Clear Yaw string tape?
Old April 12th 06, 05:57 PM posted to rec.aviation.soaring
Default Clear Yaw string tape?
I have seen a few gliders that had yaw strings attached with something
other than the white tape most of us use. It was either a clear tape
or clear sticker. If any of you use something other than the white
tape to attach your yaw string please share what you use. Thanks!
Old April 12th 06, 06:58 PM posted to rec.aviation.soaring
Scotch clear packing tape. Cut it into a little triangle (for style
points), stick the yarn on (I prefer green - with a knot at both ends),
and carefully place dead center on canopy, as far back as you can
stand.
Doesn't shrink or leave much residue like white tape. And you can
kinda see through it...
I also it to cover the big horizontal tail attachment opening on my LS6
- one piece fits perfectly.
Kirk
66
Old April 12th 06, 08:37 PM posted to rec.aviation.soaring
Nyal Williams wrote:
I have seen a glider that had a very small, round hole
for the yaw string drilled in the canopy. The owner
tied knots inside and out, tighly against the hole.
That was probably 35 years ago and I don't remember
what or who. I would not recommend it.
Kinda suck when, after your buddies ask why you fly slow and sideways,
you realize you drilled 1 cm to starboard.
Shawn
Old April 12th 06, 09:18 PM posted to rec.aviation.soaring
I saw one stuck on with a drop of clear RTV (silicone rubber). When I
asked about it, the owner said it stuck up into the airflow a bit
better and was a little more responsive. He also commented that he
didn't fix his gaze on it nearly so often as the little triangle of
white tape that he used in the past. I think I'll try that soon, unless
someone tells me that the RTV will damage my plexiglass.
Jack Womack
PIK-20B N77MA (TE)
Old April 13th 06, 02:47 AM posted to rec.aviation.soaring
My partners and I used to keep our yaw string suspended about 3/4"
above the surface on a piece of wire bent to shape and taped into
place. It gave a little better precision by keeping the string out of
the canopy's boundary layer, which was prone to a bit of hysteresis.
However, we eventually decided it wasn't enough of an improvement to
offset the pain in the butt of removing it every time we put the
canopy cover on, so we gave it up.
Just be sure you use *metric* yaw string on a German ship.
rj
Old April 13th 06, 04:21 PM posted to rec.aviation.soaring
Does anyone know who still supplies these canopy holes?
"Nyal Williams" wrote in message
At 18:00 12 April 2006, wrote:
with something
either a clear tape
than the white
use. Thanks!
(for style
knot at both ends),
as you can
stand.
And you can
opening on my LS6
Kirk
66
Old April 13th 06, 09:21 PM posted to rec.aviation.soaring
Are you looking for the EASA approved ones or the traditional ones ?
"Phil Jeffery" wrote in message
message ...
Old April 14th 06, 12:56 PM posted to rec.aviation.soaring
Milspec holes are the best, but expensive.
Hard to find now, due to extensive use in Iraq and Afghanistan -
especially the 5.56 and 7.62 mm sizes.
Kirk
60 Year Old Duct Tape Jay Honeck Piloting 11 January 15th 06 06:52 PM
Gap Tape TJ Soaring 0 October 22nd 05 04:18 AM
Teflon gap seal tape... Marc Ramsey Soaring 10 April 3rd 05 04:35 PM
BrandNew-Vector Heavy Duty Plastic Construction Tape Dispenser 13 Peaces Left [email protected] Aviation Marketplace 0 April 29th 04 11:43 PM
TURBULATOR TAPE ON VENTUS B Ventus B Soaring 5 February 18th 04 08:27 PM
