Top ten glider trailer features?
Old November 27th 13, 03:51 AM posted to rec.aviation.soaring
shkdriver shkdriver is offline
Member
First recorded activity by AviationBanter: Aug 2008
Default Top ten glider trailer features?
Hello,
I am in the early stages of building a Luebke patterned clamshell trailer for my Schempp-Hirth SHK. The trailer is an aluminum sheathed steel frame 'interpretation' of the cobra and comet style trailers. I have been paying attention to every glider trailer I've been around for the last few years, with the intention of incorporating the best features. Some of these features are;
Tracks and captured wing root dollies with adjustable tension hold down
brackets for the spar root (seen in a cobra containing a ventus)
Captured aluminum ramp with fold over center track, with either hydraulic
or double screw jack height adjustment (cobra again).
Pivoting lower carriage wheels on belly support dolly (cobra).
Drop down tailgate which provides a braced repeatable height of tail end
of trailer for rigging and derigging.
Front access hatch, ventilators, spare tire access when loaded.
Good lights with some lights down the length of the trailer.
Storage space for all the ground handling gear.
So, what am I missing or forgetting? Does anyone have any comments on favorite features or also, features which should be avoided at all costs? I want to eliminate those unforeseeable miserable items which pinch fingers, rash gliders, and detract from the chore of rigging and trailering a glider. I would also like to have a system which uses the least amount of loose gear lying about.
Thanks,
Scott W.
N-1521
Old November 27th 13, 03:57 AM posted to rec.aviation.soaring
Mike the Strike
On Tuesday, November 26, 2013 8:51:59 PM UTC-7, shkdriver wrote:
Hello,
Thanks,
Scott W.
N-1521
Hydraulic jacks have a fairly high failure rate. Screw jacks fail rarely and would be my first choice..
Working brakes would also be a nice feature!
Mike
Old November 27th 13, 04:24 AM posted to rec.aviation.soaring
Tim Taylor
I prefer screw down feet to using the tailgate. The tailgate hinge tends to wear with time from using it as a support.
Also if you are using the tailgate as the support you can't close the tailgate and have the trailer not at risk of turning while you are gone.
Get a nice set of screw jacks and you will be much happier in the long run.
Old November 27th 13, 05:04 AM posted to rec.aviation.soaring
JS
Hard to go wrong copying a Cobra. But leave the awful foam-backed carpet out.
Old November 27th 13, 06:06 AM posted to rec.aviation.soaring
Tony[_5_]
Set the height so you minimize dragging the tail of the trailer on the road when going in driveways. That is a constant problem with my driveway with most trailers.
I really liked the internal side storage compartments on Greg Cole's sparrowhawk trailer. He made the trailer as wide as the outside of the tires in the middle and tapered to "normal" width at the nose and tail. This created large storage areas ahead of and behind each wheel. That would require a major departure from Luebke plans though.
Keep good notes, someday I need a few more trailers. I have a set of Luebke 1-26 trailer plans for a future Cherokee II trailer.
Old November 27th 13, 06:11 AM posted to rec.aviation.soaring
Bob Kuykendall
On Tuesday, November 26, 2013 8:24:29 PM UTC-8, Tim Taylor wrote:
...The tailgate hinge tends to wear with time from
using it as a support...
Isn't that just another way of saying that most tailgate hinges are too flimsy?
Old November 27th 13, 06:14 AM posted to rec.aviation.soaring
son_of_flubber
I sorely miss the shock absorbers that the cheapskate designers of my 1999 Avionic trailer wrote off as decadent western luxury. The road vibration on the first long haul eased the pins out of the tailgate hinges. I don't imagine that that level of jarring vibration is good for a sailplane.
I've seen shock absorbers on some glider trailers.
I would also like some sturdy tie down points on the corners for tieing the trailer down when high winds are a possibility. Presently I loop the ropes around the frame members but that is a hassle to thread them through lying on my back in the wet grass.
Old November 27th 13, 06:30 AM posted to rec.aviation.soaring
Mount the stuff that you use every time you rig/de-rig at the rear of the trailer. Saves several trips back and forth to the front of the trailer. I have cleaning supplies, tape, ballast funnels, and the one man rigging dolly mounted in the rear. For me, it is much easier to get the rigging dolly out of the back of the trailer than trying to wrestle it out through the front hatch.
P9
Old November 27th 13, 08:40 AM posted to rec.aviation.soaring
On Tuesday, November 26, 2013 7:51:59 PM UTC-8, shkdriver wrote:
I wished we had trailer-wide drawers in front and in back of the axle. One could stow a lot of rigging stuff there.
Heinz
Old November 27th 13, 11:04 AM posted to rec.aviation.soaring
Jim White[_3_]
My ten....
Newer cobra trailers have trays attached to the wing dollies that bring the
cleaning materials in them down the back when rigged. Nice touch.
I wouldn't be without my hydraulic jack. Much much easier.
I store my probes inside the clamshell at the back, safe from damage.
Easily swappable number plate. Install mountings at the standard cobra
pitch so crew can easily attach their number plate.
Very strong hinges, fittings, and locks.
Solar panels or wind turbine that can drive a fan or dehumidifier as well
as charge batteries. I wish I could power a small heater to keep the
temperature above freezing.
Screw jacks are a pain. If you do not want to prop with the door (the rear
of my trailer sits on tyres) then fit drop down stands and wind the front
up on the dolly jack to drive them into the ground.
Single axle better than dual but fit Tyrons to ensure tyres cannot come off
when flat.
Double skin or insulation to ward off condensation.
Maintenance free exterior - hate washing and polishing.
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
F.S. 3-glider trailer Nigel Pocock Soaring 0 September 29th 06 11:29 AM
glider trailer Q Ken Ward Soaring 10 August 28th 06 04:27 PM
glider trailer Q Steve Leonard Soaring 1 August 28th 06 05:29 AM
RSS feed for glider flying related news and features? Matthieu Soaring 0 November 16th 05 06:05 PM
