FLARMCFG entry to turn on PowerFLARM brick serial port
Old March 15th 13, 10:38 PM posted to rec.aviation.soaring
kirk.stant
Default FLARMCFG entry to turn on PowerFLARM brick serial port
I've seen both of these in example FLARMCFG files, are they both correct?
# configure D-SUB 9 port
$PFLAC,S,NMEAOUT2,61
$PFLAC,S,BAUD2,2
and
# For brick, turn on output data on DB9 serial port (both GPS and FLARM).
# Needed if you want this data !
# Ignored on portable.
$pflac,s,nmeaout2,1
Kirk
66
Old March 16th 13, 12:28 AM posted to rec.aviation.soaring
Richard[_9_]
On Friday, March 15, 2013 3:38:50 PM UTC-7, kirk.stant wrote:
I've seen both of these in example FLARMCFG files, are they both correct? # configure D-SUB 9 port $PFLAC,S,NMEAOUT2,61 $PFLAC,S,BAUD2,2 and # For brick, turn on output data on DB9 serial port (both GPS and FLARM). # Needed if you want this data ! # Ignored on portable. $pflac,s,nmeaout2,1 Kirk 66
Kirk,
They are correct depending on what you want to set.
$PFLAC,S,NMEAOUT2, 61
Turns on the NMEA output DB9 port 2 and uses Data Port protocol 6 , 1 means it sends sentences GPRMC, GPGGA, GPGSA plus FLARM proprietary sentences (incl. PGRMZ)
$PFLAC,S,Baud2,2
Sets baud rate DB9 port 2 to 19.2K
I use the first set of commands for the Brick.
Richard
www.craggyaero.com
Old March 16th 13, 02:07 AM posted to rec.aviation.soaring
Paul Remde
Kirk,
Richard's note below is correct. In addition, to set to unit to output all
data on the RJ45 port, use:
$PFLAC,S,NMEAOUT1,61 (recommended) or $PFLAC,S,NMEAOUT,61 (works OK too)
Enabling the protocol 6 data is necessary for sending out ADS-B and Mode C/S
data.
Below is a link to a great PowerFLARM Core Configuration File Generation
Tool
http://www.butterfly-avionics.com/in...core-config-en
The default baudrate is 19200 - which is fine for most applications.
Therefore, it is not absolutely necessary to set the baud rate.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_____________________
"Richard" wrote in message
Kirk 66
Kirk,
(incl. PGRMZ)
$PFLAC,S,Baud2,2
Richard
www.craggyaero.com
LX Zeus and PowerFLARM Brick Gabriel Duford Soaring 4 October 4th 12 09:48 PM
Powerflarm Brick feedback Ramy Soaring 7 August 10th 12 01:02 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM 'brick' progress? Frank Paynter[_2_] Soaring 5 November 13th 11 07:28 PM
Display for PowerFLARM brick Andy[_1_] Soaring 4 May 10th 11 02:32 PM
