What would happen if 2 sets of static ports (under the wing and on the tail boom) were connected to my ASI?
Airspeed doubles and then an irreversable black hole will form swallowing the ASI, glider, you and eventually the entire planet. Please...don't do it.
Advice from scohpilot may be wrong, but after some risk and cost-
benefit analysis, I would say do not even try. I want to fly next summer. At 17:26 15 November 2013, wrote: Airspeed doubles and then an irreversable black hole will form swallowing the ASI, glider, you and eventually the entire planet. Please...don't do it. |
On Friday, November 15, 2013 12:20:19 PM UTC-5, C2 wrote:
What would happen if 2 sets of static ports (under the wing and on the tail boom) were connected to my ASI? 1- You lose the benefit of 2 sources that can be used for differing needs like airspeed, altimetry, glide computing, electronic TE. 2- You won't be using the static system that was calibrated and used when establishing the operating limits in your flight manual. 3 You would lose the option to switch to root statics to avaoid the effects of water getting in aft statics when dumping. 4 Others I did not think of quickly UH |
What would happen if 2 sets of static ports (under the wing and on the tail boom) were connected to my ASI? It will generate huge static electricity and shock you severely. |
On Friday, November 15, 2013 2:06:40 PM UTC-5, Dave Nadler wrote:
On Friday, November 15, 2013 12:20:19 PM UTC-5, C2 wrote: What would happen if 2 sets of static ports (under the wing and on the tail boom) were connected to my ASI? It will generate huge static electricity and shock you severely. PS: That's why they are called STATIC ports. |
On Friday, November 15, 2013 1:06:40 PM UTC-6, Dave Nadler wrote:
On Friday, November 15, 2013 12:20:19 PM UTC-5, C2 wrote: What would happen if 2 sets of static ports (under the wing and on the tail boom) were connected to my ASI? It will generate huge static electricity and shock you severely. Thanks for the smart ass answer to a simple question. Would it adversely affect my airspeed reading? |
On Friday, November 15, 2013 4:41:58 PM UTC-5, wrote:
Would it adversely affect my airspeed reading? Using anything other than the certificated pitot-static configuration can greatly affect your ASI reading, and your safety. |
On Friday, November 15, 2013 1:06:40 PM UTC-6, Dave Nadler wrote: On Friday, November 15, 2013 12:20:19 PM UTC-5, C2 wrote: What would happen if 2 sets of static ports (under the wing and on the tail boom) were connected to my ASI? It will generate huge static electricity and shock you severely. Thanks for the smart ass answer to a simple question. Would it adversely affect my airspeed reading? Answered in the 4th message containing no smart ass answers. UH |
Inthe good old days, when stall speed was less than 30kt,2 seaters
had an open cockpit, no one bothered with static ports; even in a modern sailplane the cockpit static is usually within a knot or two of nominal. it is useful to have a tap which opens the static line to cockpit in case , (as often happens to me, the static ports have sent water into the line, creating an offset, or the tape to prevent this has not been removed) you want the ASI to show something meaningful. However, from a practical test I can tell you that an air extractor will add 4-6 kts to the reading at approach speeds if you use cockpit static. AS has happened to me on a number off occasions, the ASI shows something ridiculous, some practicebeforehand without itcan reduce the anxiety. John F At 22:50 15 November 2013, wrote: On Friday, November 15, 2013 4:41:58 PM UTC-5, wro= te: On Friday, November 15, 2013 1:06:40 PM UTC-6, Dave Nadler wrote: On Fr= iday, November 15, 2013 12:20:19 PM UTC-5, C2 wrote: What would happe= n if 2 sets of static ports (under the wing and on the tail boom) were conn= ected to my ASI? It will generate huge static electricity and shock= you severely. Thanks for the smart ass answer to a simple question. Would = it adversely affect my airspeed reading? Answered in the 4th message containing no smart ass answers. UH |
Static ports | Grider Pirate | Soaring | 5 | August 20th 10 04:07 PM |
DG-600 AOA static ports | Marc Ramsey | Soaring | 0 | February 14th 07 10:37 PM |
Win XP and COM ports | Ted Wagner | Soaring | 13 | April 26th 05 07:30 PM |
ADF static? question | JFLEISC | Home Built | 3 | December 28th 04 01:28 AM |
Four Static Ports! Which to Use? | John DeRosa Sky Soaring Chicago IL | Soaring | 3 | May 18th 04 04:55 PM |
