The bearings for my 1986 Komet III trailer are part numbers:
30206 for the inner taper bearing and 30205 for the outer taper bearing. Apparently these parts are available through AutoZone and probably lots of others. What I'm missing is a part number for the seal between them. Four years ago, the mechanic did a lot of careful pounding to get the old seals out in reusable shape. I would like some replacements on hand this time. Can anyone post the part number? Just FYI, a mechanic I spoke with said a dragging brake could be the cause of the heat issue I'm having. RF |
RF,
Here is a link to the catalog for Knott, which is the manufacturer of the original axle. I misplaced the size of the brake assembly so you will have to find it. There should be a nameplate with a part number on the axle that can get you started. Catalogue http://www.knottbrake.com/pdf5/Spare...ailer_2007.pdf or Website: http://www.knottbrake.com/axles.html (then click on Service part catalog). Note that the catalogue also includes the part for the tongue assembly which can become handy at some point. A Komet III should have a KR 13/7 C4 tongue. Page 86 (or 164 in the pdf) gives you the tongue spare part info. I have not ordered parts from Knott USA just yet. I hope somebody on RAS has and can report if these parts are easy to procure from them. I don't think the seal you are looking for is available at a local auto part store. Good luck. |
Cobra wheel bearing info | Paul Villinski | Soaring | 6 | December 21st 14 10:07 PM |
Where to buy a jockey wheel for a Komet trailer in Berlin? | Morteza Ansari | Soaring | 4 | August 6th 13 02:07 AM |
Wanted: Cobra, Komet, Avionic, or Swan Trailer! | NEEDTRAILER | Soaring | 3 | October 24th 12 04:02 AM |
Komet trailer wheel bearings | Dan[_6_] | Soaring | 7 | February 9th 09 06:13 AM |
Komet III wheel info | Gary Emerson | Soaring | 2 | February 4th 09 03:14 AM |
