Does anyone know off hand what the wheel and tire specs are for a 1978
	vintage Komet III trailer. I'd like to consider buying a pair of wheels and tires before the trailer is picked up rather than spending the time getting new tires put on after I get there.  |
On Feb 1, 5:47*am, Gary Emerson  wrote:
	Does anyone know off hand what the wheel and tire specs are for a 1978 vintage Komet III trailer. *I'd like to consider buying a pair of wheels and tires before the trailer is picked up rather than spending the time getting new tires put on after I get there. Gary, I don't believe that there is a common spec for the Komet (or Cobra) trailer. I've seen quite a variety of Wheel on trailers. You need to verify the exact hub on the trailer that you are concerned with. The spec's you are interested in will be the bolt number and spacing as well as the wheel offset. i.e. 5 x 100 et 32 Only then can you acquire a set that will work with the trailer. I've found that a number of on-line tire stores can be helpful to your needs. I've had good luck with the Tirerack http://www.tirerack.com and Discount Tire http://www.discounttiredirect.com. They will be able to cross reference the specs for your trailer and in most cases provide the wheel-tire combo you seek. I went thru this exercise last week with a Duo-Discus trailer that was passing thru. The "low mileage new" 8 year old tires expired on the trip just outside of phoenix and destroyed the wheel (and Fender). It turned out to be a VW Vanagen spec hub and wheel. Thanks to Discount Tire a suitable replacement was found.. As a side note, one of the custom wheel shops we stopped at knew quite a lot about Gliders. The guy behind the counter asked what kind of a Sailplane is in the trailer. Upon answering his question, he replied that his Dad has a Discus and flies with the Chicago Glider club. It's a small world as I have flown many contests with (against) his Dad!  |
On Feb 2, 11:04*am, Paul Cordell  wrote:
	On Feb 1, 5:47*am, Gary Emerson wrote: Does anyone know off hand what the wheel and tire specs are for a 1978 vintage Komet III trailer. *I'd like to consider buying a pair of wheels and tires before the trailer is picked up rather than spending the time getting new tires put on after I get there. Gary, I don't believe that there is a common spec for the Komet (or Cobra) trailer. *I've seen quite a variety of Wheel on trailers. * You need to verify the exact hub on the trailer that you are concerned with. The spec's you are interested in will be the bolt number and spacing as well as the wheel offset. i.e. *5 x 100 *et 32 * Only then can you acquire a set that will work with the trailer. * *I've found that a number of on-line tire stores can be helpful to your needs. * I've had good luck with the Tirerack *http://www.tirerack.com* *and Discount Tire *http://www.discounttiredirect.com. * * They will be able to cross reference the specs for your trailer and in most cases provide the wheel-tire combo you seek. I went thru this exercise last week with a Duo-Discus trailer that was passing thru. *The "low mileage new" 8 year old tires expired on the trip just outside of phoenix and destroyed the wheel (and Fender). It turned out to be a VW Vanagen spec hub and wheel. * *Thanks to Discount Tire a suitable replacement was found.. * As a side note, one of the custom wheel shops we stopped at knew quite a lot about Gliders. * * The guy behind the counter asked what kind of a Sailplane is in the trailer. * *Upon answering his question, he replied that his Dad has a Discus and flies with the Chicago Glider club. * *It's a small world as I have flown many contests with (against) his Dad! Can't help much, but FYI, Toyota Tercel wheels ALMOST fit (AAAAARGH). Lug spacing - check Offset - check Hole in the middle - 1/8" too small to fit over the bearing protrusion on the hub. Darn!  |
| Thread Tools | |
| Display Modes | |
| Wheel pants for 6.00 x 6 wheel/tire | Wallace Berry | Home Built | 2 | January 23rd 04 05:22 AM |
