Actual Rope Break
Old June 2nd 14, 12:20 AM posted to rec.aviation.soaring
Kevin Christner
Default Actual Rope Break
I had my first "rope break" ever today. I was approximately 200-250ft above the ground. Emergency procedures were not a problem.
The Tost released for some reason. Its a nose hook so the back release mechanism could not have been the culprit. Further testing with the wheel break on the ground revealed no problems so I took another tow and had no problems. The ring may not have been engaged properly (doubtful) or the slack I got in the rope was just too much when it tightened back up (probable but the release still should have held).
In any case has anyone else ever experienced an actual emergency unplanned release? In 14 years of flying I have never heard of one. Good thing we do practice this.
2C
Old June 2nd 14, 12:40 AM posted to rec.aviation.soaring
Bill T
I've had rope breaks, weak link break, with slack line during training. At altitude so not an issue.
I have had ropes part on takeoff, normally at the initial strain on the takeoff acceleration, far up the rope, so it was missed on the first rope preflight of the day and failed late in the day. The glider hade barely moved 50ft, so it was not an issue.
I've watched one ply of a three ply poly part about 50 ft in front of the glider. After I got off tow at altitude, I told the tow pilot he would need a new rope for the next tow.
If your TOST released the ring, either it was not hooked up correctly, did it rattle after hooked up?, or your TOST springs are getting weak. Time to replace it.
BillT
Old June 2nd 14, 12:35 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
abov=
mec=
bre=
prob=
slack
but=
unplanned
d=
o practice this. =20
2C
Most common cause is a broken spring. If the spring breaks on one side it
will still close the hook but with insufficient tension. This can cause
intermittent failures.
Old June 2nd 14, 12:57 AM posted to rec.aviation.soaring
JS
Was the ring worn? If it isn't the full diameter it can self-release.
Old June 2nd 14, 01:45 AM posted to rec.aviation.soaring
Bill D
2C
I've had two uncommanded Tost releases myself and observed two more. (No drama ensued.) In another case, the hook wouldn't initially release until the pilot worked it loose by maneuvering the glider on tow. In all cases the release itself was found to be within its service life and in excellent condition with springs intact.
The one common thing with all these incidents was a badly worn Tost ring pair. An abrasive runway had noticeably removed metal from the small ring leaving it with a rough, pitted surface. The point of the hooks "beak" could capture the rough ring against the cage with friction even though it wasn't fully inserted into the release. Even when tested by pulling hard on the rope, it sometimes wouldn't come loose but it could still work loose during the tow. The "beak" can't capture a new, smooth ring pair.
We speculate the fail-to-release incident was the result on a worn, undersized ring getting cocked sideways inside the cage.
If the tow operator can't be convinced to replace the ring pair, have the wing runner shake the rope to make sure it rattles in the hook after it is attached. If it's captured by friction, it won't rattle.
Old June 2nd 14, 04:38 PM posted to rec.aviation.soaring
Dan Marotta
At Moriarty, we create rope/ring protectors using plastic water bottles
with the bottoms cut off. The bottle is placed over the rope, large end
facing the glider, and wrapped many times with duct tape for abrasion
protection. Better to wear that out than the rings or ropes where
wrapped around the large ring.
Dan Marotta 5J
2C
Old June 2nd 14, 05:35 PM posted to rec.aviation.soaring
Bill D
Our tow operator uses "whiffle balls" to protect the knot and ring pair and they are almost always found inside the ball as intended so it's a bit of a mystery how they suffer so much wear.
Dan Marotta 5J
Old June 2nd 14, 02:09 AM posted to rec.aviation.soaring
Tim[_10_]
when was the release mechanism last and most recently overhauled or
replaced?
especially on old gliders teh release mechanisms were designed for the very
old and obsolete old welded
Tost double tow rings. (see the warning on Wings & Wheels website
http://www.wingsandwheels.com/page30.htm and also on TOST website) when the
current tow rings are used on these obsolete tow releases teh rings will not
completely seat in the tow release so you are always left with a partially
opened release waiting for the evental premature release...
tim
A0
"Kevin Christner" wrote in message
practice this.
