FS: Eccentric Assembly Tools
Old July 27th 12, 11:52 PM posted to rec.aviation.soaring
SteveB_Z5
Default FS: Eccentric Assembly Tools
Do you have trouble inserting your wing pins? If that is the case, this is the tool you need. With the wings almost in place, rotate the tool in the pin bushings and pull the wings into place that last little bit, then instal the main pins. Versions of the tool have been used on 17 different types of gliders from 6 different manufacturers. Info at http://www.z5mfg.com/
FS: Eccentric Assembly Tools SteveB_Z5 Soaring 0 January 21st 12 05:37 PM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6973027.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6973449.jpg [email protected] Aviation Photos 0 April 11th 07 02:43 AM
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6973447.jpg [email protected] Aviation Photos 0 April 11th 07 02:43 AM
