Have you done a Discus 2CT Transponder Antenna Installation per863-17 (behind turbo on top of fuse)??
Old December 20th 12, 01:45 PM posted to rec.aviation.soaring
Default Have you done a Discus 2CT Transponder Antenna Installation per863-17 (behind turbo on top of fuse)??
Tech note 863-17 per SH says that this location is acceptable. Their wording is "Installation of the Transponder-Antenna on the upper side of the fuselage behind the engine compartment".
If you have actually done a transponder antenna behind the turbo on top of the fuse in a SH glider it would be great to hear from you offline.
Gary
For Sale: Duo Discus Turbo Ruud Soaring 17 August 6th 05 02:55 AM
FS: Duo Discus Turbo - Houston, TX Mark Zivley Soaring 0 June 10th 05 11:31 PM
FS: 2002 Duo Discus Turbo - Texas Mark Zivley Soaring 0 May 8th 05 07:44 PM
FS: Duo Discus Turbo - Texas, USA Mark Zivley Soaring 2 May 4th 05 11:34 PM
Transponder Installation in Discus A, B, CS Rick Fuller Soaring 0 March 27th 04 11:13 AM
