Low test numbers on Standard Cirrus, what could it be?
Old August 11th 11, 02:59 AM posted to rec.aviation.soaring
akiley
Default Low test numbers on Standard Cirrus, what could it be?
Hi All,
I'm fairly new to soaring, but thought it might be fun to test our clubs Standard Cirrus to see if it was getting advertised L/D. I jumped in with not enough understanding of all the factors that effect performance, other than reading how Dick Johnson does his tests.
I took a tow to 6000 agl on a calm early morning when ground temps were about 70f. I raised the gear, closed both vents and flew one minute legs after I stabilized the IAS at 40, 50, 60 and 70 KIAS. Then I turned in the opposite direction and flew the series again. I video taped the gauges and got an IGC file from SeeYou/iPaq.
I did NOT factor temps and didn't compute calibrated airspeed. My average of both directions at each speed gave me: 26 L/D at 40 KIAS, 26.5 at 50, 28 at 60, and 25 at 70. These numbers seem to be very low for a Standard Cirrus. Johnson's results were in the neighborhood of 35 L/D. It had no bugs, wing root tape, and yes, the gear was up.
Any comments or ideas other than sending me back to school? ... Aaron
Old August 11th 11, 03:37 AM posted to rec.aviation.soaring
Bastoune
Aaron,
A couple of questions regarding the approach used: For the
calculation, did you use the GPS distance and GPS altitude to
calculate the L/D ratio? The altitude reading of the GPS may not give
you the tolerance needed on such a short run. You should loose only
approximately ~150 feet on a minute run at 50kts. This is not much. I
do not know the tolerance on altitude of GPS except that I undertand
that they are often poor. Extending the length of the run (2-3
minutes) may reduce the height measurement errors.
If you used the altimeter, did you have a vibrating gizmo attached to
the case to "free" the needle? My altimeter only moves 100feet at a
time when left to its own...
As for the distance covered, the GPS again my throw things off if
there was some wind. If the run was up and then down the down, the
wind factor could be eliminated from the calculation. If it was a side
wind, it would be very difficult to extract.
No real answer but perhaps areas to explore. Good luck.
Bastoune
Old August 11th 11, 04:29 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
On 8/10/2011 6:59 PM, akiley wrote:
Hi All,
tests.
gear was up.
A 500' drop is a much more common number. With 1 minute runs at best
L/D, you will be dropping about 120 feet, too small to measure accurately.
email me)
Old August 17th 11, 06:10 PM posted to rec.aviation.soaring
John Firth
Hi All,
tests.
gear was up.
accurately.
email me)
AS all the numbers were unreasonably low, I would suspect
general and fairly strong airmass subsidence; Blipmaps will
give you a good estimate of this for NA.
JMF
Old August 11th 11, 06:31 AM posted to rec.aviation.soaring
Alan[_6_]
In article writes:
Hi All,
I'm fairly new to soaring, but thought it might be fun to test our clubs St=
andard Cirrus to see if it was getting advertised L/D. I jumped in with no=
t enough understanding of all the factors that effect performance, other th=
I took a tow to 6000 agl on a calm early morning when ground temps were abo=
ut 70f. I raised the gear, closed both vents and flew one minute legs afte=
r I stabilized the IAS at 40, 50, 60 and 70 KIAS. Then I turned in the opp=
osite direction and flew the series again. I video taped the gauges and go=
I did NOT factor temps and didn't compute calibrated airspeed. My average o=
f both directions at each speed gave me: 26 L/D at 40 KIAS, 26.5 at 50, 28 =
at 60, and 25 at 70. These numbers seem to be very low for a Standard Cirr=
us. Johnson's results were in the neighborhood of 35 L/D. It had no bugs,=
Well, doing it in both directions probably didn't have much effect, since
you were doing it with airspeed, not groundspeed.
The suggestion that you do it for a greater time, such as 500 feet of
altitude, seems good. Since you don't have an engine vibrating the altimeter,
you need to tap it to ensure it isn't lagging behind from minor friction.
Even so, your results will be affected by air motion -- not horizontal wind,
as you are moving with that -- but vertical motion. If you are in an area of
sink, your results will be worse. If in an area of lift, you may get some
really great looking results!
To get an idea of how you did, plot the sink rate polar from your results.
Then compare those points with the published results. I would expect that you
may find an approximate vertical offset showing higher sink rates (shifting
the graph down), if you were testing in sink.