2C
Old June 2nd 14, 05:50 AM posted to rec.aviation.soaring
Andrew[_13_]
Hi Kevin
Congratulations on managing this emergency safely. A low tow
termination of the tow is a true emergency, that some people have
not managed successfully, as discussed on this website.
I've been gliding for a long time, and my experience is that
unplanned tow terminations are very rare. I have only had two
unplanned releases, the lowest at 400ft at Lasham (Euroglide 73),
the other at 1000ft at Portmoak. On the one at Lasham, I was very
aware that the entire competition grid were watching me. Both were
wave-offs, due to towplane engine problems (neither serious as it
turned out later, but the tow pilots were understandably concerned at
the time). My experience seems logical when one considers that after
liftoff, the tension on the rope should be close to the drag on the
glider, i.e. about weight divided by L/D, i.e. about 35lbs or less. Apart
from shocks from slack lines tightening, if the rope doesn't break
during the first few seconds when the glider is being dragged over
the ground, a 'pure rope break' is unlikely. The rope is essentially
'proof tested' in the first 30 seconds of every tow. I haven't had any
ring or tow-mechanism malfunctions. So from my experience, the
most likely (but rare) problem is a tow plane engine problem.
You say you are pleased that you practiced for this. I assume you
mean that you are glad you practiced 180 turns from 200ft. I wish to
say that my personal opinion is that a verbal briefing (to go straight
ahead) would have been much safer for your instructors to teach
you, with a verbal briefing that any other alternatives must be
delayed until high enough for 'some maneuvering'. I'd put that at
300ft minimum, when a 90 turn to look back, and do some thinking,
would be be ok, but even then, a turn away to the safest area should
be made, even if off-field. Otherwise, go more-or-less straight ahead,
and let the insurance company worry about their glider. I'd
recommend that instructors should teach that a low rope break is an
emergency, and the only responsibility on the pilot is to get himself
and his passenger down without harm. Damage to the glider should
not be considered. I obviously don't know for sure, but I think its
arguable that this teaching approach might produce more minor
damage to gliders, but fewer fatalities.
It's not that a typical glider isn't capable, aerodynamically-speaking,
of performing a 180 at 200ft. They obviously can. Its that an early
solo pilot may not be able to, and experienced pilots under that
stress may not be able to either.
Safety is a tricky concept. My view is that, to be safe, one should
'stop before it becomes unsafe'. That sounds obvious, but then
consider that this logically means that we should 'stop while we are
still safe'. Ie..... we should stop when we could have safely gone a bit
further. The price for safety, is to stop too early. I can remember
stopping flying (for weather) knowing people were thinking we could
have safely gone on a bit longer. And they were completely right.
Straining this logic, its arguably safer to teach to go straight ahead,
even if an excellent pilot could do a 180.
I stand by my remark made earlier, that a site where a straight-
ahead landing is likely to produce more than minor damage, is not a
safe site.
250ft
abov=
release
mec=
wheel
bre=
had no
prob=
the slack
(probable
but=
unplanned
thing we
d=
2C
Old June 2nd 14, 08:04 AM posted to rec.aviation.soaring
Bruce Hoult
No, that's not the case unless you're not climbing.
With a tug flying at 65 knots and climbing at 6 knots (typical for our glass two seaters) somewhere around 9% of the weight of the glider (up to 600 kg or 1300 lb) is being borne by the rope. That's about 120 lbs in addition to the 35 lbs from drag.
With a 300 kg all up single seater (PW5, Libelle etc) flying a bit slower and climbing at over 1000 fpm there is actually even more strain on the rope.
I do agree that if it doesn't break on initial acceleration then it probably won't.
I'm not going to go into the turn back or not question again other than to say if you can land safely more or less straight ahead then of course do so, but you should also be competent to turn back if that's best.
Rope Break! Waveguru Soaring 9 August 28th 12 03:17 AM
Rope Break Walt Connelly Soaring 4 April 12th 11 09:04 PM
Explanation Required: ATA (actual time of arr) and ATD (actual timeof dep) SVCitian General Aviation 2 September 19th 10 10:27 PM
Actual Autos Ol Shy & Bashful Rotorcraft 3 April 26th 07 04:22 AM
IR without actual IMC Iain Wilson Instrument Flight Rules 26 October 13th 03 11:26 PM
