I know that a 45 degree bank is useful for flying small circles and staying in small thermals, but is there something special about a 45 degree bank compared to say a 50 degree bank?
For example, does the designer intend for the glider to do something special at 45 degrees? Is the glider designed to balance aerodynamic forces in a particular harmony at a precise 45 degree bank? |
On Saturday, October 5, 2013 12:48:27 PM UTC-5, son_of_flubber wrote:
I know that a 45 degree bank is useful for flying small circles and staying in small thermals, but is there something special about a 45 degree bank compared to say a 50 degree bank? For example, does the designer intend for the glider to do something special at 45 degrees? Is the glider designed to balance aerodynamic forces in a particular harmony at a precise 45 degree bank? Simple: the tan 45 deg is = 1 so you are #1, A-OK, top of the world, #1 flying ace, you get the drift! (don't drift when thermaling) On the other side, the tan of 30 and 60 deg is a mess, don't go there! Seriously, there seems to be a sweet spot around 45 deg where the radius flown at our thermaling speeds is keeping us closest to the high-climb values found at the center of the thermal without the penalty of higher wingloading and resulting higher stall speeds and overall higher sink at bank angles 50 deg. Not sure this was helpful... Herb |
I see Herb is just as frustrated as I am that it's raining...
The magic of 45 degrees is that if you tell someone to thermal at 45, they'll probably thermal at 35 - 40 which is really the optimum most of the time, at least over the soggy midwest! John Cochrane |
On Saturday, October 5, 2013 10:48:27 AM UTC-7, son_of_flubber wrote:
I know that a 45 degree bank is useful for flying small circles and staying in small thermals, but is there something special about a 45 degree bank compared to say a 50 degree bank? For example, does the designer intend for the glider to do something special at 45 degrees? Is the glider designed to balance aerodynamic forces in a particular harmony at a precise 45 degree bank? "The proper angle of bank in a thermal is one which yields the fastest average rate of climb" --Jim Indrebro-- Obvious, but often overlooked metric. Every thermal is different, airspeed is a factor, airplane, etc., etc. Matt |
On Saturday, October 5, 2013 1:48:27 PM UTC-4, son_of_flubber wrote:
I know that a 45 degree bank is useful for flying small circles and staying in small thermals, but is there something special about a 45 degree bank compared to say a 50 degree bank? For example, does the designer intend for the glider to do something special at 45 degrees? Is the glider designed to balance aerodynamic forces in a particular harmony at a precise 45 degree bank? Over time we have learned that the best climb rate tends to be when the optimum trade off between circling diameter and sink rate increase caused by banking in achieved. This turns out to be right around 40 degrees. Most people over estimate their bank angle. When they think they are 45 degrees, more likely they are just over 30. Only rarely does more than 45 improve climb.. The key is tighten till the climb rate is steadily best and stick with it.. Most gliders, left alone to spiral, will settle in around 30 degrees from my experience. FWIW UH |
Hi, there is a very descriptive book by Markus Lisken and Ulf Gerber called
Radio Control Thermal Gliding, that uses some very complex mathematics to investigate the best possible thermaling practice. In it's comparison of various birds, it concludes that Buzzards are better thermalers than Sea-gulls, because they have a lower Wing Aspect Ratio (6:1 cf 12:1.) and are able to make tighter turns into the middle of the lift. It quotes.. 'These wing shapes clearly show that a design to give minimal sink in no way concur with a design for maximum climb rate'. So your K8 might outperform a ASW29 in a small diameter thermal. |
On Sun, 06 Oct 2013 08:15:31 +0000, Peter Higgs wrote:
Hi, there is a very descriptive book by Markus Lisken and Ulf Gerber called Radio Control Thermal Gliding, that uses some very complex mathematics to investigate the best possible thermaling practice. In it's comparison of various birds, it concludes that Buzzards are better thermalers than Sea-gulls, because they have a lower Wing Aspect Ratio (6:1 cf 12:1.) and are able to make tighter turns into the middle of the lift. It quotes.. 'These wing shapes clearly show that a design to give minimal sink in no way concur with a design for maximum climb rate'. I watched a medium sized buzzard-shaped raptor at Wiener Neustadt the other day as it picked up lift at 50-60ft over the apron and climbed away. It went up like a rocket in a very small corkscrew spiral, not more than 3 times its own span and using under 40 degrees bank. Try doing that in any current sailplane! -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Maybe lots of inside rudder...?? ;-P
"Martin Gregorie" wrote in message ... On Sun, 06 Oct 2013 08:15:31 +0000, Peter Higgs wrote: Hi, there is a very descriptive book by Markus Lisken and Ulf Gerber called Radio Control Thermal Gliding, that uses some very complex mathematics to investigate the best possible thermaling practice. In it's comparison of various birds, it concludes that Buzzards are better thermalers than Sea-gulls, because they have a lower Wing Aspect Ratio (6:1 cf 12:1.) and are able to make tighter turns into the middle of the lift. It quotes.. 'These wing shapes clearly show that a design to give minimal sink in no way concur with a design for maximum climb rate'. I watched a medium sized buzzard-shaped raptor at Wiener Neustadt the other day as it picked up lift at 50-60ft over the apron and climbed away. It went up like a rocket in a very small corkscrew spiral, not more than 3 times its own span and using under 40 degrees bank. Try doing that in any current sailplane! -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
I get the 45 degree bank by looking at the screws of my instruments. Since the screws are placed in the "corners" of the non-existent square hole, the diagonals are 45 degrees to vertical/horizontal.
When I bank over, I check that a diagonal parallels the horizon (I'm a flat-lander) and the other is perpendicular. Easy-peasy! Now, if I can just stabilise my speed and the angle, I might improve my thermalling. I keep working on that ![]() |
At 20:38 06 October 2013, C-FFKQ 42 wrote:
snipNow, if I can just stabilise my speed and the angle, I might improve my thermalling. I keep working on that ![]() Actually, stabilising the attitude (not the speed) is what helps ... although the two are very similar in typical flatland thermals. J. |
60 degree Mopar V6 for homebuilt? | RapidRonnie | Home Built | 17 | February 9th 07 04:12 AM |
90 degree locking pliers? | B. Jensen | Home Built | 8 | October 3rd 05 06:50 PM |
37 degree fitting | Ernest Christley | Home Built | 8 | June 17th 04 03:29 AM |
90 Degree turn while slipping | ISoar | Soaring | 40 | February 14th 04 10:49 AM |
37 degree flare, 1/8" stainless | Richard Riley | Home Built | 8 | August 29th 03 04:21 AM |