Alan
Old August 11th 11, 03:53 PM posted to rec.aviation.soaring
aerodyne
If you want another set of data, take a look at this video I made of
the Open Cirrus. All the instruments were calibrated, you can see the
30 sec digital averager on the panel top, the timer on the lower left
with the altimeter will give you a timed measurement, and the Winter
on the left is a 2 min averager. This flight is on OLC if you want
the GPS data.
I don't have time to comment on you results, except to say reread the
Johnson and Bikel articles on test measurement.
http://www.youtube.com/user/aerodyne.../2/GJLeuUYbWdM
aerodyne
Old August 11th 11, 07:41 PM posted to rec.aviation.soaring
akiley
the Open Cirrus. *All the instruments were calibrated, you can see the
on the left is a 2 min averager. *This flight is on OLC if you want
the GPS data.
*http://www.youtube.com/user/aerodyne.../2/GJLeuUYbWdM
aerodyne
Thanks, interesting video. I just uploaded my video in two parts.
I'm pretty sure I collected the data correctly. Here is part 1.
http://www.youtube.com/watch?v=MgzhZDN_9RY
Here is part 2.
http://www.youtube.com/watch?v=Ic4DNgox7MA
I find the Excel spreadsheets hard to understand. There is one called
Performance.xls that is a blank. More homework I guess.
.... Aaron
Old August 12th 11, 02:14 PM posted to rec.aviation.soaring
akiley
If anyone's interested in attempting to figure out, or give feedback
on my glide video, I'd be interested in comments. As I mentioned, the
numbers were not good.
Here is part 2.
.... Aaron
Old August 12th 11, 03:58 PM posted to rec.aviation.soaring
Mike the Strike
on my glide video, I'd be interested in comments. *As I mentioned, the
Here is part 2.
... Aaron
Errors in your ASI could account for a good chunk of your problems.
Have you tried a calibration with another known source? With the
knowledge of air density, you can calculate true airspeed and
indicated airspeed from your GPS data.
As others have also mentioned, you don't need much vertical air
movement to screw things up either.
Old August 11th 11, 04:07 PM posted to rec.aviation.soaring
akiley
On Aug 11, 1:31*am, (Alan) wrote:
In article writes:
Hi All,
andard Cirrus to see if it was getting advertised L/D. *I jumped in with no=
ut 70f. *I raised the gear, closed both vents and flew one minute legs afte=
r I stabilized the IAS at 40, 50, 60 and 70 KIAS. *Then I turned in the opp=
osite direction and flew the series again. *I video taped the gauges and go=
at 60, and 25 at 70. *These numbers seem to be very low for a Standard Cirr=
us. *Johnson's results were in the neighborhood of 35 L/D. *It had no bugs,=
Any comments or ideas other than sending me back to school? *... Aaron
* Well, doing it in both directions probably didn't have much effect, since
* The suggestion that you do it for a greater time, such as 500 feet of
altitude, seems good. *Since you don't have an engine vibrating the altimeter,
* Even so, your results will be affected by air motion -- not horizontal wind,
as you are moving with that -- but vertical motion. *If you are in an area of
sink, your results will be worse. *If in an area of lift, you may get some
* To get an idea of how you did, plot the sink rate polar from your results.
Then compare those points with the published results. *I would expect that you
* * * * Alan
Thanks for the help. The longer sample makes sense. I forgot to
mention, I also had a Garmin 396 with WASS so altitude should have
been closer. After looking at the Garmin numbers, it was father off
from the iPaq/SeeYou and the panel altimeter. After a rough graph,
The slower speeds were consistantly worse than the 60 and 70 KIAS
speeds. Anyway, pretty bad numbers, and not very consistent either.
Maybe there was overall subsidence that day. Should have taken temp
readings and saved all that day's weather data.
The plots from my three sources compared to a published excel plot for
a clean Standard Cirrus showed fairly wild inconsistency between
sources mainly due to the Garmin's data. It also shows as mentioned
bad results at 40 and 50 KIAS, slowly getting better and 60 and 70.
Taking notes for next try which I won't get to for at least three
weeks. ... Aaron
Standard Cirrus Walt Connelly Soaring 23 March 20th 11 03:14 AM
Standard Cirrus C-Hook Randy[_2_] Soaring 26 September 26th 08 10:24 PM
Standard Cirrus Group Jim Hendrix Soaring 0 May 21st 08 03:15 PM
Standard Cirrus Don Burns Soaring 0 January 10th 07 05:24 AM
F/S - Standard Cirrus 75 Bob Soaring 0 October 4th 04 12:23 AM
