Actual Rope Break
Old June 2nd 14, 01:19 PM posted to rec.aviation.soaring
Kevin Christner
Default Actual Rope Break
You say you are pleased that you practiced for this. I assume you
mean that you are glad you practiced 180 turns from 200ft. I wish to
say that my personal opinion is that a verbal briefing (to go straight
ahead) would have been much safer for your instructors to teach
you, with a verbal briefing that any other alternatives must be
delayed until high enough for 'some maneuvering'. I'd put that at
300ft minimum, when a 90 turn to look back, and do some thinking,
would be be ok, but even then, a turn away to the safest area should
be made, even if off-field. Otherwise, go more-or-less straight ahead,
and let the insurance company worry about their glider. I'd
recommend that instructors should teach that a low rope break is an
emergency, and the only responsibility on the pilot is to get himself
and his passenger down without harm. Damage to the glider should
not be considered. I obviously don't know for sure, but I think its
arguable that this teaching approach might produce more minor
damage to gliders, but fewer fatalities.
Hi Andrew,
Here is the US the standard instruction is that you make a 180 deg turn at or above 200ft or a straight in below 200 feet. This is what the FAA Glider Flying Handbook says.
Our site is a little tricky. The runway is parallel to a 400 foot high ridge or so. You can only make a turn to the north. Generally you should always make your turn into the wind so that the wind will cause you to drift back towards the runway. In this case I was turning away from the wind. Luckily the runway parallels a large field on the other side so if you get blown away from the runway its still possible to land in the field.
2C
Old June 2nd 14, 04:18 PM posted to rec.aviation.soaring
Bill D
On Sunday, June 1, 2014 10:50:10 PM UTC-6, Andrew wrote:
Hi Kevin
Congratulations on managing this emergency safely. A low tow
termination of the tow is a true emergency, that some people have
not managed successfully, as discussed on this website.
I've been gliding for a long time, and my experience is that
unplanned tow terminations are very rare. I have only had two
unplanned releases, the lowest at 400ft at Lasham (Euroglide 73),
the other at 1000ft at Portmoak. On the one at Lasham, I was very
aware that the entire competition grid were watching me. Both were
wave-offs, due to towplane engine problems (neither serious as it
turned out later, but the tow pilots were understandably concerned at
the time). My experience seems logical when one considers that after
liftoff, the tension on the rope should be close to the drag on the
glider, i.e. about weight divided by L/D, i.e. about 35lbs or less. Apart
from shocks from slack lines tightening, if the rope doesn't break
during the first few seconds when the glider is being dragged over
the ground, a 'pure rope break' is unlikely. The rope is essentially
'proof tested' in the first 30 seconds of every tow. I haven't had any
ring or tow-mechanism malfunctions. So from my experience, the
most likely (but rare) problem is a tow plane engine problem.
It's not that a typical glider isn't capable, aerodynamically-speaking,
of performing a 180 at 200ft. They obviously can. Its that an early
solo pilot may not be able to, and experienced pilots under that
stress may not be able to either.
Safety is a tricky concept. My view is that, to be safe, one should
'stop before it becomes unsafe'. That sounds obvious, but then
consider that this logically means that we should 'stop while we are
still safe'. Ie..... we should stop when we could have safely gone a bit
further. The price for safety, is to stop too early. I can remember
stopping flying (for weather) knowing people were thinking we could
have safely gone on a bit longer. And they were completely right.
Straining this logic, its arguably safer to teach to go straight ahead,
even if an excellent pilot could do a 180.
I stand by my remark made earlier, that a site where a straight-
ahead landing is likely to produce more than minor damage, is not a
safe site.
At 23:20 01 June 2014, Kevin Christner wrote:
I had my first "rope break" ever today. I was approximately 200-
250ft
abov=
e the ground. Emergency procedures were not a problem.
The Tost released for some reason. Its a nose hook so the back
release
mec=
hanism could not have been the culprit. Further testing with the
wheel
bre=
ak on the ground revealed no problems so I took another tow and
had no
prob=
lems. The ring may not have been engaged properly (doubtful) or
the slack
I got in the rope was just too much when it tightened back up
(probable
but=
the release still should have held).
In any case has anyone else ever experienced an actual emergency
unplanned
release? In 14 years of flying I have never heard of one. Good
thing we
d=
o practice this. =20
2C
The rope tension is more than the glider's weight divided by the L/D which would only be the case in level flight. Aero tow is lifting the weight of the glider into the sky which requires more tension.
The record shows premature termination of tow is far more common than you suggest. Only one incident I know of involved a rope break in the takeoff roll. The rest were rope breaks during the early airborne part of the tow.
The reason is ropes don't simply snap when overloaded. Fibers break then the rope unravels which takes a little time. If the rope was overstressed in the takeoff roll, expect it to part at few hundred feet AGL.
The 200' AGL 180 turn back to the runway is the MINIMUM STANDARD in the US. Either a pilot learns to confidently demonstrate the maneuver with grace and precision or his flying career stops right there. All pilots are expected to retain that level of ability throughout their careers and can expect to be asked to prove it in every Flight Review or Check Ride.
