Form One Questions
Old November 26th 09, 04:06 PM posted to rec.aviation.soaring
jcarlyle
Default Form One Questions
I’ve got two questions for European pilots regarding the Form One,
arising out of curiosity on my part.
First, it appears to this US pilot that one of the uses of a Form One
is to certify that a new part is airworthy, with the basis for
airworthiness being that the part was made in accordance with a TSO or
some other approved technical specification. Is this correct?
Second, why would a plane made in Europe not have a Form One for all
installed equipment? Isn’t it necessary to certify that all of a new
aircraft’s equipment is airworthy? I ask because my LS8-18 (made in
2000) has Form Ones for the 4-point harness, nose hook, CG hook, main
wheel hub and brake, airspeed, altimeter, VHF radio, ELT and
transponder antenna. No Form Ones at all were supplied for the
transponder, encoder, SN10, Sage vario or VHF antenna. It isn’t a
matter of loss, because I have all of the Form Ones listed on the
original LS document transmittal letter.
-John
Old November 26th 09, 08:05 PM posted to rec.aviation.soaring
Robert Danewid
Well John..... usually Europe is far ahead of US in most respects, but
you have just discovered one area where we are way behind you
yanks...... our governments just love "bureaucrazy"!
Robert
ASW 28-18E
-John
Old November 28th 09, 05:33 PM posted to rec.aviation.soaring
ASM
On Nov 26, 12:05*pm, Robert Danewid
Robert
ASW 28-18E
jcarlyle skrev:
Oh really? Where?
Jacek
Old November 28th 09, 10:10 PM posted to rec.aviation.soaring
Darryl Ramm
Robert
ASW 28-18E
jcarlyle skrev:
Oh really? Where?
Jacek
Ah for starters the value of their currency.
Darryl
Old November 26th 09, 08:45 PM posted to rec.aviation.soaring
John Smith
Roughly said, yes. EASA Form 1 ist the exact equivalent of the FAA Form
8130–3, it even has the same blocks. (And EASA honors FAA 8130-3 forms.)
Form 1 (or an equivalent certificate) is only required for required
equipment.
I'm not sure how transponders, radios and ELTs are handled because they
are not required but must be approved somehow.
Old November 26th 09, 10:06 PM posted to rec.aviation.soaring
Robert Danewid
I have a Form One for both my radio and transponder.
/Robert
equipment.
Old November 27th 09, 12:59 PM posted to rec.aviation.soaring
jcarlyle
Who determines "required equipment" for Form One? I've got Form Ones
for things that aren't on either the Minimum Equipment List or the
Master Equipment List, while I'm missing Form Ones for things that ARE
on the Minimum Equipment List! Seems very haphazard - maybe it is a
"bureaucrazy"...
-John
equipment.
Old November 27th 09, 01:35 PM posted to rec.aviation.soaring
John Smith
"bureaucrazy"...
You can have your wrist watch TSOed if you wish and pay for it, but it
isn't required.
On the other hand, even TSOed instruments don't nessecairily come with a
Form 1. They most probably will today, but Form 1 is just a standardized
format for describing to which TSO a given aircraft part conforms, but
you can ask the manufactorer to confirm this in handwriting on the back
of a used envelope if you prefer this. This won't make anybody's life
easier, though. And don't forget that Form 1 didn't even exist a couple
of years ago, so the TSO certification of older instrument will most
probably have some random format unless they have been overhauled recently.
On yet another hand, you can even fill out a Form 1 also for non-TSOed
parts, if you like. Just leave block 13 empty or fill in: not TSOed.
Old November 27th 09, 02:47 PM posted to rec.aviation.soaring
jcarlyle
Appreciate the additional information, but you sidestepped the
question.
You said earlier "Form 1 (or an equivalent certificate) is only
required for required equipment." I said earlier "I'm missing Form
Ones for things that are on the Minimum Equipment List!"
The MEL defines required equipment, doesn't it? If not, what IS the
definition of "required equipment" used to trigger the use of a Form
One?
-John
isn't required.
Old November 27th 09, 03:07 PM posted to rec.aviation.soaring
John Smith
Yes, of course. But frankly, I'm no aviation attorney and even if I were
I couldn't comment on a glider I have never seen.
Air Force Form 181? Yossarian Piloting 7 April 16th 05 06:00 AM
Request for a 337 form MC Soaring 12 March 11th 05 03:56 AM
FAA form 337? Paul Lee Home Built 15 February 1st 04 07:17 PM
Mylar "form 1" vs "form 2" John Soaring 1 November 27th 03 01:20 AM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 06:06 AM
