PowerFlarm: 2.7 Vertical Range
Old April 6th 13, 05:23 PM posted to rec.aviation.soaring
Default PowerFlarm: 2.7 Vertical Range
Does anyone care that the flarm vertical range has been reduced to 500 meters in the new firmware version. Why would the vertical range for ADS-b, and PCAS be more or less unlimited and configurable and the PowerFlarm be limited to 500 meters.
Henry
Old April 6th 13, 08:41 PM posted to rec.aviation.soaring
Craig R.
Henry
Personally, I won't upgrade until this limitation has been removed.
Craig
Old April 6th 13, 10:32 PM posted to rec.aviation.soaring
FLARM
On the (recently introduced) 500m vertical range limitation for FLARM
signals:
Previously the ability to show traffic beyond 500m vertical was a undocumented, unreliable ‘bug’ which could have caused problems with other functions, which is why we removed it.
As this capability is not needed for collision avoidance functionality, it is not a high priority to be implemented properly, but it is definitely on our list.
Highest priority for us is an official IGC/ENL v3.0 release with all the PCAS detection and other improvements we have implemented over the last months.
A Beta version of this should become available within a week; public release before the end of April.
FLARM
Old April 7th 13, 04:36 PM posted to rec.aviation.soaring
son_of_flubber
I'm very happy that FLARM is getting around to removing "features" that are in fact bugs. Thanks for the emphasis on reliability and correctness. This bodes well.
Old April 8th 13, 03:35 AM posted to rec.aviation.soaring
Matt Herron Jr.
Henry
And thank you for reading RAS and keeping us informed of your reasoning, intents and progress! Super supportive
Matt
Old April 8th 13, 08:46 PM posted to rec.aviation.soaring
Ramy
Henry
Matt
I second all the comments and kudos.
But please try to figure out a way to increase the vertical range and make it configurable. the 500m vertical limit, while more than enough for collision avoidance, significantly hinder the buddy flying capability that many of us were hoping to utilize.
Ramy
Old April 9th 13, 01:56 AM posted to rec.aviation.soaring
Okay I'll bite, what does 'bug' in quotation marks really mean? I liked the bigger vertical range too. It allow me to sort targets. If I get an indication of a glider in the area and see a target that is a different glider, but not displayed of Flarm, couldn't that cause confusion?
Why not provide all the information you have?
9B
Old April 9th 13, 02:52 PM posted to rec.aviation.soaring
Andy[_1_]
Version 6.00 of the dataport specification includes this statement:
"Sub-Sentence PFLAC,,RANGE
Syntax: PFLAC,QueryType,RANGE,Value
Meaning: Maximum horizontal distance of aircraft to be processed, in meters.. This affects alarms, NEAREST as shown on the integrated displays, as well as PFLAU / PFLAA messages over the data port. The vertical range cut-off of 500m cannot be changed.
Values: Positive integer values between 2000 and 25500 are allowed, 3000 is the default (3000m). The values will be rounded to the next 100m."
Also it includes "PFLAA sentences are limited to other aircraft with a horizontal distance of less than the configured horizontal range (default is 3km) and a vertical separation of less than 500m. Non-moving aircraft are suppressed."
Data port specification V4.06e also includes the PFLAA vertical range limitation "PFLAA sentences are limited to other aircraft with a horizontal distance of less than the configured range (default is 3km) and a vertical separation of less than 500m. Non-moving aircraft are suppressed."
V4.06e does not appear to include "The vertical range cut-off of 500m cannot be changed." and this was added between version 4. and version 6.
I could not find any sentence that allowed the specification of FLARM vertical range to be changed, and that is consistent with it being a fixed value..
Unfortunately, my portable is out for the modification that will make it useless in my native UK so I can't check if FLARM vertical range was a menu selection.
Anyone that expected more than 500m FLARM vertical range probably didn't read the available documentation and was perhaps mislead by the hype.
Andy (GY)
Old April 9th 13, 11:27 PM posted to rec.aviation.soaring
son_of_flubber
Explain
PowerFlarm Range Analysis Richard[_9_] Soaring 0 March 25th 13 04:43 PM
PowerFLARM Range Issues - Part Two with info from todays flights Mark Soaring 34 October 20th 12 08:21 PM
PowerFlarm BRICK range issues - are we alone???? Mark Soaring 79 October 17th 12 12:17 PM
PowerFLarm expected range [email protected] Soaring 6 August 30th 12 03:43 PM
long range aircraft flying short-range routes? tupolev204 Piloting 10 April 22nd 11 07:44 PM