However, demonstrating an ability to perform the maneuver doesn't mean it's required or even the preferred action in a real emergency. It's simply an additional option in the pilots repertoire. A pilot is expected to exercise good judgment in selecting the best option for the situation.
That said, if a pilot damages a glider in a risky off field landing when the glider was in a position for a safe return to the runway, he'll likely be grounded pending a check ride.
Old June 2nd 14, 04:38 PM posted to rec.aviation.soaring
Dan Marotta
At Moriarty, we create rope/ring protectors using plastic water bottles
with the bottoms cut off. The bottle is placed over the rope, large end
facing the glider, and wrapped many times with duct tape for abrasion
protection. Better to wear that out than the rings or ropes where
wrapped around the large ring.
Dan Marotta 5J
On 6/1/2014 6:45 PM, Bill D wrote:
On Sunday, June 1, 2014 5:20:14 PM UTC-6, Kevin Christner wrote:
I had my first "rope break" ever today. I was approximately 200-250ft above the ground. Emergency procedures were not a problem.
The Tost released for some reason. Its a nose hook so the back release mechanism could not have been the culprit. Further testing with the wheel break on the ground revealed no problems so I took another tow and had no problems. The ring may not have been engaged properly (doubtful) or the slack I got in the rope was just too much when it tightened back up (probable but the release still should have held).
In any case has anyone else ever experienced an actual emergency unplanned release? In 14 years of flying I have never heard of one. Good thing we do practice this.
2C
I've had two uncommanded Tost releases myself and observed two more. (No drama ensued.) In another case, the hook wouldn't initially release until the pilot worked it loose by maneuvering the glider on tow. In all cases the release itself was found to be within its service life and in excellent condition with springs intact.
The one common thing with all these incidents was a badly worn Tost ring pair. An abrasive runway had noticeably removed metal from the small ring leaving it with a rough, pitted surface. The point of the hooks "beak" could capture the rough ring against the cage with friction even though it wasn't fully inserted into the release. Even when tested by pulling hard on the rope, it sometimes wouldn't come loose but it could still work loose during the tow. The "beak" can't capture a new, smooth ring pair.
We speculate the fail-to-release incident was the result on a worn, undersized ring getting cocked sideways inside the cage.
If the tow operator can't be convinced to replace the ring pair, have the wing runner shake the rope to make sure it rattles in the hook after it is attached. If it's captured by friction, it won't rattle.
Old June 2nd 14, 04:41 PM posted to rec.aviation.soaring
Congratulations on a successful outcome Bill!
My only rope break was on my FAA check ride with an inspector in the back seat.
A turbulent tow where the line went slack. A boot full of rudder pre-tension wasn't enough apparently as *snap* a the tow rope became a flicking serpent in front of me. Approx 400ft AGL with limited options in my 12 o'clock I made a turn back and judged I was high. Deviated right of centreline to fly a short base leg to wash off excess altitude before landing. Gained a few points with the examiner that day as he had only just 're-qualifed' on gliders that morning.
In hindsight? I should have been more aggressive in the post-slack yaw to soften the blow a little more. I also feel I could have released the tow rope over the field to allow the FBO to recover the rings instead of 'systematically', soon after PTT.
As a poster in the bunkhouse says, you don't rise to the occasion, you sink to the level of your training. Thanks TK.
Old June 2nd 14, 04:44 PM posted to rec.aviation.soaring
*ahem*
Kevin
Old June 2nd 14, 05:30 PM posted to rec.aviation.soaring
Bill D
My first uncommanded Tost release was on a winch launch at about 10' AGL so I just landed straight ahead on the runway. This was a no-sweat event and I didn't know it was an uncommanded release until the crew told me.
The second was on aero tow just as I decided to release in a good thermal. This was more startling since it seemed like the glider had acquired some intelligence of its own.
The others were during CAP Cadet orientation rides where the Cadet attaching the rope may not have checked the security of the ring in the hook (Our fault since we hadn't trained them to do it). These incidents persuaded us to check the Tost ring pair more carefully for wear and to insist the person attaching the rope checks to insure the ring is free to rattle in the hook.
It's possible for a pilot to detect an improperly inserted ring pair since the yellow knob won't retract all the way if the ring is just "captured" by the "beak". I've learned the hard way to pay attention to how the release knob feels as the hook closes.
Old June 2nd 14, 05:35 PM posted to rec.aviation.soaring
Bill D
Our tow operator uses "whiffle balls" to protect the knot and ring pair and they are almost always found inside the ball as intended so it's a bit of a mystery how they suffer so much wear.
