National Records, why are there not two categories?
Old March 6th 14, 02:52 AM posted to rec.aviation.soaring
Tony[_5_]
Default National Records, why are there not two categories?
On Wednesday, March 5, 2014 7:23:00 PM UTC-6, wrote:
Buy a 1-26 and go after the 1-26 records. Those are national records too and they are quite breakable . This way you don't have to buy a pressure suit or a $500,000 glider...
Best Regards,
Daniel Sazhin
I guess I'm just curious how it got to this point. The rules for state records say you need to take off within the state (you can land across state lines) you are claiming the record in. Seems like it used to be a requirement that for a US record you should take off within the country where the record was claimed. Seems like a reasonable distinction to have US and OUS categories.
I've always wondered the same thing about geography. It's been discussed here before, particularly after Fossett and Enevoldson. I think someone mentioned then that some countries do keep geographic as well as citizenship based records.
Old March 6th 14, 11:19 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
to=
pressur=
=20
=20
=20
Best Regards,
=20
=20
=20
Daniel Sazhin
=20
=20
=20
r=
state=
require=
OUS=
categories.
he=
menti=
bas=
ed records.=20
The British system is British National Records (the FAI sanctioned ones)
can be set by a British Citizen flying anywhere in the World. Many years
ago the BGA , recognising that most pilots couldn't afford to go record
chasing in South Africa, the American South West, Australia and all the
other places where the weather is much better than the UK, created a second
set, UK Local Records; these can be set by a pilot of any nationality on a
flight starting within the defined boudaries of mainland UK.
All of the British National Records currently listed were set outside the
UK, except the gain of height and absolute altitude records, which were set
in Scotland and are the only ones on both lists.
I think that system is a very good idea and fair to all parties.
National Records & Citizenship Tony[_5_] Soaring 8 July 11th 11 11:55 AM
Too many record categories? Pat Russell Soaring 1 February 7th 07 05:20 PM
State and National records question Gary Emerson Soaring 3 January 22nd 07 11:14 PM
More Bush National Guard records emerge Otis Willie Military Aviation 0 September 9th 04 03:38 AM
Changes to Aircraft Approach Categories?! skyliner Instrument Flight Rules 10 February 9th 04 08:55 PM
