FYI, the exe appears to be faulty...
;-) Sean |
On Thursday, September 26, 2013 8:44:09 PM UTC-5, Sean F (F2) wrote:
FYI, the exe appears to be faulty... ;-) Sean Mine update works fine. Flew with it last Saturday. |
On Thursday, September 26, 2013 6:44:09 PM UTC-7, Sean F (F2) wrote:
FYI, the exe appears to be faulty... ;-) Sean I just updated an Oudie and all worked OK. Try a different browser. 4.51.004 Richard www.craggyaero.com |
Sean - I assume you are talking about the 4.5 update. Some significant changes in this release.
No problems getting it installed for 4.5 or any of the previous updates. Maybe your download was bad for some reason. Try, try again! Poke around on http://forum.naviter.com to see if others are having issues and/or post a message. Let us know what you find. Good luck. - John |
Gremlins I guess. Will try again this evening!
Sean |
Hi Sean,
Did you copy the file to the root directory of the Oudie or try to run it on your PC? You must either copy it to the root directory of the Oudie or put it in the top level directory of a microSD memory card. Then reboot the Oudie. Best Regards, Paul Remde Cumulus Soaring, Inc. ___________________________ "Sean F (F2)" wrote in message ... FYI, the exe appears to be faulty... ;-) Sean |
Make sure the file name has not changed. Last time I downloaded through chrome twice and it labeled the file as a copy with a (1) added in it would not load.
Kerry |
For me, I tried to download it DIRECTLY to the root of the oudie, and when updating, it said it was corrupt. However I tried downloading it to my hard drive, then copying to the oudie, and that worked fine. Maybe that's it
On Friday, September 27, 2013 3:26:58 PM UTC-5, Paul Remde wrote:
Did you ... try to run it on your PC? Paul Remde Cumulus Soaring, Inc. I think that Paul may be on to something. If you run the EXE on your computer you do get Sean's exact error message, "...blah is not a valid Win32 application." |
PowerFLARM Files not valid with OLC | Tim Taylor | Soaring | 5 | June 22nd 13 05:30 AM |
Oudie not making valid IGC files | Tony[_5_] | Soaring | 2 | May 31st 11 05:44 AM |
Valid OLC log out of SN-10b | Jim Archer | Soaring | 4 | June 11th 08 11:46 PM |
Valid OLC log out of SN-10b | Jim Archer | Soaring | 0 | June 11th 08 06:43 AM |
Airworthiness Cert Still Valid? | Carl Orton | Owning | 12 | February 13th 04 10:21 PM |
