DG-600 AOA static ports
Old February 14th 07, 10:37 PM posted to rec.aviation.soaring
Marc Ramsey
Default DG-600 AOA static ports
My DG-600 has paired sets of static ports on the fuselage, just above
the wing roots. These feed the factory installed angle of attack meter.
My meter does not function, and I'd like to construct a replacement.
I assume the AOA meter was simply measuring the pressure differential
between these ports. Would anyone care to guess as to the magnitude of
these pressure differentials?
I believe these meters were installed to address two issues, touchy
stall characteristics at rearward CGs, and helping the pilot avoid
draggy portions of the polar. Does anyone know if the meters were
effective?
Marc
KX-155 static Robert M. Gary Piloting 3 September 13th 06 03:40 AM
KX-155 static Robert M. Gary Owning 4 September 13th 06 03:40 AM
Win XP and COM ports Ted Wagner Soaring 13 April 26th 05 07:30 PM
Four Static Ports! Which to Use? John DeRosa Sky Soaring Chicago IL Soaring 3 May 18th 04 04:55 PM
Static in KX-165A Chad Lemmen Owning 3 July 21st 03 09:57 PM
