Glider knowledge test questions in searchable form
Old June 1st 13, 04:30 PM posted to rec.aviation.soaring
Thin Air
Default Glider knowledge test questions in searchable form
Looking for the entire catalog of knowledge test questions (650+) in a format that can be keyword searched (.pdf, .txt, etc.).
I've found several links (even on FAA website) but all end up broken.
Any help would be appreciated.
Thanks
JB
Old June 1st 13, 04:43 PM posted to rec.aviation.soaring
Dan Marotta
Well, this one works:
http://www.faa.gov/training_testing/.../media/pvt.pdf
and this one:
http://www.air.flyingway.com/faa_exa...itten_exam.htm
"Thin Air" wrote in message
Thanks
JB
Old June 1st 13, 04:52 PM posted to rec.aviation.soaring
Thin Air
Thanks Dan, but neither of those are from the glider bank, but rather the private pilot bank. While there is quite a bit of overlap between those two, there is also significant differences.
Still searching.
JB
Old June 1st 13, 05:42 PM posted to rec.aviation.soaring
son_of_flubber
Last year I asked for a 700 +/- question long test from one of the on line testing services, then I cut and pasted from the browser window to notepad to produce a text file of the entire question bank. Quite easy.
A text file is searchable. I don't have the file and I don't remember the source.
Old June 1st 13, 05:48 PM posted to rec.aviation.soaring
Thin Air
Thanks for the suggestion.
I did purchase the Dauntless (checkride.com) software and while it contains the entire question bank, it will not output the questions in any searchable format.
JB
Old June 1st 13, 05:58 PM posted to rec.aviation.soaring
son_of_flubber
This is where I scrapped the entire glider question set
http://www.exams4pilots.org/
Got 98% on the exam.
Old June 1st 13, 06:24 PM posted to rec.aviation.soaring
Thin Air
Thanks for that. That is EXACTLY what I wanted except for the fact that it only has about 75% of the question pool (~480 out of ~660 questions).
Still searching for a complete (or at least nearly complete) set.
Thanks
JB
Old June 1st 13, 06:40 PM posted to rec.aviation.soaring
Also take a look at webexams.com.
Old June 1st 13, 06:53 PM posted to rec.aviation.soaring
Some we have used at CISS
http://exams4pilots.org/faatest.cgi?m=2
http://www.webexams.com
http://preparetotest.com (not free)
Not sure if these meet your criteria
Old June 1st 13, 07:12 PM posted to rec.aviation.soaring
Thin Air
Thanks, found that earlier but no glider bank that I can find.
JB
FAA Knowledge Test for PPGL JSoar Soaring 7 February 17th 12 06:43 PM
Form One Questions jcarlyle Soaring 12 November 28th 09 11:10 PM
Passed CFI Knowledge Test Kobra Piloting 10 August 6th 08 02:37 AM
FAA Knowledge test Dave Piloting 15 October 31st 03 07:32 PM
FAA Knowledge Test Results Richard Moore Instrument Flight Rules 4 October 12th 03 08:10 AM
