Restraint Harness
Old January 20th 14, 09:10 PM posted to rec.aviation.soaring
Default Restraint Harness
I need to replace my seat belt and shoulder harness. I have some flexibility since my glider is an experimental (LS4). Based in the USA.
It currently has a four point harness made by Gadringer. Choices are to get it re-webbed or replaced. I am leaning toward trying to get it re-webbed, but thought I would see what folks like today in the way of harnesses as I might just as easily replace it.
What is the favored harness manufacturer today? Or is there a favorite?
Thanks for the input.
WD
Old January 20th 14, 09:42 PM posted to rec.aviation.soaring
Bill T
Updated the Pawnee and the Schweizer 1-26with Hooker Harness. They have the old "military style" connections.
The Grob, LS, ans Schweizer 2-33 have the older Schroth style, now Davis brand.
Check out Wings and Wheels for the Davis style, Hooker Harness has their own web site.
Bill T
Old January 21st 14, 12:25 AM posted to rec.aviation.soaring
Dave Springford
In the US Hooker Harness will re-web your current belts.
Assuming the metal bits are all in good shape it is significantly cheaper to re-web than to replace the entire system. Most (all)seatbelts have a 12 year life limit due to UV degradation of the material. The tensile strength goes down drastically due to this degradation. For about $150 it is certainly worth sending them for re-webbing during the off-season.
If you are in Canada, use GJ's Aircraft belts. He does a super job.
www.gjsair.ca
Dave Springford
www.foxonecorp.com
Old January 21st 14, 03:46 PM posted to rec.aviation.soaring
Here's another option
http://www.aircraftseatbelts.com/
I'm sending mine for re-webbing and having a crotch belt made. I think the re-webbing was quoted at $145.
Old January 21st 14, 09:10 PM
Matt G. Matt G. is offline
Junior Member
First recorded activity by AviationBanter: Jul 2012
WD
I had Wag-Aero reweb the belts for my Austria and I am happy with them. Price was reasonable, too.
Old January 24th 14, 05:27 PM posted to rec.aviation.soaring
rlovinggood
I'll second the company at the website listed above. I sent in my Schroth four-point harness and they returned it within a week or so with everything replaced except for the rotary buckle. They replaced the rusty adjusters and slides with new parts. My only "problem" was determining what color of webbing to order...
Ray Lovinggood
Carrboro, NC
LS1c/d
Old January 24th 14, 05:29 PM posted to rec.aviation.soaring
rlovinggood
I'll second the company at the website listed above (www.aircraftseatbelts.com "Aviation Safety Products" located in Blairsville, Georgia, USA). I sent in my Schroth four-point harness and they returned it within a week or so with everything replaced except for the rotary buckle. They replaced the rusty adjusters and slides with new parts. My only "problem" was determining what color of webbing to order...
Ray Lovinggood
Carrboro, NC
LS1c/d
Old January 27th 14, 02:13 AM posted to rec.aviation.soaring
Thanks for all the input. Very helpful!
Ray - what color did you end up going with?
WD
Old January 27th 14, 02:15 PM posted to rec.aviation.soaring
rlovinggood
I got a dark blue, probably the "Midnight Blue" as shown on their web page. It looks very good. CAVEAT...HOWEVER... I have a problem. I installed the harness yesterday in the glider and then found the lap belt will not engage into the rotary buckle. Both shoulder harnesses work fine and both shoulder harness "tabs" will engage into the lap belt slot in the rotary buckle. It appears the round hole in the "tab" of the lap belt is too small. I've placed a call to "Aviation Safety Products" and am awaiting their call back. It is disappointing that they didn't do the simple test of trying to insert the new metal "tabs" into the rotary buckle before sending out the harness. I'll report back with news when it becomes available.
Ray
Harness Cleaning Terry Edmonds Soaring 1 August 19th 13 04:39 PM
AR3201 Harness? noel.wade Soaring 13 March 10th 09 02:23 PM
looking for Hooker harness Al MacDonald Home Built 0 July 12th 08 03:54 PM
S-H safety harness (V2C) [email protected] Soaring 20 April 28th 06 08:54 AM
Harness Nolaminar Restoration 2 December 25th 03 03:04 PM
