FS: ECCENTRIC ASSEMBLY TOOLs
Old March 14th 13, 03:45 AM posted to rec.aviation.soaring
SteveB_Z5
Default FS: ECCENTRIC ASSEMBLY TOOLs
For Sale: ECCENTRIC ASSEMBLY TOOLs
Do you have trouble getting your wings in place that last little bit to
insert the wing pins? Then this is the tool you need. The tool fits
lots of different gliders from different manufactures. Known to work on
DG200 and 300, Pegasus, ASW-15, -17, -19 ,-20 (lots),-27, -28 and -29.
Any glider with a pin diameter of 1.41". Other sizes on request
$80 shipping included ($95 out of the US)
Steve
http://www.z5mfg.com/
Old March 14th 13, 02:41 PM posted to rec.aviation.soaring
Papa3[_2_]
I've seen some eccentric assembly tools before. We have one here at Blairstown, and it walks on two legs. It's called a Templin. Guaranteed to get any wings together regardless of make/model. Highly portable. Works on cheap beer.
P3
Steve
Old March 15th 13, 03:44 AM posted to rec.aviation.soaring
SteveB_Z5
P3
Could you arrange to have this tool at Warner Springs ~9:30 Saturday morning? Will have to except payment in good beer.
Steve
Old March 15th 13, 04:40 AM posted to rec.aviation.soaring
JS
Can Bobby keep in shape with expensive beer?
Maybe the Polish Racing Team kknows.
Old March 15th 13, 01:08 PM posted to rec.aviation.soaring
Papa3[_2_]
Steve
There's your first mistake. Anything that costs more than $15.99 for a 30 pack (or for that matter, anything that's not sold in a 30 pack) simply won't work. In fact, you run the risk of upsetting the very delicate equilibrium that's been developed over the last 40 or so years of Bobby's beer drinking. Consequences could be dire indeed.
P3
Old March 15th 13, 01:40 PM posted to rec.aviation.soaring
Tony[_5_]
Round is a shape
Old March 15th 13, 06:21 PM posted to rec.aviation.soaring
JS
On Friday, March 15, 2013 5:40:00 AM UTC-7, Tony wrote:
Round is a shape
And nobody mentioned the nickname that (as far as I know) Captain Kurt Staubach came up with.
Old March 15th 13, 08:52 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
I used Steve's assembly tool all last season and really like. When I first looked at it I felt sure it would get bound up in the first pin hole but just a little twist and it comes right out. Well made and worth it especially if you are using a one man rigger.
-karl
Steve
Old March 17th 13, 01:26 AM posted to rec.aviation.soaring
I agree this kind of tool is useful when one-man rigging, and this approach is very elegant. As an alternative, for the past 20 years I've used a 1" dia. length (about 12"-15") of Delrin or other hard plastic rod (i.e., anything softer than the bore of the spar bushings). When the wings are close but won't quite slide together, I just shove the rod into the bores and lever them the last bit. Obviously this won't work unless they're already fairly close but none of the eccentric tools will, AFAIK. The old Libelle 301 assembly wrench was the exception for two reasons: it grabbed pins glassed into the tops of the fork-and-tongue spars instead of fitting into the bores, and there was no turtledeck fuselage to get in the way so you could get a really wide angle with the wrench. I've seen guys try to lever 301 wings together when the pins weren't even quite engaged (unwise)!
Chip Bearden
ASW 24 "JB"
U.S.A.
Old March 18th 13, 12:47 AM posted to rec.aviation.soaring
SteveB_Z5
Chip Bearden
ASW 24 "JB"
U.S.A.
Chip,
My first 2 gliders both had levers for assembly (Jantar and Libelle) and I can't understand why more manufacturers don't use this method. The tools I make are made from Delrin to be nice to the spar bushings. The tool also protects the bushings from the wear of using the wing pins to bring the bushings into alinement. One would work quite well on your -24.
Steve
FS: Eccentric Assembly Tools SteveB_Z5 Soaring 0 July 28th 12 12:52 AM
FS: Eccentric Assembly Tools SteveB_Z5 Soaring 0 January 21st 12 06:37 PM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 03:45 AM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6973027.jpg [email protected] Aviation Photos 0 April 11th 07 03:45 AM
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6973447.jpg [email protected] Aviation Photos 0 April 11th 07 03:43 AM
