What is magical about a 45 degree bank?
Old October 6th 13, 06:47 PM posted to rec.aviation.soaring
Dan Marotta
Default What is magical about a 45 degree bank?
If you haven't already read it, you should also look at "Streckensegelflug"
by Helmut Reichmann:
http://www.amazon.com/Streckensegelf.../dp/3613024799
"son_of_flubber" wrote in message
Thank you for the recommendations made here. I've just ordered copies of:
"Fundamentals of Sailplane Design" by Fred Thomas.
"Radio Control Thermal Gliding" by Markus Lisken and Ulf Gerber
Good reading for the winter ahead.
Old October 6th 13, 06:58 PM posted to rec.aviation.soaring
son_of_flubber
Ich habe nur eine bischen deutsch.
Old October 6th 13, 09:38 PM posted to rec.aviation.soaring
C-FFKQ (42)
I get the 45 degree bank by looking at the screws of my instruments. Since the screws are placed in the "corners" of the non-existent square hole, the diagonals are 45 degrees to vertical/horizontal.
When I bank over, I check that a diagonal parallels the horizon (I'm a flat-lander) and the other is perpendicular. Easy-peasy!
Now, if I can just stabilise my speed and the angle, I might improve my thermalling. I keep working on that
Old October 6th 13, 10:08 PM posted to rec.aviation.soaring
James Metcalfe
At 20:38 06 October 2013, C-FFKQ 42 wrote:
snipNow, if I can just stabilise my speed and the angle, I might
Actually, stabilising the attitude (not the speed) is what helps ...
although the two are very similar in typical flatland thermals.
J.
Old October 6th 13, 10:39 PM posted to rec.aviation.soaring
David Salmon[_3_]
At 17:48 05 October 2013, son_of_flubber wrote:
I know that a 45 degree bank is useful for flying small circles and
staying
in small thermals, but is there something special about a 45 degree bank
compared to say a 50 degree bank?
For example, does the designer intend for the glider to do something
special at 45 degrees? Is the glider designed to balance aerodynamic
forces in a particular harmony at a precise 45 degree bank?
The only thing I am aware of in relation to 45 deg of bank, is that it
gives the minimum height loss in a 360 deg turn. This is not of much help
in turns in thermals.
Dave
Old October 6th 13, 11:32 PM posted to rec.aviation.soaring
Dan Marotta
If that means you don't speak German, fear not. It's published in English.
"Streckensegelflug"
Old October 7th 13, 03:58 PM posted to rec.aviation.soaring
Dave Nadler
Silly Flubber. Everyone knows the special number is 42.
Old October 7th 13, 04:51 PM posted to rec.aviation.soaring
Ramy
One thing special about 45 degrees is that it is the only angle you can really measure in flight without artificial horizon. If the horizon is aligned with your instrument screws you are banked 45 degrees. You will often be surprised how steeper it is then you thought.
Ramy
Old October 7th 13, 05:19 PM posted to rec.aviation.soaring
Dan Marotta
Pesky mountains ruin the horizon so I can't use the screws. Maybe I should
move to Kansas. Steve...?
"Ramy" wrote in message
Ramy
Old October 7th 13, 05:40 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Monday, October 7, 2013 11:19:01 AM UTC-5, Dan Marotta wrote:
Pesky mountains ruin the horizon so I can't use the screws. Maybe I should move to Kansas. Steve...?
Stick with New Mexico and the uncertainty of your bank angle.
60 degree Mopar V6 for homebuilt? RapidRonnie Home Built 17 February 9th 07 04:12 AM
90 degree locking pliers? B. Jensen Home Built 8 October 3rd 05 06:50 PM
37 degree fitting Ernest Christley Home Built 8 June 17th 04 03:29 AM
90 Degree turn while slipping ISoar Soaring 40 February 14th 04 10:49 AM
37 degree flare, 1/8" stainless Richard Riley Home Built 8 August 29th 03 04:21 AM
