long range aircraft flying short-range routes?
Old March 15th 11, 10:40 PM
tupolev204 tupolev204 is offline
Junior Member
First recorded activity by AviationBanter: Mar 2011
Default long range aircraft flying short-range routes?
Hi, this is my very first post.
As you see, Im a bit of Tupolev fan hehe, and would like if someone could give me some clearity on this.
TU 204-300 has a capacity of 142 pax. and can fly non stop between Moscow - Vladivostok, which is about 6.500km
Could this airplane be easily used for short routes, like the A320 which has also about 150 pax. (business + economy).
Or is it really requierd to have an airplane specially designed for short routes fly only on those?
Thanks in advance for your replies!
Old March 16th 11, 05:35 AM posted to rec.aviation.piloting
Orval Fairbairn[_2_]
Of course, it would work! All you have to do is reduce the fuel load to
do the shorter routes.
Old March 16th 11, 05:11 PM posted to rec.aviation.piloting
150flivver
On Mar 15, 11:35*pm, Orval Fairbairn
TU 204-300 *has a capacity of 142 pax. and can fly non stop between
Certainly it is possible to use a long range aircraft on short
routes. The real question is whether it is economical to fly long
range aircraft on short range routes. I don't know the specific
figures for a TU 204-300 vs. an A320 so I can't make an informed
opinion but my gut feeling is with cost of fuel escalating, an
aircraft needs to be specifically optimized for the routes it will fly
to be economically viable.
Old March 16th 11, 08:51 PM
Junior Member
Thanks for your replies!!
Yes, I understand now a little bit more, thanks! :-)
Old March 19th 11, 09:31 PM posted to rec.aviation.piloting
Brent[_2_]
I have seen a 777 do a short range hop (under 200NM) but i beleive some
investigations revealed that this short multi time per day hop had had the
two flights before it cancelled on mechanicals (777's stick out like sore
thumbs in tha airport i train at)
"150flivver" wrote in message
On Mar 15, 11:35 pm, Orval Fairbairn
Old April 9th 11, 02:20 PM
lesNeelagep lesNeelagep is offline
Banned
male pattern baldness is a condition that affects the hair follicles, which are
male pattern baldness part of the skin from which hairs develop. In most instances, hair falls out in compact, round patches about the dimension of a quarter. The extent of the hair reduction
itchy scalp varies in some situations, it is only in a very few spots. In people, the hair loss can be higher. From time to time it can entail the total scalp (alopecia totalis) or even all the human body and scalp (alopecia universalis). It is not achievable to predict how considerably hair will be misplaced. Regrowth of hair in standard alopecia areata is normal more than a period of time of months or, often, a long time, but won't be able to be guaranteed. The hair at times regrows white at least in the very first instance. Even more hair loss is not unheard of. In alopecia totalis and alopecia universalis the likelihood of complete regrowth is less.
Old April 9th 11, 02:22 PM
Banned
itchy scalp is a sickness that affects the hair follicles, which are
itchy scalp component of the skin from which hairs expand. In most situations, hair falls out in small, round patches about the size of a quarter. The extent of the hair reduction alopecia areata varies in some situations, it is only in a number of spots. In other people, the hair loss can be better. Sometimes it can entail the whole scalp (alopecia totalis) or even all the physique and scalp (alopecia universalis). It is not attainable to predict how substantially hair will be misplaced. Regrowth of hair in common alopecia areata is regular about a period of months or, at times, years, but can't be assured. The hair sometimes regrows white at minimum in the initial instance. Additional hair reduction is not unusual. In alopecia totalis and alopecia universalis the probability of complete regrowth is much less.
Old April 9th 11, 02:23 PM
Banned
itchy scalp is a sickness that influences the hair follicles, which are alopecia areata aspect of the skin from which hairs develop. In most scenarios, hair falls out in small, round patches about the size of a quarter. The extent of the hair reduction
male pattern baldness varies in some circumstances, it is only in a number of spots. In others, the hair reduction can be greater. From time to time it can involve the whole scalp (alopecia totalis) or even all the human body and scalp (alopecia universalis). It is not probable to predict how a lot hair will be lost. Regrowth of hair in regular alopecia areata is standard around a time period of months or, often, years, but won't be able to be guaranteed. The hair in some cases regrows white at least in the initially instance. Even more hair reduction is not uncommon. In alopecia totalis and alopecia universalis the probability of total regrowth is less.
Old April 9th 11, 02:25 PM
Banned
itchy scalp is a disease that affects the hair follicles, which are alopecia areata part of the skin from which hairs develop. In most circumstances, hair falls out in little, round patches about the size of a quarter. The extent of the hair reduction
alopecia areata varies in some circumstances, it is only in a several spots. In other folks, the hair reduction can be higher. Sometimes it can include the total scalp (alopecia totalis) or even all the body and scalp (alopecia universalis). It is not feasible to predict how considerably hair will be misplaced. Regrowth of hair in typical alopecia areata is normal more than a time period of months or, from time to time, years, but cannot be guaranteed. The hair in some cases regrows white at minimum in the initial instance. Further hair loss is not unusual. In alopecia totalis and alopecia universalis the probability of total regrowth is significantly less.
Old April 22nd 11, 06:47 PM posted to rec.aviation.piloting
Jessica Powell
Air France was flying A380s between Paris and London last summer. They
were doing this to get some revenue out of their aircraft that otherwise
had over 11 hours to sit at CDG/LFPG between flights from/to
Johannesburg. That's a very short flight for a long haul aircraft, but
I don't think they are doing this currently. It probably takes more
time to load/unload the passengers than flight time.
Long range Wx Paul kgyy Instrument Flight Rules 4 December 31st 04 05:25 PM
Long range Wx Paul kgyy Piloting 4 December 31st 04 05:25 PM
Long Range Spitfires??? ArtKramr Military Aviation 3 September 9th 03 11:05 PM
Helicopter gun at LONG range Gordon Military Aviation 17 August 20th 03 03:14 AM
Helicopter gun at LONG range Tony Williams Naval Aviation 3 August 20th 03 03:14 AM