Dan Marotta 5J
Old June 2nd 14, 05:38 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
Hi Kevin
=20
=20
=20
Congratulations on managing this emergency safely. A low tow=20
=20
termination of the tow is a true emergency, that some people have=20
=20
=20
=20
=20
I've been gliding for a long time, and my experience is that=20
=20
unplanned tow terminations are very rare. I have only had two=20
=20
unplanned releases, the lowest at 400ft at Lasham (Euroglide 73),=20
=20
the other at 1000ft at Portmoak. On the one at Lasham, I was very=20
=20
aware that the entire competition grid were watching me. Both were=20
=20
wave-offs, due to towplane engine problems (neither serious as it=20
=20
at=20
=20
the time). My experience seems logical when one considers that after=20
=20
liftoff, the tension on the rope should be close to the drag on the=20
=20
Apart=
=20
=20
from shocks from slack lines tightening, if the rope doesn't break=20
=20
during the first few seconds when the glider is being dragged over=20
=20
the ground, a 'pure rope break' is unlikely. The rope is essentially=20
=20
any=20
=20
ring or tow-mechanism malfunctions. So from my experience, the=20
=20
=20
=20
=20
You say you are pleased that you practiced for this. I assume you=20
=20
mean that you are glad you practiced 180 turns from 200ft. I wish to=20
=20
straight=20
=20
ahead) would have been much safer for your instructors to teach=20
=20
you, with a verbal briefing that any other alternatives must be=20
=20
delayed until high enough for 'some maneuvering'. I'd put that at=20
=20
300ft minimum, when a 90 turn to look back, and do some thinking,=20
=20
would be be ok, but even then, a turn away to the safest area should=20
=20
ahead,=20
=20
and let the insurance company worry about their glider. I'd=20
=20
recommend that instructors should teach that a low rope break is an=20
=20
himself=20
=20
and his passenger down without harm. Damage to the glider should=20
=20
not be considered. I obviously don't know for sure, but I think its=20
=20
arguable that this teaching approach might produce more minor=20
=20
=20
=20
=20
aerodynamically-speaking,=
=20
=20
of performing a 180 at 200ft. They obviously can. Its that an early=20
=20
solo pilot may not be able to, and experienced pilots under that=20
=20
stress may not be able to either.=20
=20
=20
=20
Safety is a tricky concept. My view is that, to be safe, one should=20
=20
'stop before it becomes unsafe'. That sounds obvious, but then=20
=20
consider that this logically means that we should 'stop while we are=20
=20
bit=
=20
=20
further. The price for safety, is to stop too early. I can remember=20
=20
stopping flying (for weather) knowing people were thinking we could=20
=20
have safely gone on a bit longer. And they were completely right.=20
=20
ahead,=
=20
=20
=20
=20
=20
=20
ahead landing is likely to produce more than minor damage, is not a=20
=20
safe site.
=20
=20
=20
=20
=20
=20
=20
250ft
=20
abov=3D
=20
=20
=20
The Tost released for some reason. Its a nose hook so the back=20
=20
release
=20
mec=3D
=20
hanism could not have been the culprit. Further testing with the=20
=20
wheel
=20
bre=3D
=20
ak on the ground revealed no problems so I took another tow and=20
=20
had no
=20
prob=3D
=20
lems. The ring may not have been engaged properly (doubtful) or=20
=20
the slack
=20
=3D
=20
I got in the rope was just too much when it tightened back up=20
=20
(probable
=20
but=3D
=20
=20
=20
In any case has anyone else ever experienced an actual emergency=20
=20
unplanned
=20
=3D
=20
release? In 14 years of flying I have never heard of one. Good=20
=20
thing we
=20
d=3D
=20
o practice this. =3D20
=20
=20
2C
=20
which
of
s=
ro=
=20
t=
i=
US.=
grace
expec=
expect=
it's=
an=
exerci=
th=
be=
Bill, you need to accept that this forum is worldwide. Advice and practice
is different outside the USA. While turn backs may be de rigueur at low
height in the USA they are positively discouraged in the UK and never ever
practiced. People who make low turns receive intensive counseling and/or
remedial instruction.
I would never ever criticise a pilot, or take punitive action for choosing
the option which gives the best chance of survival. Insurance can pay for
damaged gliders, as far as I am aware all the money in the world cannot
resurrect dead people.
You have made it very clear that you feel we are lacking in some way and of
course we think the FAA is barmy, such is life.
Old June 2nd 14, 07:50 PM posted to rec.aviation.soaring
Kevin Christner
Hmm I think the BGA may want to take a hard look at this. My cockpit being crushed by trees would not have been an appealing option.
Old June 2nd 14, 07:51 PM posted to rec.aviation.soaring
Bill D
On Monday, June 2, 2014 10:38:34 AM UTC-6, Don Johnstone wrote:
"Bill, you need to accept that this forum is worldwide. Advice and practice
is different outside the USA."
Don, you need to accept that it's different everywhere outside the UK.
"While turn backs may be de rigueur at low height in the USA."
Wrong. Turns are optional. TRAINING is de regueur.
"You have made it very clear that you feel we are lacking in some way."
In very specific ways.
"We think the FAA is barmy."
Thanks for pointing that out. I've made sure they got the message.
Rope Break! Waveguru Soaring 9 August 28th 12 03:17 AM
Rope Break Walt Connelly Soaring 4 April 12th 11 09:04 PM
Explanation Required: ATA (actual time of arr) and ATD (actual timeof dep) SVCitian General Aviation 2 September 19th 10 10:27 PM
Actual Autos Ol Shy & Bashful Rotorcraft 3 April 26th 07 04:22 AM
IR without actual IMC Iain Wilson Instrument Flight Rules 26 October 13th 03 11:26 PM
