Valid OLC log out of SN-10b
Old June 11th 08, 07:43 AM posted to rec.aviation.soaring
Jim Archer
Default Valid OLC log out of SN-10b
I cannot get a valid OLC flight out of my SN-10b. I purchased the glider a
few months ago, have flown a few flights and all are invalid on OLC.
Prior to download the SN-10 security routine runs and approves the file.
OLC tells me the file error message on his end says Signature Missmatch
and he believes that it is a software issue, recommending me to get the
original software that came with the SN-10, install it and try again.
Unfortunately I don't think I can do that, bought a used glider with the
SN-10 already installed.
All of the SN-10 data transfer utilities I'm using for the SN-10 I
downloaded off the internet, pasted it onto the club laptop that I use to
download. So my question is, does anyone have a similar experience with
their SN-10b? Is it possible that I need to download the software off the
internet onto the actual computer I use for downloading? Will loading the
software differently somehow help? Anything else that it might be?
Thanks for any help,
Kestrel #33 OZ (yes it flies again)
Old June 11th 08, 01:39 PM posted to rec.aviation.soaring
Paul Remde
Hi Jim,
Check to see what firmware version the SN10b is running. If it is not
version 2.31 you can get a free upgrade he
http://www.ilec-gmbh.com/software.htm
That is likely to fix the problem.
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Jim Archer" wrote in message
Old June 11th 08, 10:58 PM posted to rec.aviation.soaring
Jim Archer
Thanks Paul, I am in the middle of doing that right now, I was running
2.22...
At 11:39 11 June 2008, Paul Remde wrote:
Hi Jim,
Paul Remde
glider
a
file.
Missmatch
to
with
Old June 11th 08, 11:13 PM posted to rec.aviation.soaring
Jim Archer
2.22...
Hi Jim,
Paul Remde
glider
a
file.
Missmatch
to
with
Old June 12th 08, 12:46 AM posted to rec.aviation.soaring
The ILEC SN10 is not an IGC-approved secure logger,
so you will not get a "green smiley" on OLC for a log
produced by an ILEC SN10. The flights are not "invalid",
they are just at a "different security level". See:
http://www.onlinecontest.org/olc-2.0..._jsp=rules_olc
for an explanation.
If you are having a problem different than this, please
post (or contact me) a more precise discussion of the
issue you see...
Hope this helps,
LX20-Secret Key Not Valid! Ken Ward Soaring 6 April 29th 06 09:22 PM
Enroute charts valid for use in Canada? Andrew Sarangan Instrument Flight Rules 3 June 3rd 04 07:34 PM
Airworthiness Cert Still Valid? Carl Orton Owning 12 February 13th 04 11:21 PM
