C-Hook | Randy[_2_] | Soaring | 26 | September 26th 08 10:24 PM |
Standard Cirrus Group | Jim Hendrix | Soaring | 0 | May 21st 08 03:15 PM |
Standard Cirrus | Don Burns | Soaring | 0 | January 10th 07 05:24 AM |
F/S - Standard Cirrus 75 | Bob | Soaring | 0 | October 4th 04 12:23 AM |
