Clear Yaw string tape?
Old August 27th 13, 07:50 PM posted to rec.aviation.soaring
Discus 44
Default Clear Yaw string tape?
There is a good chance that using RTV for attaching a yaw string could lead to a permanent mark on the canopy. Most of the RTV's have Acetic acid and formaldehyde and a list of other chemicals that may leave a blemish. I would not recommend using it. Acetic Acid is a component of Acrylic adhesive BTW.
Tom
Discus44
  #33
Old August 28th 13, 01:15 AM posted to rec.aviation.soaring
bumper[_4_]
On Tuesday, August 27, 2013 8:05:19 AM UTC-7, John Godfrey (QT) wrote:
On Tuesday, August 27, 2013 9:54:28 AM UTC-4, wrote:
I have had very satisfactory service from my MK3 and MK4 yaw strings.
Nice clear adhesive patch that can be removed from the canopy without leaving a mark. Very satisfying triangular shape to the adhesive patch gives me a very warm feeling inside whenever I examine it during flight.
Also, very excellent customer service. One time at Minden I was having some questions about the length and responsiveness of the fibrous indicating structure and the company representative drove up to my plane and addressed my concerns in less than one hour from the telephone call.
My understanding is that clear yaw string tape can only be safely used with clear yaw strings
QT
QT,
You will be pleased to learn that the new MKIV.1a "high tech", "clearly invisible", imaginary yaw string is in stock, on sale at 50% off, and ready for immediate non-shipment. Just clean a spot for it on your canopy, send payment, and enjoy! :c)
bumper
zz
QV & MKIV
  #34
Old August 28th 13, 01:28 AM posted to rec.aviation.soaring
bumper[_4_]
On Tuesday, August 27, 2013 11:13:16 AM UTC-7, Eric Greenwell wrote:
Unfortunately, the dealer network is very thin. Just try getting your
string serviced in Washington State!
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Eric,
Quit complaining and move to Nevada. Besides superb soaring conditions, you can get your string serviced in less than an hour. Also, being Nevada, I hear you can get almost anything else serviced too . . . though I wouldn't know about that.
bumper
  #35
Old August 28th 13, 02:49 AM posted to rec.aviation.soaring
SteveB_Z5
Phil Jeffery wrote
Does anyone know who still supplies these canopy holes?
As the maker of fine glider assembly tools, I'm sure we at http://www.z5mfg.com/ can supply you with what ever hole you need.
Steve
  #36
Old August 28th 13, 04:33 AM posted to rec.aviation.soaring
Tony V
On 8/26/2013 9:04 PM, Uncle Fuzzy wrote:
Personally, I just WON'T use anything other than Bumper's setup.
Yeah, well I have serious reservations. I just don't think it's quite
fully developed and requires more engineering. I'm thinking of a remote
control for calibration of the device. The constant pointing to one side
or the other is quite unacceptable.
Tony "6N"
  #37
Old August 28th 13, 06:03 AM posted to rec.aviation.soaring
bumper[_4_]
Tony "6N"
Well, Tony, I don't know what to say. I'll admit that some earlier MK's inadvertently were shipped with an open loop feedback system. And some did not receive proper training before being sent to meet "their glider". This was quickly rectified in production and all new MKIV's come with extensive primary* training and a closed loop system that cleverly monitors relative wind and also accepts inputs from all flight control surfaces with a rather strong rudder bias. This insures that the MKIV will always point in a direction while in flight.
Some manufacturers might not admit it, but since we have a transparent operation here, in the interest of full disclosure we have uncovered a bug in our software and are working on a patch or exorcism or something. Only seen this on strong thermal days at Minden, some MKIV's will inexplicably act possessed, spinning rapidly and often pointing straight up. We think they are being affected by karma or force fields from the airport wind sock, which purportedly is also pointing straight up and twisting rapidly during such times. For all we know, it could be possessed as well. There is little risk to pilots as most are well clear, circling at cloud base during these troubling moments.
*Advanced training is the owner's responsibility. Repetitive training works best, with frequent flights being an excellent way to insure your MKIV doesn't go stupid and forget how it's supposed to behave.
bumper
  #38
Old August 28th 13, 06:16 AM posted to rec.aviation.soaring
Uncle Fuzzy[_2_]
'calibration is vastly over-rated! Starch, on the other hand.....
Tony "6N"
  #39
Old August 28th 13, 05:43 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
QT
QT,
bumper
zz
QV & MKIV
I'd jump on this is a heartbeat except for all the comments I would have to endure about the king's new yawstring...
  #40
Old August 30th 13, 03:14 AM posted to rec.aviation.soaring
Echo
On Wednesday, April 12, 2006 11:57:34 AM UTC-5, Bruno wrote:
I have seen a few gliders that had yaw strings attached with something
other than the white tape most of us use. It was either a clear tape
or clear sticker. If any of you use something other than the white
tape to attach your yaw string please share what you use. Thanks!
www.sailplanestickers.com I think it is...
60 Year Old Duct Tape Jay Honeck Piloting 11 January 15th 06 06:52 PM
Gap Tape TJ Soaring 0 October 22nd 05 04:18 AM
Teflon gap seal tape... Marc Ramsey Soaring 10 April 3rd 05 04:35 PM
BrandNew-Vector Heavy Duty Plastic Construction Tape Dispenser 13 Peaces Left [email protected] Aviation Marketplace 0 April 29th 04 11:43 PM
TURBULATOR TAPE ON VENTUS B Ventus B Soaring 5 February 18th 04 08:27 PM
