Transponder installation
Old January 18th 14, 06:10 PM posted to rec.aviation.soaring
who's me?
Default Transponder installation
Got a question for all you radioheads out there. I am installing a Becker Xnder and I notice my other glider has a 8"x8" or so grounding plane attached (glue?) on the inside where the antenna is mounted.
Question??? I need ground plane information such as size, thickness, installation tips, do's and don't, ideas.
The Becker is a 250 watts version and I will be using a small 2.5" wire rod type antenna.
Thank you all,
R
Old January 18th 14, 06:47 PM posted to rec.aviation.soaring
On Saturday, January 18, 2014 1:10:46 PM UTC-5, who's me? wrote:
Got a question for all you radioheads out there. I am installing a Becker Xnder and I notice my other glider has a 8"x8" or so grounding plane attached (glue?) on the inside where the antenna is mounted. Question??? I need ground plane information such as size, thickness, installation tips, do's and don't, ideas. The Becker is a 250 watts version and I will be using a small 2.5" wire rod type antenna. Thank you all, R
Thickness does not matter. I usually use a piece of .016 aluminum. Installation manual should define sise, but about 5 inches in diameter is what I recall.
On glass ship it can go inside. On carbon ship I put on outside behind the gear with 2 sided tape.
UH
Old January 18th 14, 09:11 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
who's me? wrote, On 1/18/2014 10:10 AM:
you all, R
The glider manufacturer may have a document showing the "correct"
installation, if not UH's comments apply.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old January 19th 14, 12:22 AM posted to rec.aviation.soaring
Dan Marotta
I installed my ground plane inside my carbon fuselage. Used a blade antenna
just aft of the gear doors and offset slightly to the right due to the
thickness of the fuselage at the glue joint. Passed transponder test at
avionics shop and is clearly visible to ATC.
what I recall.
UH
Old January 19th 14, 01:51 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
what I recall.
UH
Or use a di-pole antenna that doesn't need a ground plane. I mounted mine all inside the fuselage just forward of the rudder.
JJ
Have you done a Discus 2CT Transponder Antenna Installation per863-17 (behind turbo on top of fuse)?? [email protected] Soaring 0 December 20th 12 01:45 PM
Honeywell KT76C transponder, installation manual Dave S Instrument Flight Rules 0 July 10th 05 05:59 PM
Honeywell KT76C transponder, installation manual Dave S General Aviation 0 July 10th 05 05:59 PM
Transponder Installation in Discus A, B, CS Rick Fuller Soaring 0 March 27th 04 11:13 AM
For Jim Weir: Transponder Installation Ron Wanttaja Home Built 11 February 3rd 04 03:26 PM
